Factory fog lights
ctpathy
Maybe someone has had this problem.
I have power going to the fog lights the switch lights up and the lights are brand new.
I also checked the two 15 amp fuses and are good so i'm out of ideals.
hope someone can help
thanks ctpathy
thanks ctpathy
Have you checked the relay? Is is a small black box, about 1" by 1" mounted on the passenger side firewall near the wiper motor. Should say 'Bosch' on it.
thanks ctpathy
I have the exact same problem, i have checked everything except for the relay. Although i have no clue where I might find a replacement relay at?
Any automotive store will have the relay that the fogs use, it is a standard relay.
  • 5 months later...
Sorry to revive a resolved thread, but I didn't feel the need to start a new one.
I have the same problem as mentioned above and it is the relay. I replaced it with a generic one from AutoZone and the fogs are all wackoo now! The minute I plug it in the right fog comes on with the lights switched off. When I turn on the lights, the right one goes off and the left one comes on. If I left that relay plugged in, it would run down my batt. Manager assured me this was the correct one and that I have other issues. What gives?
did they work before? i bet its the wrong relay go check or look ofr a diferent one
They didn't work by themselves, but if I hit the stock Bosch relay it would occasionally work. I'll try again to take it back.
