Everything posted by Mr. Pickles
What he said. /\ I've run mine for 9 months or so, several times on the trail and daily driven. I've gone about 5-7K miles or so. It takes a little bit of getting used to, nothing major though. Feels stout at all hell when driving. The ratcheting and popping sounds will scare you the first few times, but its normal and ok. I've actually had some fun with the looks people give you in parking lots like at the grocery store. Soccer moms pull their kids away, while guys in the know stop and look for a sec or 2. Some guys have described it as a bit "spooky" sometimes on road, which I would agree with, but nothing bad at all, more like maybe a mild pull like you'd feel from a truck rut under some conditions, but no biggie. You just get used to it, and then its second nature. Ditto on the coasting or mild throttle around corners, but that's just at slow speed really. There's not much difference going down the highway. And you can do some nasty sweet power slides if you really want to. sly Off-road, the gain is HUGE. I rarely "need" to use 4wd anymore at all, although I'll still do so just to be on the safe side. It will make your truck nearly as capable in 2wd as it is now in 4wd, so going into 4wd means that much more difference, and more you can do. Getting stuck gets a lot harder.
What, you guys think its cute to salt-up the mud holes for the rest of us?
Mine were actually exactly your book description, nice and easy. Lift, loosen nut a bit, break it loose with a pickle fork, loosen bolts, remove and replace. Straight forward as can be. Word is the lowers are much more in depth.
Ah, yes, a trailer queen. I'd prefer to drive mine to the fun.
The long black bolts are for the rear-most body mounts, and there are only 2. There are tons of write-ups about the install from me, 88, Statikuz, and others. Search, and you shall discover most everything really. :type:
Yep, I also added a 2nd hook, then used those points to mount my guard/fancy light holder. The first attempt had the right idea but failed (duct taping Red's mouth closed :X ) but version 2.0 is solid and going strong. Sorry for the crappy quality on the 2nd pic, I couldn't find the camera so I used my phone.
Rockwells, that's what I was thinking. Aren't there 2.5 ton as well? This guy needs one of these though.
Houston, we have a problem.... :o $$$$$$$$$$$$$$$$$$$$$$$$$$
Just grab some shears and trim that valence and the plastic back a bit. Only takes a few min, and you can make it look pretty much factory if you take your time. Had to do that at stock height with 31's (and sagging suspension), but I think I would have had to even after suspension. Only takes a sec.
95 with new thorleys& flowmaster 50 2.5"
Mr. Pickles replied to MikeV's topic in 90-95 WD21 Pathfinders
Like MWS says, I bet you hit the resonance frequency of your engine and exhaust system. I'm there at 2500-2800 RPM's with stock pipes and a Flowmaster 40. The sound suddenly increases almost double with a blatty sound, but it would depend on your set-up as to what you hit. The walls/mountains on the side would add tons as well. Maybe a combo of different exhaust exit location, length, and/or muffler would solve it. -
Outstanding! I'm sure you'll have it full of projects and crap in no time at all!
*shakes head at the mystery stain in the interior* Good luck man! At least you have a plan taking you on to bigger and better things.
If in doubt, you could buy some cheap cut-out's from places like JC Whitney, just to try it out. There's everything from simple bolt on/off, cable-actuated, to electric, etc. Probably won't help power, like has been said, but if you gotta do it, do it I guess.
went wheeling for the first time, lots of Q's
Mr. Pickles replied to twotirefryer's topic in General Forums
I've got the Rough Country UCA's= good. Got the Energy Suspension poly bushings almost everywhere up front= good. Sounds like you've got a good game plan going. -
Welcome back! What they said up there. /\ congrats, sad, then congrats again! Missed the part about Pezzy leaving the hubby though... (been gone a while myself)
If everything else checks out, try driving it around a bit. Mine did that after washing it (although it was warm when being washed), and I went through the basic stuff too. Some of the guys convinced me to *drive it off*, and sure enough after probably 30-40 gentle miles it ran fine again. Water must have got somewhere it didn't like, and it eventually evaporated or something.
Fiberglas fenders... Linky
If you're already gonna put in a different motor on the cheap, why not a 350, for all the work either motor would probably take.
Haven't messed with it so far, been busy on house projects. Has anybody pulled the switch from the tranny before? Is it just a simple unplug and unscrew? My Haynes manual predictably says nothing. I may just go grab a junkyard one and see if that's it.
I'd stop throwing parts and guesses at it and go back to square 1 at this point. You changed the T belt and immediately had problems? Go back to the T belt, and start from scratch.
Man, this thread is old! I'm going on 29 shortly. Next year at 30, I fully expect a bunch of black balloons, a keg, and a... ummm... huh.... wait, what was this about again. *mental note* 2007 NW NPORA winter meet/trail run/beer/bbq/zzzzzzzzz Do it!
omfg! Looks like something off the wreck of the Titanic! Is this the usual salt damage people have to deal with back east? Sorry, I can't add anything more productive than :o . Where are you at again? Ran out in the driveway, but mine looks like factory in comparison, and my truck is kinda rusty. Good luck.
Under $20?! We have no Advanced Auto here. pssd Yeah, that should be plent of jack for your truck for most anything, and good stands too. LOL, 20 years... B is old.
Regular changes and/or good quality products are key. I've used the high-mileage stuff for the last couple years, whichever is on sale. But regardless, I religiously change oil and filter every 3K miles in our vehicles. Our Acura calls for oil and filter every 7K, but it still gets it every 3 or so. Honestly, yes, its probably overkill. But if you do it yourself in the Pathy, it takes about 10 min and $10. You can't really go wrong there in my book.
I'm there, out of principle. It just struck me that it died when it did, but I didn't touch anything, so I guess/hope its a fluke. I doubt it though. If not, next up is a junkyard reverse light switch. If that doesn't do it, I'll say screw it and go the old manually switched route. That would probably be the most durable bet in the long run anyways.
