92Path_68CJ
92Path_68CJ last won the day on February 25 2024
92Path_68CJ had the most liked content!
About 92Path_68CJ
  • Birthday 09/12/1992
    1993 Pathfinder, Calmini HD steering, Swayaway HD torsion bars
    Screwdriver Mechanic
    Choose
    Southern California
6,351 profile views
92Path_68CJ's Achievements
NPORA Old-Timer (5/5)
91
  1. Finally been catching up on years overdue maintenance. Got the drilled and slotted rotors on a few weeks ago, today did upper and lower ball joints on the driver side and repacked the bearings, next the passenger side, followed by the tension rods. (picture before I cleaned up my grease mess)
  2. If anyone ever finds themselves looking for these connectors because they also want to reuse the factory harness. Use part number: 12015792 Delphi Weather Pack Someone on the facebook group managed to reverse image search for them online. I'll just order new connectors
  3. I appreciate the suggestion, I have one set already I used to wire some lights to the stock fog light harness. I checked online and some places through my work, but the connector is pretty darn uncommon from what little I've seen. Autozone "makes it, but one is 34$. I broke the original fog lights years ago and saved the wiring knowing I would do something with it eventually, Im hoping maybe someone will have done something similar. I'm not in a big hurry, but I do wanna continue to use to stock wiring. It's already there. https://www.autozone.com/electrical-and-lighting/fog-light-connector/p/duralast-electrical-wire-connector-275/
  4. Wanted: Fog light connectors for the WD21. Anyone have the male end (attached to the fog light) in good shape off the factory Bosch foglights for the WD21 they'd let go? New ones are like 20-30$ a connector. I'd like to wire some non factory lights into the factory harness and if anyone has some in good shape I'd be interested in purchasing them. I only need the connector that comes off the factory foglight, I don't need the factory foglights themselves, or the harness that goes in the car.
  5. Its been years since I've been on here but I still wonder about this from time to time, I'm curious to see what the solution ends up being.
  6. I do the same a couple times a year. Im trying to make it a habit of checking everytime I wash mine.
  7. as long as you dont use your shocks as limiting straps you'll be fine.
  8. Yup, we have those here. Not a bad visual deterrent.
  9. Project Pathfinder blew its trans on the Mojave Road this weekend.
    1. Show previous comments  2 more
    2. 5523Pathfinder
      5523Pathfinder
      I don't remember a external trans cooler being installed. Was there one?
    3. 92Path_68CJ
      92Path_68CJ
      Good question. I will have to look next time I got out there. It was very cool out when it went, and it had been sitting for a while, so it surprised me.
    4. 92Path_68CJ
      92Path_68CJ
      Has a trans cooler. Guess I forgot. A new rad and an e-fan conversion was already its its future. The stock 93 radiator can't hold its own in 100 degree summer heat. When we get there we'll see about a new trans cooler and maybe a temp gauge.
  10. Been done a few times. All custom work. The more you can do the better. Otherwise its all about the $.
  11. Not stock, but 31 inch BFGs, automatic, about 2500 @ 65.
