Loose Timing Belt?
cooleeze
Hello,
I took the top timing cover off and started it. I noticed the timing belt seemed quite loose when running. Are they normally loose? somewhat loose? I don't know the history, the timing belt seems to be in good condition but I was hoping to drive from A to B for a couple weeks before doing the timing belt(my other vehicle isn't on the road and I'm in a bit of a bind). Any suggestions would be great!!
Cheers :)
Thanks for the responses,
Actually when I twist it between the cam gears it dosen't want to go beyond 90 degrees, maybe just seeing the belt movement when running scared me a bit, I don't know.
How long of a job dose it usually take doing this timing belt having above average mechanical skills? Just curious.
Thanks!!
If you have the top cover off, your 1/3rd of the way there P...
If you dont know when it was changed last... and your over 60k-110k Change it.....
Pull the:
Skid Plate
Shroud
Rad and hoses
Fan
HB
upper and lower cover and your there.... While there, T-stat and water pump.... It is way cheaper than $800 for a JDM delivered to your door..... Then you would get to do all this stuff anyways....
I agree.
It isn't a hard job or very time consuming (have done it 3 times, about 3hrs each time). As long as you have all the parts and tools you will need all ready to go before you start, it should go smooth. It helps a lot to have a second set of hands also. The hardest parts are usually the harmonic balancer and the main nut on the crank, the main reason you pull the radiator is to easy the ability to get tools on those parts.
If my memory serves me well, when I did my t-belt (before and after) the belt would loosen and then tighten frequently. This happens because the valve springs put tension on the cam lobes witch in turn makes the the cam pulleys "spring" away from each other. I think it is normal to have a bit of looseness...NO?? Did my belt about 6 months ago and everything is still a go. But changing the belt is never a bad idea regardless.
Yes, the belt should/will flutter to some degree while the engine is running. Tension is checked while engine is off.
Plus, grabbing the belt to twist it 90 degrees while it's running can be dramatic. And painful.
hahaha thanks for the responses. I'm going to throw some insurance on it w/o doing it right now. I know, I know it's a gamble but this thing is so rusted out that I almost want to take it out for a bit of wheeling to see if anything else is wrong. I just don't trust it and if it breaks oh well, I traded it for an Xbox 360 to my brother who had it sitting for almost 4 years.
I guess I need a reason for throwing more money into it(I'd like to do a few things while doing the timing belt) and a successful wheeling trip will make it(motivate me) or break it. :chairfall:
Well, a broken timing belt on our trucks usually will mean the replacement of at least a few valves, if not the heads or even engine. We have an interfearance engine; the valves and pistons play in the same playground, if the bell doesn't ring then they are both at recess at the same time and hurt each other.
Dude, watch this!! :lol:
Ok I know you feel the risk is worth it, but even if you only do the belt your just in it a couple hours and about $20 (might also consider a new tensioner if it's just been sitting for 4yrs)
If it breaks then it may end up being the same as if you had just taken to hammer to the XBox you traded.. maybe more. The point is, unless your just out the break and dispose of the truck, the risk is... IMO ...not worth it. And if you do mean to just destroy it, then please jusst sell or give it to someone who can get some real use out of it. :beer:
Less than a day and you assure yourself that the belt should not be an issue.
I recommened that your seriously think about it before deciding not to change it :togo:
