hawairish
  1. Yep, that's them...the Reflex line. However, I don't really recommend them...they do ride a little rough unloaded (though...loaded up, they seem to do well). Quality seems questionable, though. I had to replace one under warranty before I ever installed it...when trying to press one of the bushings out, it hit against my workbench and something inside started rattling. I compared the compression and rebound to the other shock, and it was noticeably easier to compress and slower to rebound. If that's what it took to dislodge something, not sure how trail-worthy they really are. I only bought them for as cheap option, since I was still exploring some other rear suspension options at the time. I paid about $30/ea from Rock Auto...they're still that amount, but with CAN shipping, not sure. Also, the 33-185569 Bilstein above has extended length of 29.7", not 29"...typo on my part. This is probably what I'll go with eventually.
  2. Well, I won't revive my opinion on that topic, but they are owned by the same company.
  3. And just to note...those part numbers are more for answering CDN_S4's question about having that much rear lift. And about the bushings...I'm not exactly sure what pieces come with the Bilstein shocks. From their description, both eyelets are 5/8", which is a good 16mm equivalent for the lower mount. The upper mount is 12mm, so a suitable sleeve would need to be used (or upgrade to a 16mm bolt)...not sure if the the sleeve is included, but I see some sleeves in the pic at their website. I also wouldn't be surprised if you need to use some thick washers to fill gaps on the sides of the bushings if they're too narrow. I'm using some extra thick washers on my setup, top and bottom.
  4. Hahaha, you guys know me too well. The shocks I run are for a 99-04 F250/F350 2WD (Monroe Reflex 911194). The only catch about them is that the bushings needed to be flipped...right sizes, wrong ends. I ended up using some poly bushings instead on one end (Energy Suspension 9-8107G). Here are the stats from Monroe (compressed/extended/travel): F250: 16.625"/28.25"/11.5" R50: 15.125"/24.25"/9.125" If you're looking for a suitable Bilstein replacement, these are the 5125 Series options with the 255/70 valving that XPLORx4 has recommended in the past: 33-104652: 17"/28"/11") 33-185569: 17.9"/29"/11.1") There are some other sizes in the series with different compression/rebound numbers: 5125 Series
  5. I just can't get over the fact that someone sells a car for $75. That's awesome. Unless it's haunted. Then yes, $75 for a haunted car is fair, and still pretty awesome. Time to hit the junk yards!
  6. LOL So, some quick numbers: last tank got 250 miles on 14.85 gallons, so about 16.8 mpg. About 75% of those miles were freeway, cruising around 65 mph @ 2500rpm.
  7. Milling the spacers wouldn't be a problem, but at 3" of lift, you'll be pushing the limits on the CVs. The thing about having that much lift is not necessarily putting the CVs at angles they can't operate at (after all, the relationship between the CV and LCA is unchanged), but instead having the CV work a lot harder while at a weaker angle. It's working harder because it has to oscillate more to do its main function: keep constant velocity. You can also imagine a CV like a ratchet with some swivel joints and extenders...what's going to best deliver torque: everything being straight, or everything having angles on it? Your better bet would be to just use the springs, keep the spacers, and save up for an SFD. I may be able to help you with the latter part soon.
  8. Giggity giggity....those are gonna look nice!
  9. Yes, it could make that much difference. When the upper perch is aligned with the lower perch, the axis of the spring is parallel (or near parallel) to the strut shaft, and load is distributed evenly to the spring along the strut shaft. If rotated, the spring tilts relative to the shaft, and load is no longer distributed evenly to the spring, and is also being applied at an angle. We should also not eliminate the rear from the discussion, though. Have you jumped on the rear of the truck or driven it around to relax the rear springs? It's not abnormal for them to recoup some height when they're removed, but they settle soon after. Did everything else seem to seat properly when re-installing things there? One more thing, going back to another point you mentioned...running the AC coils and the strut spacer will not be good. I wouldn't go much beyond 2" of total lift up front without an SFD. That slight ticking that you noticed that didn't feel too restrictive...well, that is likely still binding. Did you try it with the wheel turned by chance? The tick might be more pronounced.
  10. Well, let's take a few steps back then... First, the maximum possible delta in height between the front and rear before and after spacer installation is .5"...and that assumes that the 1.5" strut spacers doesn't really net 2" of lift. It's only 1.5" tall because of the angle of the strut; similar to a right triangle where the hypotenuse is the strut, you wouldn't need 2" spacer to lift the front 2". Second, if you were standing several feet from the side of the vehicle and comparing the rake visually, but now with less reference between the tire and fender lip, do you think you could honestly tell that it's .5" more off? It would be difficult, unless you're a Masonic eagle. I've run several levels of spacers and SFDs, so I'm very familiar of the breakdown and installation of the components. That said, let's talk about the installation, and a very common mistake made when re-assembling the struts. The upper spring perch has a notch on the perimeter of it, and possibly a "W" stamped on the opposite side of the notch. "W" is for wheel, and that should face outward of the vehicle, towards the wheel. The notched side faces inward towards the engine. If those have been rotated, the spring will not sit at the correct angle, effectively lowering the front of the truck. Can you confirm this isn't the case? Pictures of the front and rear setup would also be useful in case we're missing something else.
  11. That's sounds about normal, but where are you measuring from? The FSM has the specs and where to measure from, so you should be able to gauge the stock take from those numbers. But, of course, you're looking for things to sit level.
  12. Wow, the original post makes me dislike our search function even more. Never seen this thread, and that's basically sums up everything I researched about the LSD the other month. Nonetheless, that's a really good original post! I re-geared to 4.636 when I did my LSD swap. I was pleasantly surprised at the difference it made. It just had a lot more pep because of the efficiency improvement. My tires are about a 5% driveline change, and the gearing change is about -6%, so it cancels out almost perfectly. As for MPG, I haven't calc'd it (yet, measuring on this tank), but it seems to be about the same....and I somewhat expect that. While it's now a little easier to turn the tires, the engine has to make more revolutions to go the same distance as before. It should all net out. I think the gearing change is worth it in general. I paid $140 per diff, and that basically included a free LSD. Again, pleasantly surprised with the restoration of power and torque...I remember thinking, "wow, is this what it was like stock?!".
  13. Probably not issues, per se, but probably a noticeable gap between the theoretical pivot point height on the axle (bottom of the drivers side spring perch) and the real pivot point on the panhard bar mount. If that gap is greater than 2", then I'd suspect he has lift springs.
  14. It's all about getting the clamp hooks far enough apart. It's also wise to make sure the threads are properly greased. On addition to the normal safety precautions, I also wrap the coil with a wet bath towel...it helps stabilize it in my garage floor, and acts as a dampener should something go wrong. I just have difficulty believing that rental spring compressors can't handle the springs, to be honest, and for a number of reasons. I say give it another try.
  15. Hope you're not suggesting that I think anything Stioc did was bad or wrong. Quite the opposite considering I proposed doing it, too. Nothing wrong with being mindful of other systems at play, and voicing it so others can draw their own conclusions and do things correctly. I'm the nay-sayer when I need to, but I'm also the guy thinking about how to do things better and safer. ...unlike that 12" SFD guy whining about cracking a pair of Fleurys spacers and calling them crappy and cheap on the NPORA Facebook page. Looks to me like he's using low-grade carriage bolts meant for lumber, judging by the square seat under a dome-shaped bolt head. He's the kind of backyard mechanic we should avoid being like. There's no excuse for making a death trap.
  16. Well, I've seen it for a few reasons, bigger engines being one of them. But yes, it would have to have some cooling benefits of it lifts the rear of the hood off the weatherstripping underneath it. It's just another way for air to escape the engine bay. My only real caution is that the hood and hinges are designed to 'catch' the firewall during a frontal collision to avoid entering the cabin as a giant blade. Probably not wise to defeat that function.
  17. 97Pathfinderman: see if there are any tags or labels on the rear springs. Also, count the number of wraps/coils and report back. A few of us can compare numbers to see if they're aftermarket. You can also measure the thickness of the coil. Fastpakr: the thing about the basic coil spring compressors is that you have to get the hooks as far apart as possible on the spring. I've not had any problem using them on OME MDs (a few times) or HDs. The HDs were a little tricky because I had to disassemble the compressors (basically just unscrew one of the hooks) slide it in near the coil ends, use a mallet to tap them over a little, and then thread the bolts. I was able to get them opposite of eachother, too, basically getting every coil except the ends, of course. Took more effort than MDs, but was doable.
  18. Hey dude, sorry about the delayed response here. Couldn't remember which thread it was... So I bought these Centric brake line p/ns from Rock Auto: 15042115: 2008-2013 Nissan Rogue, front right 15042116: 2008-2013 Nissan Rogue, front left 15042354: 1998-2004 Nissan Frontier, 2000-2004 Nissan Xterra, rear w/ VDC There are cheaper options. I bought these particular ones because at the time, RA posted the dimensional specs which I compared to R50 lines to confirm a match. The front lines required a little bit of filing to the strut bracket where the hose clips. I remember one hose having a better shape on the hose to work with, but couldn't tell which side was which. They were good for about 2" extra length, but more if you fab up a bracket. The rear line was good for nearly 6" extra. And yes, I think I will sell the PHB drop if you're interested...but only selling for what I paid. I put some gray epoxy paint on it already.
  19. Guess I could've explained the magic, but there it is. Yeah, I've got no major concerns about water on the engine either...for short periods of time. I wash my engines down at the spray-n-wash all the time. Rain's not an issue where I live for the most part (but when it does rain, it pours here...monsoons + El Nino). But I'm talking about driving vs. parking. If I'm driving, no worries: it'll steam or drip off from motion. I wouldn't want for it to be parked with water dripping into the engine bay for prolonged periods of time, especially atop the engine where water can pool in some places.
  20. So, you've not seen Andy's setup yet?? Just kidding... This guy (Silverhorn) over at NICO has a cool setup: Though judging by some engine pics, there's really no good placement if dripping water is a concern. However, I'd think it only be a decent concerned while parked, no? I know I've seen hoods propped up a little at the hinges for venting. It'd probably look awkward at the fender lines, but I'd think lifting it off the rear weatherstrip a little would help. Or maybe even removing the weatherstrip altogether? I think the cowl is already shaped to drain water to the sides below where the weatherstrip is installed (too lazy to go outside to check).
  21. How much did it end up being? When I bought mine a while ago, it was all included in the price. But still, sounds like it's a $100, 25% discount. Not bad. Also, the HD shaft only comes with the R50 version, otherwise the cross shaft gets re-used.
  22. Yes, it's supposed to on yours. Came with the two I received the other month.
  23. Good stuff, Kyle. In fact, that's kind of why I was asking...I had been looking at some OE Mustang, Grand Prix, or GTO hood vents that have drip trays. But they also looked to be rather restrictive. Of course, every bit helps, and what hot air isn't blown under the truck while driving will surely escape where it can. Even at slow speeds, hot air rising of course.
  24. Seen a particular set of louvers that you liked? I've been thinking about them too.
