Alternator issues
1987caddy
Hey everyone, on my 95 XE the alternator is only producing 12 volts until I rev the motor to 3k RPMS and then it produces 13.8-14 volts after that. With the engine off, battery has 12.3 volts. When first start up its showing 12 volts at the battery. Once you rev it, it makes good voltage even at idle and voltage stays good with a load on the system. Battery is 2 months old and alternator is 6-7 months old. It's a reman 90 amp maxima alternator. Any ideas to fix low voltage at startup?
That actually sounds typical for the Maxima swapped alts. Mine will sometimes not charge well at idle either. I think Simon or someone else had it do it on theirs as well.
I think it might be a pulley size issue.
I do remember some talk about this issue also
