ILoveMyPatty Posted August 17, 2009 Share Posted August 17, 2009 Well, after my wheel came off while cruisin down a dirt road, I've got some fixes to do. My wheel studs are stripped like crazy and I need to replace them. I got new studs, but cannot figure out how to get them out. Do I have to take my hub off and then slide the wheel stud mounting plate thing off? I'm so stuck. My search function isn't working either.. thanks for the help! Link to comment Share on other sites More sharing options...
GrimGreg Posted August 17, 2009 Share Posted August 17, 2009 For the front, it's easiest to pull the disk off and go at them. For the rear, easiest to gut the brake and then replace them with the axel in place. Link to comment Share on other sites More sharing options...
ILoveMyPatty Posted August 17, 2009 Author Share Posted August 17, 2009 Pull the disk? So I have to take it all apart starting from the outside, which involves taking out the hub? Or can the disk be removed with all of that intact and pull the studs out with the plate thing in its original position? Link to comment Share on other sites More sharing options...
GrimGreg Posted August 17, 2009 Share Posted August 17, 2009 Yeah, remove the caliper and the hub. The hub nut holds the disk on. Link to comment Share on other sites More sharing options...
ILoveMyPatty Posted August 18, 2009 Author Share Posted August 18, 2009 Seems quite involved to replace wheel studs. What a PITA. Link to comment Share on other sites More sharing options...
Precise1 Posted August 18, 2009 Share Posted August 18, 2009 Yep, they are a pain, but also not a 'normal' repair. B Link to comment Share on other sites More sharing options...
MY1PATH Posted August 18, 2009 Share Posted August 18, 2009 u should take pictures as you do it. It will provide usefull for the next person to change front rotors or studs like you are doing. Link to comment Share on other sites More sharing options...
adamzan Posted August 18, 2009 Share Posted August 18, 2009 (edited) It's not hard at all to remove the hub 1. Have someone hold brakes to loosen the 4x4 hub bolts (makes it easier) 2. Remove caliper and wire it out of the way. 3. Remove 4x4 hub if you haven't yet. 4. Remove snap ring, there are some washers behind it too, be careful you don't loose them. 5. Remove wheel lock nut cover (there are 2 Philips head screws holding it on) 6. Remove wheel bearing lock nut. You have to use the special nissan tool or you can use to 6mm Allen keys in the holes. Now the hub should slide off with the rotor, be careful you don't drop the wheel bearings. Good time to re pack them too. I don't know if you have to remove the rotor but if you do it's bolted to the hub. Hope this helps. Edited August 18, 2009 by adamzan Link to comment Share on other sites More sharing options...
GrimGreg Posted August 18, 2009 Share Posted August 18, 2009 I don't know if you have to remove the rotor but if you do it's bolted to the hub. Those bolts alternate with the stud spaces. Link to comment Share on other sites More sharing options...
Terrano1992 Posted August 18, 2009 Share Posted August 18, 2009 I don't know if you have to remove the rotor but if you do it's bolted to the hub. Loose these bolts first (with brake pressed), then remove caliper and hub. Easy way... Link to comment Share on other sites More sharing options...
k9sar Posted August 18, 2009 Share Posted August 18, 2009 Link to comment Share on other sites More sharing options...
