PATHRIDER
Everything posted by PATHRIDER
  1. thanks bud..ill check it on the rear q panel
  2. If I can only locate it im pulling one out from my wifes truck for now..Thanks edicer...Im still trying to look for it...im thinking its in the kick panel
  3. Trying to look for the power doorlock main control box on my pathy but not having any luck.. I tried replacing the actuators on the drivers side door with another one that I know works and that wasnt it...Any ideas guys why the doorlock quit working? Cant operate it from the switch either..all fuses are ok..any help is greaTLY appreciated factory alarm still arms and disarms
  4. Thanks B...I saw the one on the for sale section but the member is in canada..Im going to check cl here also and probably post in the wanted section..ill keep you guys posted
  5. sorry forgot to mention its auto tranny guys..yeah ive seen the how to on droping the tranny pan and its not easy.Im going to take it to a tranny shop and see what the damage is. worst comes to worst ill probbly have to replace the tranny..what would you guys recommend as far as where to get the tranny and how much would it cost to replace it? Thanks for the quick reply guys
  6. Hey guys! my wifes transmission on her 94 pathy started having some grinding noise on drive a few days ago and yesterday it wouldnt go forward anymore but it still has reverse. It makes a grinding noise but it goes away after it shifts....any ideas if the tranny is toast or just some sensor needs replacing thanks folks
  7. Sorry Scott mistaken you for 88path I wasnt the switch so its gotta be the control module. My switch panel worked on the wifes pathy. Im going to pull the door panel off tomorrow and try her control panel ..Thanks again bud
  8. Brian howzit going bud..Brian right? Ventured into a diffrenet hobby ..old school bmx Hope things are going great at your end Im going to check that ic board and I have a spare one ( I think) switch it real quick. Moving the knob (drivers side) did lock/unlock the doors before but not anymore so it could be the controller..I think mine is on the drivers side inside the door panel just above the speakers. Thanks for the tech info and ill check on it right now..Ill keep you posted shoot I forgot my wife has a pathy too...hahaha...ill just pull here control panel real quick
  9. hey guys is there any other fuse location for the doorlock on a 1993 pathy? My doorlock started acting goofy around jan..it will lock and unlock by itself sometimes when driving and theres times when I lock it through the switch itll lock and unlock by itself..same thing when I push down on the doorlock itself. Any help is appreciated guys
  10. The bushings were replaced with energy suspension bushings when I did the lift 2 years ago and im sure the torsion bars where adjusted perfectly ..Thats the first thing I measured after doing the lift and waited a few weeks for everything to settle and measured it again..just now measured it again and theyre even in the front.
  11. Thanks bud..That pic helped....Ill give it a try and hopefully it helps..Im assuming itll help with the alignment too
  12. Thanks guys. By the way a newbie question here, Is this bracket going to level out my rear? its sitting a bit lower on the drivers side right now and its been like that since I raised it 2 years ago. i used ford coil springs and was cut exactly at the same height prior to install..Could it be that one of the springs is shot? Steve I think I just spoke with you on the phone..are you from rugged rocks?
  13. Hey guys can somebody please tell me if I have to jack my truck up and prop the rear diff to install the bracket for the panhard rod? or can I do it with the truck on the ground and just unbolt the panhard rod and install the bracket? Im thinking that with the truck on the ground on all four theres some load on that panhard rod..Any help is greatly appreciated :coffee!:
  14. Thanks for the info and reply guys.Sorry it took me a while to visit the forum Heres my conversion and a real easy one.Im going to change the bulb to a projector type and do a HID conversion ..Ill post some pics when im done edicer if youre interested I have a brand new grille and all the brackets for the headlights if youre planning on doing a conversion.I was going to use it on my wifes pathy but she doesnt want me touching her baby...lol...she told me it cost too much money everytime I replace something
  15. couple of options that need your suggestion guys.. Hella headlights http://www.partsgeek.com/catalog/1994/niss.../headlight.html or I can also go with the projector type which according to the vendor the bulbs can be replaced. From what I understand on tru tainfs post I can use the hid kit if I decide to considering that its going on a projector headlight Like this http://www.k2motor.com/lhp7x6jm-h.html Let me know what you guys think
  16. Thanks bud.I just checked with calmini and they do have it..Its a rip off though..$75 for that piece..Im going to keep searching.I believe L&P performance makes one also but couldnt get a hold of them.
  17. Pardon my lack of knowledge but its been a while since ive tinkered with my pathy and forgot what some of my suspension parts called..lol.. Ive spoke with caseyt before about my rear suspension and he noticed that its needing some kind of a panhard rod drop kit..Cant remember the name of such part that he has mentioned but I think what hes refering to is a panhard rod drop kit (arrow pointing ) After doing the lift I didnt even notice that my truck sits higher on one side and I know for sure that my springs were at the same lenght and I installed a new set of shocks. Part needed..I think calmini calls this a rear track bar bracket
  18. Excellent.this helped a lot.Im thinking that my headlight is suffering from voltage drop also.Im going to wire it up directly with a relay .You wouldnt happen to have the part number or a place where I can order this composite headlights do you? Been checking online and no luck or maybe I just dont know what to look for I might also upgrade to a bigger alternator soon as weather permits. Thanks My1Path
  19. I am but I go to bmx museum.
  20. Howzip going guys...been a while since I visited the site and might I say that this site is still the best and probably the only one with a lot of knowledgeable members. I ventured to a different hobby for the past 2 years (old school bmx) I need your expertice again guys in converting my 1993 pathys headlight to a HID.actually my front grilles and headlights are from a 93-94 hardbody.I did this conversion a few years back. few of my questions are Is there a composite headlight for the 89-95 hardbody (round one)?The headlights I have right now are the sealed type and the bulbs can not be replaced on those for me to convert to HID ...or is there any other route on doing this without having to replace my headlights from sealed to composite? what brand of HID kit would you guys recommend and where can I find them? Thanks in advance and your input is greatly appreciated guys
  21. I was told the same thing. Thanks for the reply guys
  22. Thanks bud..i bought some last year at a local fasteners and now cand find them...hey path another question is what would you recommend for a panhard bar drop bracket..im going to be needing that also. calmini maybe?
  23. Hey guys does anyone know what size bolt the upper control arms spindle is? lenght and pitch too if possible. Cant find my darn manual and Im going to take to have it aligned tomorrow and the guys at our local alignment shop here told me that I might need longer bolts just in case it has to be shimmed. I dont recall having to use a longer bolts on all the thread I read on here but Im headin to my local fasteners anyways so might as well pick a few. Any help is greatly appreciated Oh yeah this site still rocks.I havent been on here for almost a year and still see a lot of you hardcore nissan enthusiast
