Stpickens
17
Stpickens last won the day on September 10 2020
Stpickens had the most liked content!
2003 pathfinder le
Choose
Choose
2003
Vancouver wa
Country
Stpickens's Achievements
NPORA Veteran (3/5)
262
Running out of fuel, upon fill, tank only takes 16 gal.
Stpickens replied to DonutHands's topic in 96-2004 R50 Pathfinders
It sounds like you may have a fuel vent breather issue or the fuel pick up has dislodged. I can attest that these will use 20.1 gallons before they start to sputter. Tested it out last week to be exact, not on purpose. Sent from my iPhone using Tapatalk -
I still haven’t fixed my odometer light either [emoji23] and I have everything to do it. Sent from my iPhone using Tapatalk
It’s an extreme leds lightbar. Sent from my iPhone using Tapatalk
Hawairish and TowndawgR50 are teaming up!
Stpickens replied to hawairish's topic in 96-2004 R50 Pathfinders
Mine would be the one on Facebook with the 3” sfd. I will let the pines to spines guys explains the technical parts. The sfd strut mounts do fix the camber issues beautifully. You essentially need to get the full 4” sfd kit to utilize the full benefits. Like leveling out the cv axles back to factory angles. With any spring lift you have on the struts you will keep that going into the added height of the sfd. So if you have +2” springs and then add a 4” sfd you’ll net a total of 6” over factory height. My current set up: OME Struts OME Springs 3”sfd 7449 Landrover springs. All this equals + 4.75” over factory height. Sent from my iPhone using Tapatalk- 155 replies
- 5
- sfd
- trailing arms
(and 3 more)
Tagged with:
Pines to spines 3” sfd OME had struts and springs LR9449 rear springs. Sent from my iPhone using Tapatalk
Here’s my reason.
Looks great! Sent from my iPhone using Tapatalk
I am ready for the sfd kit whenever you are. [emoji1303] Sent from my iPhone using Tapatalk- 155 replies
- 1
- sfd
- trailing arms
(and 3 more)
Tagged with:
His rig is pretty sweet. I can’t wait to get him out on the trail. [emoji1303] Sent from my iPhone using Tapatalk
