7
Everything posted by PathyAndTheJets
You could give this a shot.
PathyAndTheJets replied to RedRider3141's topic in The Garage
Finally replaced the transmission harness that the PO hacked up. Got reverse lights now. Replaced the broken headlight adjusters and aimed them. Put an unbroken rear dome light in. Put new block off plates in the dash and center console. Put my power mirror switch in, not quite sure how to get it wired up yet though. -
A "better" Warn hub installation
PathyAndTheJets replied to deluded's topic in 90-95 WD21 Pathfinders
I just got a regular style snap ring from my parts bin and made sure it moved a bit. .005 is about when you can see it move. In the same vein, I don't adjust wheel bearings to factory specs. It's too time consuming, and too easy to screw up and burn up the bearings. I get them seated, then get about .005 of play. Just enough to feel. -
How To Care For My "New" Junkyard Frame?
PathyAndTheJets replied to peejay's topic in 90-95 WD21 Pathfinders
Wash it out, paint it with POR-15, spray some gloss black over it for uv protection. -
1988 misfire & wont rev past 3k rpm
PathyAndTheJets replied to Pathy87's topic in 86.5-89 WD21 Pathfinders
That's a shame. That body looks immaculate. If it wasn't raining currently i think I'd be out making sure my crank bolt was torqued still. -
It's behind the back timing cover. So might as well do that too. The balancer isn't a press fit, you should be able to pull it off pretty easily. When you put it back on, wipe some grease on the crank so it comes off nicely next time. -
Spinal column
I also have one.
Yeah. I was about to warranty them out, and then I saw all the lettering was upside down. Flipped then around, rode 100% better.
You're not SASed are you? The front ones only go on one way. I bet the rear ones are upside down. The fat end goes down, that's where the oil reservoir is.
Still trying to figure out Ticking & knocking Sound
PathyAndTheJets replied to Macrow's topic in 90-95 WD21 Pathfinders
Sounds like an exhaust leak to me, you could get a mechanic's stethoscope to narrow down whether or not its coming from the head. Look for any blackening on the exhaust, that'll point to a leak in that area. -
You might check your rear bushings for play, tires inflated properly? On the ranchos is the canister side down? I've made that mistake, truck rode like you're describing.
Limp mode limits the rpm to 3k All those mixture heaters burn up at some point. Mines burnt and now unplugged. I doubt that's the issue. Is your timing correct? -
Power Train Gas Mileage Musings
PathyAndTheJets replied to vf24renegade's topic in 90-95 WD21 Pathfinders
I'm not totally familiar with the jatco auto, but most other 4 speeds will coast in high gear. A one way clutch will freewheel when the drive train is being pushed by the wheels. It sounds like it's engine braking, which is usually done by engaging a band or clutch, usually triggered by a drop into low. I'd start with the brakes though. Especially the drums. Most people struggle with them, and I've seen them put together wrong multiple times. My bet is that they're dragging, which is probably making the transmission feel weird when the torque converter tires to lock up. -
My power steering pump shaft had a lot of play, so the pulley would go sideways under load and the belt would squeal. If you loosen the belt try pushing the pulley back and forth. It shouldn't have much play, like maybe .020" I think a bushing went out in mine, i just swapped pumps out though.
Sharing my winch mount/ tube bumper build
That is some fine fab work. Can't wait to see it finished! What kind of steel are you using? And how much does that thing weigh roughly? Just curious for future plans. -
92 pathy 2 or higher suspension lift?
PathyAndTheJets replied to Charlie_Brown's topic in 90-95 WD21 Pathfinders
You gain approach, break over, and departure angle, then you have more clearance for larger tires. But you wear everything out prematurely. -
Vg30i running issues after rebuild
PathyAndTheJets replied to RCWD21's topic in 86.5-89 WD21 Pathfinders
I'd start by double checking the vacuum line routing. You said you swapped one onto the fuel pressure regulator, which from what I gathered from a quick glance at my spare fuel pump, is integral to the pump. Could be wrong but I didn't see it on the vacuum diagram in my FSM either. But if I am incorrect in that, the fuel pressure reg should have full vacuum supply. -
Yeah. The difference in height between the bottom of the steering stop on the control arm and the center of the pivot bolt should be between 1 3/4 to 1 7/8 of an inch. It looks like yours is almost on the bump stops. That tool should work, I'd still heat it up a bit to soften the adhesive.
Wow, super clean truck! Looks like the torsion bars sagged out on the front. Stock should sit close to level with the rear. If it's glued, a heat gun and some patience, with a follow up with an adhesive remover wheel would be your best bet.
The shop had a keg of it laying around, and I was a few ounces low. The license you need for r12 is the same that you need to legally work on any automotive a/c system. Costs 19 bucks and you have to pass a test. -
R12. No typo. -
1987 3.0 extremely high idle
PathyAndTheJets replied to Projectmudfinder's topic in 86.5-89 WD21 Pathfinders
Have you checked codes on the PCM? Here's a write up on it. http://www.nissanpathfinders.net/forum/topic/21-ecu-self-diagnostics-for-87-95-pathfinder/page-4?do=findComment&comment=770992
