Everything posted by Leo94
87 twin turbo sas 1 inch lift...
Leo94 replied to AK9849cy's topic in Solid Axle Swaps, Hardcore Custom Fab
That's off his npora profile and it shows when he was last online not when he last posted on here. -
All good, It is a great country but unfortunately I wouldn't recommend staying here permanently. The price of living here is so damn high compared to other countries and the vehicle laws are just ridiculous, here is an example of some new laws that will commence soon and they even crush cars rather than auctioning them off . If I had the choice I would probably live in New Zealand -
Don't hold your breath. -
Seen this build before, imo he should have kept the chopped body rather than going full buggy.
Just swap the entire loom and the dash along with it, better than wiring imo
Could you post some photos up to show us how bad it is?
Now you do have a reason to download it .
Fuel pressure?
1988 Gas Tank. Rust issues
Leo94 replied to PathfinderProject1988's topic in 86.5-89 WD21 Pathfinders
*Por 15 -
The battery? you can just drain whatever power is left manually, when its unhooked push the brakes and the horn and that should do the trick.
Clean the throttle body again and the IACV, It's happened to me before where I clean the IACV on a different vehicle and the problem actually gets worse and it idles much higher so try cleaning both and see how you go. Have you tried letting the ecu reset?
$300 is pretty decent for a r50 if you ask me. If I were you I would get the r50, swap the engine and drive it till you can fix the wd21 then either sell one or keep both.
Thanks, I'm pretty sure I found the link to that fsm on here but iirc the link went dead.
Click on them.
I have a FSM for the 89 d21/wd21 which covers the tbi unit and how to adjust the tps, it's about 155mb and I can't remember where I got it from but if you want I can upload the two pages which show how to adjust the tps.
Wouldn't let me edit but here are some other useful links: 1. D22 Gearbox noise 2. D21 Gearbox help 3. 4x4 D21 Manual Transmission
1. Never done it myself but if this isn't your daily it might be worth a shot, there's plenty of info online as well as the fsm that covers rebuild. 2. It would appear that a d22 qd32 box might fit. 3. Depends how confident you are, time, money etc. Maybe just upgrade to a bigger box and be done with it. I was going to say auto hubs not working properly but after reading again you said the diff is getting drive but not to the cv axle. First thing I would suggest is check the diff and gearbox fluid levels and go from there, but it pretty much sounds like your diff is stuffed.
Also don't use regular body filler, that's just for smaller stuff and may even come out after a couple of offroading trips.
I would use something like fiberglass filler or JB weld.
Replacing the screws on the fuel regulator to bolts or phillips hex head bolts would be a good idea too. Do you think you would be able to take a couple of shots of the back of the engine and maybe places you can't get too/see properly when its in the vehicle and then posting it here, I'm sure these will help other members for explanatory purposes and such, But thanks for the video it really gives you a good idea of what the back of the vg30e engine looks like if members need to relate to it for future purposes.
Or a transmission jack adapter for a floor jack if you're on a tight budget.
I did this on photoshop a little while ago in regards to another forum topic on npora. I didn't really photoshop the bar on well but you get the idea.
Picture it in your head, then click below.
Need advice on possible pathy usage.. Lifts and such.
Leo94 replied to Cabincar's topic in 96-2004 R50 Pathfinders
If you could upload a couple of shots of path in the forest you plan on taking it would help allot in the decision on what vehicle you plan on getting i.e What you might think is a hard trail might not be that hard at all and in that case maybe a r50 could be suitable for your needs, after all the r50 is a much better off-road machine than the outlander.
