92Pathmaker Posted January 17, 2009 Share Posted January 17, 2009 Is there another plug besides the one on the driver side bottom of the radiator. With the cap off I tried draining through that one and got about 12oz of coolant after 15 min. I'm not sure if I am missing something or if something is plugged up. I've tried searching everywhere and all I can find is directions saying to drain the coolant, no pictures. Thanks for any advice in advance. Link to comment Share on other sites More sharing options...
MY1PATH Posted January 17, 2009 Share Posted January 17, 2009 you should have gotten more than 12oz from the radiator... There are also 2 block plugs, one should be behind the alternator and the other should be behind the PS Pump. Don't forget to move your heater to hot so the heater core gets drained too.(do this with ignition "on" for electronic models) hope that helpled. Link to comment Share on other sites More sharing options...
92Pathmaker Posted January 17, 2009 Author Share Posted January 17, 2009 I thought that there would be one on the block, I just didn't know where to look. I'll go try to find those. Thanks. Is it important to use distilled water instead of tap water. Will the minerals build up or something? Link to comment Share on other sites More sharing options...
92Pathmaker Posted January 17, 2009 Author Share Posted January 17, 2009 Is there any trick for collecting the coolant from the plug behind the alternator? It is a very interesting place to put a drain plug. I got the rest of the anti-freeze out it just ended up all over the place. Link to comment Share on other sites More sharing options...
MY1PATH Posted January 17, 2009 Share Posted January 17, 2009 a wider bucket? Link to comment Share on other sites More sharing options...
silver97ex Posted January 17, 2009 Share Posted January 17, 2009 Good to know cause I am doing mine Monday. I just plan on making a mess. Link to comment Share on other sites More sharing options...
92Pathmaker Posted January 17, 2009 Author Share Posted January 17, 2009 It splashes all over the diff. and control arm you would need one that is 30" wide. I just made a big ass mess. Everything else was pretty easy. Good luck Silver Link to comment Share on other sites More sharing options...
adamzan Posted January 18, 2009 Share Posted January 18, 2009 there should be a little hose attached to that drain valve. Mine has one. Link to comment Share on other sites More sharing options...
MY1PATH Posted January 18, 2009 Share Posted January 18, 2009 (edited) there should be a little hose attached to that drain valve. Mine has one. There are NO HOSES on the ENGINE BLOCK PLUGS only on the radiator plug. but shoving a piece of vaccum line in there quick might give it some direction. Edited January 18, 2009 by MY1PATH Link to comment Share on other sites More sharing options...
adamzan Posted January 18, 2009 Share Posted January 18, 2009 Yeah I meant the radiator one. Man you don't need to shout, I have a headache Link to comment Share on other sites More sharing options...
92Pathmaker Posted January 18, 2009 Author Share Posted January 18, 2009 I like the idea of using a hose of some sort, you have to get it on there quick. It will save you from spraying antifreeze everywhere and having to clean it up, unless you are into that kind of thing. Link to comment Share on other sites More sharing options...
Precise1 Posted January 18, 2009 Share Posted January 18, 2009 *snort* It's not golden... B Link to comment Share on other sites More sharing options...
GrimGreg Posted January 18, 2009 Share Posted January 18, 2009 Just cut off the lower hose and let it drain out, probably due for new hoses anyway. Link to comment Share on other sites More sharing options...
silver97ex Posted January 19, 2009 Share Posted January 19, 2009 All the hoses are recently replaced so I will use the drain plugs. I'm off to do it right now. Link to comment Share on other sites More sharing options...
Simon Posted January 19, 2009 Share Posted January 19, 2009 Clamp the lower hose with something (not vice grips, as the teeth can damage the hose) then take it off the rad. Stick it in a bucket, then unclamp it. Link to comment Share on other sites More sharing options...
GrimGreg Posted January 19, 2009 Share Posted January 19, 2009 All the hoses are recently replaced so I will use the drain plugs. I'm off to do it right now. Why didn't you do the flush when you replaced them? Link to comment Share on other sites More sharing options...
msavides Posted January 19, 2009 Share Posted January 19, 2009 (edited) Clamp the lower hose with something (not vice grips, as the teeth can damage the hose) then take it off the rad. Stick it in a bucket, then unclamp it. Go to home depot and get a cement mixing pan. I got one that is large enough to almost covers the entire front end of the truck. Then just pour it into suitable contain for recycling (using a funnel). It works great for all kinds of fluids when your not sure where it is going to run off of. http://housewares.hardwarestore.com/35-175...aign=googlebase Mark Edited January 19, 2009 by msavides Link to comment Share on other sites More sharing options...
silver97ex Posted January 20, 2009 Share Posted January 20, 2009 Why didn't you do the flush when you replaced them? Well, I had the w'pump, tensioner, t-stat, and all hoses replaced at the same time. Then my t-stat was sticking open so I replaced that myself and didn't use the correct/enough of the liquid gasket so it wanted to leak. So yesterday I pulled it all apart again to fix the leak. The drivers side drain plug didn't want to move, I got the passenger side out so I just drained that....and made a decent sized mess but its all good. So far, no leaks Link to comment Share on other sites More sharing options...
