Superior shift correction kit
TerranoNZ
As most people know my trans blew up a while back and I've been rebuilding it myself. After getting the torque converter rebuilt (That was what blew) I ordered 2 shift kits and a few remaining bits I needed.
I can't offer a complete how to, but with the FSM it's pretty easy to pull the trans apart. This is more so people can see what's involved before taking the job on.
Should you do it? Well I've rebuilt a few engines in my time, I've a pretty good mechanical understanding. I've got the FSM to work from, without this I wouldn't of started it :aok:
This is what you get in the kit + instructions. *The 0.041 drill bit arrived broken, but was not a big deal as you only need that for the "Heavy duty" option.
Tools you will need: Basic tools, socket set, spanners, cir clip pliers that sort of thing.
Vernier calipers
Power drill
Parts wash
Step 1: Cross drilling through gallery
As per instructions, remove the pressure regulator valve. Some of the valves were hard to remove. I had a magnet that was too big to fit inside.
But with a cunning plan :aok:
Using a pin as an extension I was able to get the steel valves out easy.
Place the body protector in place.
Use the 0.062 drill bit to drill through the body wall.
Clean out the body with parts wash, make sure to debur the hole on the other side.
Step 2: Pressure valve spring
Measure the spring, if in spec as mine is add little blue spring. (Blue)
Step 3: Sequence & Relay valve
Remove the valves and replace separator plugs and pins. (Red)
Be sure when reinstalling that the springs are seated on the clips correctly.
Step 4: Pressure modifier
Remove and inspect for cracks. (Yellow) Don't really know why that's part of a shift kit :shrug:
Step 5: Modifier accumulator
Step 6: Drilling separator plate Let the fun begin
Drill as per instructions either Regular duty or heavy duty. I went with Regular as this is my DD and I read that someone went heavy and thinks it shifts too hard.
Debur all holes and clean swarf.
Step 7: Put the valve body back together
As in FSM
Step 8: Replace accumulator seals
As pic these are Teflon seals not O-rings, hence the split in them. 2-3 &1-2 Accumulator only (4 seals)
They are a PITA to install. Use petroleum jelly to hold them in and quickly push them in, but don't push too hard.
Step 9: Replace accumulator spring
New spring is red colour.
Very hard :rolleyes:
Step 10: Replace Servo cover gasket
Pretty straight forward, Torque bolts to 11.5Nm (100 In/lbs)
Step 11: Orifice plug :rofl:
My case doesn't have the plug or ball in question, so I'm done here.
Step 12: Replace rings on stator support shaft
2 large and 2 small.....Easy, just careful of the Vaseline :lol:
DONE :jig: Now cross your fingers it works :D
  • 3 months later...
  • 1 month later...
My bad Adam... I missed your post, better late than never :D
Shifts really nice, Hard shifting seams faster and gentle shifting is sometimes unnoticeable.
I wish I could post a vid, but it's really one of those things you need to feel.
That's a damn good idea :aok:
  • 7 months later...
