94pathfinder Posted January 18, 2010 Share Posted January 18, 2010 on the way to work this morning i noticed that my tranny was slipping quite a bit, and now after my drive home it seems that i have no third gear at all it'll shift into third, and you can press the gas pedal, and it'll just rev up. i can drop it from drive to 2nd and it'll work fine. any ideas. thanks Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted January 18, 2010 Share Posted January 18, 2010 when was the last time you flushed the transmission? have you checked the condition of your transmission fluid lately? is it dark brown and no longer cherry red? does it smell burned? did you bypass your stock transmission cooler to an external unit? Link to comment Share on other sites More sharing options...
94pathfinder Posted January 18, 2010 Author Share Posted January 18, 2010 no on the tranny flush, never done it. i have the oe trans cooler. didn't know about replacing it with an aftermarket one, what do you recommend? Link to comment Share on other sites More sharing options...
94pathfinder Posted January 18, 2010 Author Share Posted January 18, 2010 the fluid was a reddish brown color smelt a little burnt, not too bad i think. but it definately wasn't a cherry red fluid color. Link to comment Share on other sites More sharing options...
OldSlowReliable Posted January 18, 2010 Share Posted January 18, 2010 I definately see atleast a changing of the fluid, if not a cooler also... Mine is in the same boat (just the fluid color) and I'm preparing to change it out.. Link to comment Share on other sites More sharing options...
nismothunder Posted January 19, 2010 Share Posted January 19, 2010 (edited) Nope,you need a new tranny,thats what mine did,you burnt a clutch plate,I'm sorry for your lose...Just revs in third,no gear there at all,you can try changing the fluid but it probly will be just a waste of money...Again I'm soory for your lose... Edited January 19, 2010 by nismothunder Link to comment Share on other sites More sharing options...
87pathy Posted January 19, 2010 Share Posted January 19, 2010 stupid nissan trajomatics Link to comment Share on other sites More sharing options...
Precise1 Posted January 19, 2010 Share Posted January 19, 2010 Yes, but it is quite often caused by neglect or the damn cooler clogging. Yeah, I have one and I'm doing everything I can to keep it from frying. It's already been rebuilt once... B Link to comment Share on other sites More sharing options...
Precise1 Posted January 19, 2010 Share Posted January 19, 2010 on the way to work this morning i noticed that my tranny was slipping quite a bit, and now after my drive home it seems that i have no third gear at all it'll shift into third, and you can press the gas pedal, and it'll just rev up. i can drop it from drive to 2nd and it'll work fine. any ideas. thanks no on the tranny flush, never done it. i have the oe trans cooler. didn't know about replacing it with an aftermarket one, what do you recommend? That really doesn't sound good at all. I don't think changing the fluid will help, but if you do, make sure to replace the filter/pickup unit, clean the pan and bypass the stock cooler that is prone to clogging. There are many threads about them. Honestly, I think you need a tranny shop or a replacement unit. B Link to comment Share on other sites More sharing options...
94pathfinder Posted January 19, 2010 Author Share Posted January 19, 2010 ok how hard is the 5 speed swap? Link to comment Share on other sites More sharing options...
nismothunder Posted January 19, 2010 Share Posted January 19, 2010 I hear its cheap if you get a 5 spd rig to swap from,just time consuming... Link to comment Share on other sites More sharing options...
slade420 Posted January 19, 2010 Share Posted January 19, 2010 "I hear its cheap if you get a 5 spd rig to swap from,just time consuming... " what would you say is the difficulty rating? if one had a donor 5 spd. Link to comment Share on other sites More sharing options...
Precise1 Posted January 19, 2010 Share Posted January 19, 2010 If you can change the clutch, you can do the swap. It's a bit more work but not any harder. Someone just did this with a write up lst year. Was it BeastPath?? Search for "tranny swap" and see what you find. Yes, the way to go is with a donor vehicle... B Link to comment Share on other sites More sharing options...
94pathfinder Posted January 20, 2010 Author Share Posted January 20, 2010 ok not doing the 5 speed swap, found a guy on craigslist with a good transmission with the shifter linkage broken on it, and a bad transmission with a good set of shifter linkages. Link to comment Share on other sites More sharing options...
94pathfinder Posted January 24, 2010 Author Share Posted January 24, 2010 Ok so i've ordered a replacement transmission with 65K on it from Japan for 380 bucks, then i'll go to one of the auto parts stires and grab a trans cooler, and hopefully i'll e able to do more then 35. Link to comment Share on other sites More sharing options...
Precise1 Posted January 25, 2010 Share Posted January 25, 2010 Yes, good idea. I was at the wreckers yesterday and grabbed 2 tranny coolers, one fair size off of a pathy and a pint sized one off of a chrysler. Where did you order a tranny with 65k miles for $380?? Good deal!! I think many people would like to know!! B Link to comment Share on other sites More sharing options...
94pathfinder Posted January 25, 2010 Author Share Posted January 25, 2010 Ebay motors from JDM Engine Depot in Texas, free shipping too. should be here on tuesday Link to comment Share on other sites More sharing options...
Precise1 Posted January 25, 2010 Share Posted January 25, 2010 Nice. I'll copy that link into the parts source thread. I'm glad you found a good price. Let us know how it goes... B Link to comment Share on other sites More sharing options...
94pathfinder Posted January 26, 2010 Author Share Posted January 26, 2010 transmission should be here today so now the endless wrenching to pull the old one out begins. ohh joy!! Link to comment Share on other sites More sharing options...
94pathfinder Posted January 29, 2010 Author Share Posted January 29, 2010 yeah this is more of a bitch than i thought it would be. stuck on the torsion bar ancours on the front lower control arms. mainly on the drivers side, and the bigger bolt, other than that. yeah this thing is the suck Link to comment Share on other sites More sharing options...
Alkorahil Posted January 29, 2010 Share Posted January 29, 2010 Was this happening after the vehicel was warmed up or soon after you started it? I see you are in Michigan and it is winter time.... if it has been real cold there, especially over night when it has been sitting, then it takes the fluid a while to warm up, it will not like or want to go or stay in overdrive. Just a thought. Link to comment Share on other sites More sharing options...
R3DN1CK Posted January 31, 2010 Share Posted January 31, 2010 Was this happening after the vehicel was warmed up or soon after you started it? I see you are in Michigan and it is winter time.... if it has been real cold there, especially over night when it has been sitting, then it takes the fluid a while to warm up, it will not like or want to go or stay in overdrive. Just a thought. agreed... also, nissan make a tranny cooler flush. 999MP-AM006P I belive. Link to comment Share on other sites More sharing options...
94pathfinder Posted February 9, 2010 Author Share Posted February 9, 2010 ok i believe the tranny gusset is right where the starter goes, is this true or not. Link to comment Share on other sites More sharing options...
PATHRIDER Posted February 11, 2010 Share Posted February 11, 2010 Ebay motors from JDM Engine Depot in Texas, free shipping too. should be here on tuesday Would you happen o have the direct link please Link to comment Share on other sites More sharing options...
94pathfinder Posted February 12, 2010 Author Share Posted February 12, 2010 ok im about to head down to the shop, does anyone know what size the crankshaft bolt is. i only have up to a 24mm, it won't fit. Thanks John Link to comment Share on other sites More sharing options...
