14
Everything posted by CamperDan
Yes a OEM Nissan replacement clutch kit would be nice but that can be a bit pricey. I'm currently running an aftermarket heavy duty clutch kit from Clutch Max Pro https://amzn.to/4qRWyXw I tow my wife's 6X10 Cargo Trailer Camp Conversion with my R50, and do some off-roading every now and again too. I've been running this setup on my 2001 R50 Pathfinder 4X4 for the past 3 years with zero issues. As for gear box itself, if you can find the parts to rebuild it I say go for it, you can also try checking your local junkyard to see if you can find a used one. But they are very rare and hard to find since the manual transmission was only available from 2001-2002 for this gen R50. I've only come across 3 examples in my local junkyard here in Las Vegas in the last 5 years.
If the clutch pedal is anything like the clutch pedal on an R50 it might be caused be a worn clutch pedal assembly. I had a very similar issue on my R50 not to long ago. Turns out that the pin that connects the clutch pedal to the clutch master cylinder had wallowed out the hole that it goes through and caused the clutch pedal to not be able to fully return to its resting place after the clutch pedal was released. Check out this short video for reference.
@IdahoFalls, I paid $850.00 about 3 years ago here in Las Vegas to have my clutch replaced, but this was the cost of labor only, since I provided my own parts. With parts included, it would have cost me $1050. I should also mention that my R50 is 4WD. If your R50 is also 4WD and this is the quote you received with parts included, I would say this is a fair price. I hope this information helps. Chris.
Crank No Start, Coolant Dripping From Oil Pan
CamperDan replied to AlekAuto's topic in 96-2004 R50 Pathfinders
@AlakAuto, based on what I know about the VQ35DE engine in your 2002 R50 Pathfinder, there are a few potential sources for your coolant leak. One possibility is the water control valve, which is located under the lower intake plenum at the rear of the engine. My guess is that the rubber hose connected to it might have failed. I hope I’m wrong about that, as it can be quite a job to access. Regardless, I recommend starting with a coolant system pressure test. Another area to check is the rubber heater hoses that connect to your heater core on the passenger side firewall of the engine bay. If this were the issue, I think you would have noticed that leak by now. In my experience, when those heater hoses leak, it usually doesn’t run down the oil pan. Doing a pressure test may also help you pinpoint the leak. Chris.- 6 replies
- troubleshooting
- help
(and 2 more)
Tagged with:
This is your Rear Windshield Wiper Motor, you will need to remove your rear wiper arm and then there will be a plastic nut that you will need to remove from around the wiper motor shaft which will then allow you to remove it from your R50 hatch. Chris.
- 1 reply
- 2
The "L bracket" in the photo on the right goes on the back side of the alternator and, yes this alternator replacement job is a pita. I had to replace the alternator on my 2001 a few months ago and it took hours to to complete not to mention all the parts you have to remove to make enough working room. I'm surprised you were able to get the alternator to stay put without it, as it is meant to securely clam the backside of the alternator and keep it fixed in place as you thigten the bolt that goes through it. As for the other bracket on the left it just supports a wire loom, I had to go back and check my video to verify as it's been about 9 months since I've done this repair. Check out time stamp 44.40 of this video for reference, I hope this helps Chris.
OK I guess it wouldn't be a bad Idea to have a replacement flywheel on hand just in case the original one can't be reused. As it's always better to "have and not need than to need and not have" it's definitely worth fixing and keeping on the road, as these manual transmission R50's are rare and hard to find. Replacing the hydralic hose and clutch slave cylinder is very easy, Wishing you all the best with your repairs on your new R50 Chris.
I don't blame you for outsourcing the clutch replacement to a local repair shop, it's a big job, and that's what I did when my clutch gave up the ghost. Replacing the clutch hydralic hose is not a bad idea just due to it's age, but I'm curious as to why you want to replace the clutch master and clutch slave cylinders. Are they having issues? You should also be able to reuse the flywheel unless it was absolutely smoked by the previous owner. Chris.
I recommend ClutchMaxPRO Heavy Duty OEM Clutch Kit I've been running this on my 2001 R50 4X4 for a little over 2 years now and I've never had an issue. I get nice smooth shifts and I do quite a bit of towing with this set up too. Check out this link https://amzn.to/42X8JtM Chris.
- 2 replies
- rear main seal
- clutch issues
(and 1 more)
Tagged with:
Rear glass hatch/window won't stay open
CamperDan replied to csprinkle's topic in 96-2004 R50 Pathfinders
Good deal, you're very welcome anytime, thank you for all of you're views and support I appreciate it! Chris. -
I had also had this issue when I first acquired my R50, the good news is it's a cheap and very easy fix. You just simply need to replace your lift struts for your hatch glass. This is also a very common repair. Chris. -
Leaky bleeder valve on Slave Clutch Cylinder
CamperDan replied to PamPoovey's topic in 90-95 WD21 Pathfinders
I recommend double checking the banjo bolt that connects the clutch hydraulic hose to the clutch slave cylinder to make sure it's tight. Although if this is your issue I would imagine you would see brake fluid dripping from the banjo bolt and not you're bleeder valve. Chris. -
Bilstein Shocks 1997 Pathfinder 4x4
CamperDan replied to AR97Pathfinder's topic in 96-2004 R50 Pathfinders
Here's a link to those Bilstein shocks https://amzn.to/3ynRxAQ they are much cheaper to get this way vs getting them through 4X4parts.com, looks like they wanted $54.00 just for shipping lol no thanks. Chris. -
Hey like I said I was corrected on this topic once in the past too, and I'm still learning. That's what makes this site such a great place for all R50 Owners, I don't know everything but NPORA does. I have spent countless hours in the past doing research and asking questions here on NPORA, and just learning to leverage other like minded R50 enthusiast. Chris.
He's gonna want to stick to the VQ35DE that came in R50s 2001-2002 only, because the VQ that's in the 2003-2004 R50s has a few other changes beside from the drive by wire throttle body. I was also was planning on sourcing a spare engine from the junkyard out of an 2003-2004 R50, but according to our late friend @Dbot there's other things that have been changed like the cam phasers, sensors etc, so it won't mesh with his R50s current computer. He advised me of this as he was thinking about doing the same in the past, but after doing some research he came across some of these differences in the engines. Chris.
96 Tailgate Glass Hinges Broke while driving
CamperDan replied to Danbergie's topic in 96-2004 R50 Pathfinders
1996-2004 R50 hatch glass hinges are all the same, you'll also find that a lot of R50 parts are interchangeable. Chris. -
Well in this case the only other thing I could recommend if your local junkyard allows it is to bring your old panhard bar to the junkyard with you and try to match it up or test fit it on one of those R50s that's there. My R50 has been a bit of a work in progress, it's come a long way and it's also been built and maintained with junkyard parts lol Chris.
Do I have a partially blown head gasket??
CamperDan replied to Ripple's topic in 96-2004 R50 Pathfinders
You are very welcome, I'm always happy to help, and thank you again for all of your views and support. I'm also pleased to hear that you have found my YouTube videos helpful. Chris. -
Sorry to hear about the recent issues you have been having with your R50, you can complete a head gasket combustion leak test. Here's a link to were you can get said leak test kit. https://amzn.to/3Rf56Jc It is straight forward and very easy to complete this test with the use of this test kit. I sincerely hope it's not a blown head gasket. Oh you can also try bleeding air from your cooling system via the bleed port on the backside of your engine, it will be covered by a rubber cap. Just make sure you are doing this when the engine is cold and with it off Good luck. Chris. -
I'm definitely adding this one to my bag of tricks when it's time to R&R my Clutch Slave Cylinder and Clutch Hydraulic Hose man they are rusty! Chris.
I echo Slartibartfast's recommendations for replacing your negative battery cable as you don't want to inadvertently cause stress on your battery or alternator. It's not that bad of a job to replace it yourself either I also had to replace mine a few weeks ago due to it being too lose and it was causing a no crank no start issue for me from time to time. You can find one relatively cheap on Amazon that's where I got my replacement negative battery cable from. Here's a link https://amzn.to/3ReK2Tg Chris.
That's awesome, I think I seen that video in the past too, when in doubt look again! Chris.
man talk about going through the wringer, I just replaced the Alternator on my 2001 R50 Pathfinder 4X4 5-Speed a few weeks ago and it was not fun. It's also been my experience with my R50 you fix one thing and then something else pops up that needs fixing. After 3 years of owner ship I finally got my check engine light to go off and stay off. My advice is to keep fighting start with the cheap and easy stuff first and work your way up and good luck! Chris.
