Low Brake Pedal
BrianD
I have posted before about replacing my brake lines - so that went well but now I've got a low brake pedal - Bled them 2 x all 4 wheels - even removed the ground from the battery but still I have to push the brake pedal quite far before getting any action - Suggestions pls?
Thanx - Brian
Thanx - Brian
Don't know about the R50 but the WD21's equipped with ABS you have to bleed the ABS unit also
Adjust the rear brakes. The drums could be way out of adjustment, causing the shoes to move far further than they would normally have to in order to contact the drum.
^ This happened to me when I changed my rear brakes. I thought it was not bled properly but then I adjusted them and it was nice and tight. However if the parking brake feels normal to you or feels like it always has then I don't think its the brakes.
Sometimes bleeding brakes can be a pain... air gets stuck and it's hard to get it out. During the process maybe try hammering on the brakes a ton of times occasionally (with all the bleeders closed). Like for 30 seconds straight, pushing really hard over and over.
Tap Gently. Hammering breaks stuff.
Alternatively, replace the bleeder screws with speed bleeders and/or use a pressure bleeder. Motive products makes a very nice one that had adapters for many different cars. I've used on for years. It makes a frustrating job routine, and a lot less messy. Even so, you may need to run the bleed procedure a couple times to get any air trapped in the ABS actuator, and get it to collect in the calipers/wheel cylinders to get it out easily. Good luck.
Hehe, perhaps, but I'd like to know that I can hammer on my brakes if I need to! With the truck off (no power brakes) I doubt you're going to do much damage unless it was already almost busted, in which case maybe it'd be good to find out in the garage? But I'm only talking about there being a small amount of air in the lines. Anyway, no warranty comes with my advice!
Sounds like the master cylinder. Not hard to replace. Careful with the brake fluid, will eat your paint off. I would make sure your wheels are off as well if your going to bleed the brakes in case you get brake fluid all over which will eat the paint right off those black steelies.
Thanx - Brian
Thanx everybody - in the owners manual on page 8-19 (do it yourself) there's a procedure to check the brake booster - which I did and it seems to work better now - Oh ..I also did the emergency brake handle pull(also in the owners manual)which is supposed to adjust the rear shoes - the pedal is still a bit low and bugs me - I gotta get 4 rubber tubes and bottles for bleeding. However ..in the workshop manual - it says to bleed the load sensing valve FIRST!( I do not see a bleeder vavle for it) then do the bleeding in order of: Left rear - rite rear - left front - rite front - which I've dun 2X - duh!
I was also told to leave the brake fluid resevoir lid off over nite and sumtimes it will bubble the air out on it's own - Which I have not dun yet...if have any luck with all of the suggestions I will post again...it rained all day yesterday and I have no garage.
What I meant by "Tap Gently" is to actually tap repeatedly P... on each caliper with an actual hammer to help shake loose any bubbles stuck to the inside of the caliper fluid chamber, so the fluid passing through it can carry them out of the system. Stomping("Hammering") on the brake pedal can move enough fluid to break residual bubbles loose, but since I rarely have a helper with brake bleeding, I use a pressure bleeder with clear vinyl tubing attached to the bleeder valve so I can see the fluid condition and watch the bubbles coming out. Be sure to run the tubing up from the bleeder valve before curving it down into the collection container to create a trap so the air bubbles don't work back up the tubing into the caliper while you are trying to close the valve.
Thanx a lot - I never thot o that - will do!
