ctpathy Posted August 17, 2008 Share Posted August 17, 2008 Maybe someone has had this problem. I have power going to the fog lights the switch lights up and the lights are brand new. I also checked the two 15 amp fuses and are good so i'm out of ideals. hope someone can help thanks ctpathy Link to comment Share on other sites More sharing options...
Alkorahil Posted August 17, 2008 Share Posted August 17, 2008 Maybe someone has had this problem. I have power going to the fog lights the switch lights up and the lights are brand new. I also checked the two 15 amp fuses and are good so i'm out of ideals. hope someone can help thanks ctpathy Have you checked the relay? Is is a small black box, about 1" by 1" mounted on the passenger side firewall near the wiper motor. Should say 'Bosch' on it. Link to comment Share on other sites More sharing options...
Alkorahil Posted August 17, 2008 Share Posted August 17, 2008 (edited) Also, make sure your high beams are not on Edited August 17, 2008 by Alkorahil Link to comment Share on other sites More sharing options...
yozsi Posted August 17, 2008 Share Posted August 17, 2008 yep, your headlights should be on low beam for them to work... if you have power to the lights check your grounds. Link to comment Share on other sites More sharing options...
purdyboy89 Posted August 17, 2008 Share Posted August 17, 2008 Maybe someone has had this problem. I have power going to the fog lights the switch lights up and the lights are brand new. I also checked the two 15 amp fuses and are good so i'm out of ideals. hope someone can help thanks ctpathy I have the exact same problem, i have checked everything except for the relay. Although i have no clue where I might find a replacement relay at? Link to comment Share on other sites More sharing options...
GrimGreg Posted August 17, 2008 Share Posted August 17, 2008 I have the exact same problem, i have checked everything except for the relay. Although i have no clue where I might find a replacement relay at? Any automotive store will have the relay that the fogs use, it is a standard relay. Link to comment Share on other sites More sharing options...
Alkorahil Posted August 18, 2008 Share Posted August 18, 2008 Any automotive store will have the relay that the fogs use, it is a standard relay. Yep. Link to comment Share on other sites More sharing options...
ctpathy Posted August 21, 2008 Author Share Posted August 21, 2008 You guys where right it was the relay. Thank guys for all your help ctpathy Link to comment Share on other sites More sharing options...
Mr. Pickles Posted August 23, 2008 Share Posted August 23, 2008 Yep, standard relay, $5 or less at any parts store or even Walmart, etc. Link to comment Share on other sites More sharing options...
jpawela Posted February 8, 2009 Share Posted February 8, 2009 Sorry to revive a resolved thread, but I didn't feel the need to start a new one. I have the same problem as mentioned above and it is the relay. I replaced it with a generic one from AutoZone and the fogs are all wackoo now! The minute I plug it in the right fog comes on with the lights switched off. When I turn on the lights, the right one goes off and the left one comes on. If I left that relay plugged in, it would run down my batt. Manager assured me this was the correct one and that I have other issues. What gives? Link to comment Share on other sites More sharing options...
edicer2 Posted February 8, 2009 Share Posted February 8, 2009 did they work before? i bet its the wrong relay go check or look ofr a diferent one Link to comment Share on other sites More sharing options...
jpawela Posted February 8, 2009 Share Posted February 8, 2009 did they work before? i bet its the wrong relay go check or look ofr a diferent one They didn't work by themselves, but if I hit the stock Bosch relay it would occasionally work. I'll try again to take it back. Link to comment Share on other sites More sharing options...
beastpath Posted February 9, 2009 Share Posted February 9, 2009 thats awesome. i wish everything would work if i just hit it. Link to comment Share on other sites More sharing options...
Precise1 Posted February 10, 2009 Share Posted February 10, 2009 Doesn't work with my GF... B Link to comment Share on other sites More sharing options...
