87 twin turbo sas 1 inch lift...
More Alum work....
Trying another radiator configuration...
Had a custom Jegs radiator in the shed for a past project. Wondering if I can get this bad boy to fit...
Went to the Junkyard and picked up a Volvo E-Fan... these are the same unit as the 2-speed Taurus fan... only removable from the shroud.
These Volvo units also have an easy to remove relay pack for the fan.
This is also on the way... coolant fan switch from NAPA. This switch is used in THESE applications.
While at the yard getting the fan... napped the plug (and a used spare switch) from a VW..
Making it work together...
Edited by GrandpaX
does that thing ever come out of the Garage ?
Does it need to? This thing is where most of the new mods are come up with. It will someday drive and do everything well. However it is probably my last huge Nissan build... so why not make it a good one.
Edited by GrandpaX
  • 1 month later...
You have the coolest toys. :)
Thanks, ya all this crap and my favorite toy is...
As I get older the luxury of getting away from it all has become more and more inviting. Bought this middle of the road 29er last summer.. It helps me get lost.
  • 1 month later...
Getting slowed down by other everyday commitments... however getting close on the truss for the 96-97 Isuzu Rodeo Dana 44. It is a smaller version of what I posted before...
The pan hard runs the other way to match the direction of the front track bar (SAS).
The truck is setting high on jack stands.. the pan hard is almost level at ride height.
