AC upper control arm
Coucoui6
just put the control arms on and don't crank the torsion bars too much. leave an inch between the UCA and the upper bumpstop and you should be fine. most people wreck cv's because they don't replace torn boots
an inch a ive got about a 1/4 inch hehe
sorry for thread jack
Not really easy. You have to make sleeves for the bushings. I used 1" diameter nylon rod, cut them to length and drilled them big enough for the bolts.
Just ordered a set of them, maybe in 2 weeks they will be here so I can install 'em. :)
its about 6 hour job to put in the diff drop but it helps i have put in the ball joint spacers and yes they will ruin your oem upper control arms i had to strengthen mine after they cracked in only days of use i have not been able to afford any aftermarket UCA's but my reinforced oem's are great after 2 years now in total i am 3" up in the front with re indexed t-bars and the 1" spacers
