Sway Bar Disconecter's
kiwipete
Well I have had to re-install my sway bars because I failed a WOF with them removed. Now, I want to be able to continue with the excellent articulation I get without them so I am thinking of making some disconnecter's for them, saving me the hassle of fitting them back in place every 6 months for the WOF.
The rear ones are easily enough modified by cutting the shaft, sleeving it and welding the sleeve to one half, assembling the unit, drilling and pinning it together.
The front ones are going to be harder to work out. As you can see by the pictures below there is not much length of the connecting bolt to work with.
What suggestions do you guys have for me here please?
edit, fixed photos up.
Edited by kiwipete
Wonder how they'd (The WOF guys) Feel about a thin sway bar. Shave it to within an inch of it's life, so is no longer does it's job :D
Though there isn't much flex in the front.
How about cutting the sway bar in the middle then weld a sleeve on one side and a drill hole on the other for a pin?
wouldnt that make the it hard to get the pin in " if ever needed " with lineing up the hole????????
Now there's an Iidea that sounds crazy enough to kind of make sence. Yes re-connection may be a bit of a pain but thats why you have someone to bounce on the bumper for allignment issues and as Tex said, a trusty old persuasion device.
I'm still goeing to copy that idea Dave, I'm just too lazy... You ever get your setup worked out so you didn't have to go underneath to disconect them that you were planning?
2 things about the front, if your lifted you can use a longer connecting bolt, hell the energy suspension kit does
and if you sleve the center for A pin I see no propblems, If you drilled it when was level then it should go back together when its level.
Somehow I don't think i'd get away with that either, humph.
I get better flex without the bars all the same.
That would have to be one hell of a pin with the loads placed on it, wouldnt it?
Better to sleeve it, and place a fake pin in it so it just looks like its pinned, he he he, now there's a thought.......
Heres mine that I had made up for the rear, fronts are next
The only thing that worries me with your set up Dave is the bottom section hanging down. i'td get knocked about a bit wouldnt it, or do you discon both sides and hang the bar up somehow?
I thought only one side of the rear needed disconnecting?
What plans have you for the front?
As long as the Bottom A arm section of the bolt and the swaybar part too, does not come into contact with anything as the suspension moves when it is all disconnected?
I'm currently using 2 lengths of 6mm shock cord on either side, this keeps it roughly in stock position without it restricting articulation.
Not sure about the front yet, I will pull it out and have a look one day soon.
With my lift I can reach through the wheel arch and disconnect/reconnect quite easily, only takes a few seconds each side.
Yeah that was gonna be my other suggestion :D
BTW if you wanna practice I've got 2 pair of links you can play with :aok:
I might just grab those spare links off you please, it has been suggested that I try to get the certifier to ammend the cert for no front swaybars. At least the rears are easy enough to modify.
  • 2 years later...
I think I'm going to attempt this one. I like running anti-roll bars on the road as I'm used to driving a s13 and a z32, i can definitely feel the difference on-road. they suck on the trails though!! I've got the extended energy suspension front sway bar bolts as well so it should make it a little easier to work with. I'll post pics up when I do it.
