ctpathy Posted June 23, 2008 Share Posted June 23, 2008 Hey guys My son has a 91 pathy and he has a squeel when it warms up and at 3000 rpms. We have changed the ideler pulley with a used one has this happen to any of you. thanks for all your help Brian aka ctpathy Link to comment Share on other sites More sharing options...
Nismojunky Posted June 23, 2008 Share Posted June 23, 2008 fan belts? Link to comment Share on other sites More sharing options...
Slick Posted June 23, 2008 Share Posted June 23, 2008 i just gave mark a pulley as his was a squealin ....... it happens..... old age n all...... Link to comment Share on other sites More sharing options...
RedPath88 Posted June 23, 2008 Share Posted June 23, 2008 Local Schucks Auto Supply listed prices varying from something like $8-$20 (bearing only) depending one which one you need.. there were a couple sizes apparently and iirc around $30-$35 for the entire pulley w/bearing. Link to comment Share on other sites More sharing options...
Precise1 Posted June 26, 2008 Share Posted June 26, 2008 New belt, belt tension, belt dressing. Try any of these? B Link to comment Share on other sites More sharing options...
adamzan Posted June 27, 2008 Share Posted June 27, 2008 Just for the record belt dressing is only a temporary solution. It shut my a/c belt up but then 2 days later the belt flew apart while i was on the way to a midterm exam. Needless to say I spent 45 minutes unraveling tiny strings of belt from my fan clutch and shaft, and drove it to a gas station and borrowed a knife. NOT fun in the cold Canadian winter! Link to comment Share on other sites More sharing options...
RedPath88 Posted June 28, 2008 Share Posted June 28, 2008 Then the belt squeal was not the problem, it was the symptom Link to comment Share on other sites More sharing options...
Slick Posted June 29, 2008 Share Posted June 29, 2008 if you need a pulley, i have another spare.............. Link to comment Share on other sites More sharing options...
Precise1 Posted June 30, 2008 Share Posted June 30, 2008 Just for the record belt dressing is only a temporary solution. Depends on the condition of the belt and WHY it was squealing. If it is just a glazed belt, a dab of bar soap works well, just be careful getting in there!! Then the belt squeal was not the problem, it was the symptom Well said. B Link to comment Share on other sites More sharing options...
Alkorahil Posted June 30, 2008 Share Posted June 30, 2008 I can get you a new one for $35.00 if you want. Part number is 11925-88G00 Link to comment Share on other sites More sharing options...
