Help me install my ebay impulse buy
Little Mule
I bought a JDM clinometer/altimeter on ebay late one night. Why? I don't know. And I thought it was kind of neat as I tend to like gadgets. I guess its a little bling.
It works mechanically, but has some wiring for lights. I'm going to put it on the center of the dash just above the air conditioning vents. But before I go putting holes in my dash, I want some expert advice.
Question 1: How should I attach this to my dash? What is under the dash that I can damage if I try to drill into it? I don't think the vinyl dash material is strong enough to hold it on its own.
Question 2: Wiring it up? There is one red and one black wire. I assume I need to attach an inline fuse on the red. But to where should I connect the power?
Thanks for the help. Here are some photos.
The cluster:
  • Replies 75
  • Created
  • Last Reply
Top Posters In This Topic
Ideally, the red wire should be connected to one of the dimmer-switch controlled 12vDC+ wires for the dash lights, so it goes with the rest of the lights. Realistically, you can hook it up to any 12vDC+ source you want. The black wire is the ground, of course. No idea on how mounting should go, it appears to me that they screw to the dash in JDM stock form, but I've never experienced an install of anything like this. I'd say try doublesided sticky 3M foam tape and see if it'll sit flat against the dash that way.
There's some killer 3M tape that you could probably get anywhere. I've used it and its great. Its heavy duty, pretty much permanent, and made for automotive use. Sticks like hell for sure. Just be sure to clean the dash thoroughly to remove any armor-all or any of that type stuff so you get a really good stick.
There is one on ebay now. Here's the link:
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW
I almost got one for $25, but someone tried to snipe me, but failed. But they drove my price up. :angry: Oh well.
I'm going to do a little studying before I install it, but I will take pictures when I do put it in. My only concern about using an adhesive is the the mounting bracket is a little raised. Thus, if I just use adhesive, the cluster will sit about 1/2 inch above the dash, leaving an ugly gap. If anyone has one mounted, I'd love to see a picture.
Thanks.
You'd about tip over at 50 degrees! Pathys are good up to 45 at least, though.
I've seen several of those things go for at least $50 on Ebay...you can buy a Steel Horse tiltmeter/clinometer for about $20 new if that's all you wanted. I never wanted to drop $50 on one specifically from Japan. Spendy toy, that's for sure!
Try spending money to buy a new car. The way I see it, little expenses like this keep me happy with my 16 year old car, and decrease the urge to go buy a new Titan, etc.
But, as I said. I was up too late on ebay. It does however match my dash, and that was the final straw that made me give in.
well... I've heard of "flying down the road" but to need an altimeter?!?
I've got an ebay search for wings and a rudder, but nothing has come up yet.
Cool. I got it installed. It was easy. I took pics of the process. But you have to wait until Monday. I'm going fishing this weekend and hope to take an action photo for you. I need to go get my fishing gear ready now. WAVEY
As I said, I didn't want to use adhesive tape, because the bracket stands too tall. This would leave an unsightly gap between this gauges and my dash. I can't have my pretty Pathy be unsightly. The pic of the gap:
Then carefully take out the air vents. You need to remove 3 more obvious screws. There are four plastic retaining tabs that you can push down with a thin flat head screwdriver. You may also need to slightly push away the edges of the dash pad if they overlap the vent housing.
Ok. After you have the air vents out, if you look into the space where they were, and luck up under the dash, you will see 4 square holes in the plastic. 2 are towards the front, and 2 are towards the back. The front holes are about 2.5 inches ahead of the back. The holes are also 6 inches apart from side to side. This perfectly matches up witht he 4 holes of the bracket used to mount the altimeter/clinometer guages. Figure out where those holes correspond to the top of the dash. I did it by putting 2 small nails through the front holes, putting my bracket on over the protruding nails, and then circling the back bracket holes on the dash.
Here is the pic of the nails protruding through the top of the dash, and my bracket over them. This enabled me to find where the holes in the back of the dash need to be. After I figured this out, I took a scapel blade and cut out holes in the top of the dash as seen in that last picture. I also made a small hole in the middle to run the wires through.
You need some metal clips like this one already in the dash. I tried Checker auto parts, but they didn't have anything like it. The clerk there said she had never even seen anything like it. So I tried 2 Nissan dealers. Neither had any in stock, so I had to wait 4 days as they ordered them. :angry:
I'm sorry, but I lost the receipt, so I can't tell you what part number they are. If I find it, I'll post it.
Here is what it looks like underneath with the screw coming through the metal clip. After screwing the bracket into all four metal clips, thread your wires through the center hole and down past the AC controls and radio. Screw your guages into the mounting bracket, and screw the cover into the top of the bracket. You will need a short stubby screwdriver for that because the windshield is in the way for a long screwdriver. I still need to hook up my wires. I'm going to do as 88 suggested earlier and hook them up to the dimmer switch.
