ahardb0dy Posted April 20, 2010 Share Posted April 20, 2010 Took the adjustable shock switch apart today and the bulb is no good, it is easily replaced but can't find a source for it. Even in Nissan FAST it just shows the switch itself, don't want to spend $40 on a switch when all it needs is the bulb. The bulb that is in the AC switch looks the same but has a different base, but the bulb itself can be removed from the base and put in the other base. So anyone know where I could find these bulbs? Looking for sources other than junkyard or the dealer. Thanks Link to comment Share on other sites More sharing options...
GrimGreg Posted April 21, 2010 Share Posted April 21, 2010 IIRC Radio Shack carried a bulb that works. Link to comment Share on other sites More sharing options...
ahardb0dy Posted April 21, 2010 Author Share Posted April 21, 2010 thanks, from all the reviews of people using them in their cars I think they should work. Appreciate it. Link to comment Share on other sites More sharing options...
ahardb0dy Posted April 25, 2010 Author Share Posted April 25, 2010 thanks, picked up the 2 pack of bulbs yesterday after work, $1.79 plus tax, swapped the bulb today, it was the exact same size, works perfect now, one less thing to do on the pathfinder now. Link to comment Share on other sites More sharing options...
adamzan Posted April 25, 2010 Share Posted April 25, 2010 Can you post a pic of these? The bulbs in the switches in my 95 are bulbs with the wires wrapped in some little rubber thing. Link to comment Share on other sites More sharing options...
Tungsten Posted April 25, 2010 Share Posted April 25, 2010 the rubber thing is a color filter the radioshack bulbs work fine if you can't find any, try bulbtown.com Link to comment Share on other sites More sharing options...
ahardb0dy Posted April 25, 2010 Author Share Posted April 25, 2010 in the shock switch the rubber part is the mount for the bulb it has nothing to do with being a filter, pic below: 12V Microlamps (2-Pack) Model: 272-1092 | Catalog #: 272-1092 $1.79 Link to comment Share on other sites More sharing options...
adamzan Posted April 25, 2010 Share Posted April 25, 2010 So how did you wrap the wires around the rubber thing? Very carefully I assume?? Link to comment Share on other sites More sharing options...
Tungsten Posted April 25, 2010 Share Posted April 25, 2010 oups didn't read that right yes you have to insert the long wires at the base of the bulb into the holes of the rubber base and wrap them around the rubber base insert just like the old bulb was done, then clip off whatever is left over Link to comment Share on other sites More sharing options...
kiwipete Posted April 25, 2010 Share Posted April 25, 2010 (edited) I'm looking at replacing mine too, but we here in New Zealand don't have a supplier of these wee bulbs. I am however going to try small 12V LED's instead. Edited April 25, 2010 by kiwipete Link to comment Share on other sites More sharing options...
ahardb0dy Posted April 25, 2010 Author Share Posted April 25, 2010 (edited) I wrapped the wires the same way the old bulb came out, the 2 wires and the bulb in the big hole, each wire has it's own hole under the bulb, than run one wire back up towards the top of the bulb than back down again, than I cut off the excess wire, repeat for other wire, done Edited April 25, 2010 by ahardb0dy Link to comment Share on other sites More sharing options...
ZombeeXXX Posted April 25, 2010 Share Posted April 25, 2010 http://autolumination.com/74.htm Just about everything you could need. They also offer some led alternatives. Link to comment Share on other sites More sharing options...
