7
Everything posted by gv280z
If my mechanic was correct, mine seems awfully low compared then at the 125 roughly give / take region. My truck runs great though, with 31s I can hit 60 in about 8 seconds I think and mileage is around 16 - 18, haven't had a road trip to calculate long dist. mileage with the new tires yet but I did get 19mpg before the tire swap on hwy trips. I've barely got like 202,000 on my engine and I never see it smoking. Could my mechanic have been wrong?
I put K&N in everything I got man, both my nissans and my chevy, my old honda I used to have and the Maxima I had before that. You just take it out once in a while, like every 6 - 8 months or so, knock all the loose dirt out against the sidewalk or side of your house, then spray the cleaning solution on it and let it set for a little bit, then spray it out (from inside out, push the dirt back out of the filter, not INTO it) with a garden hose. Let it dry and then spray a light coating of oil onto it, drop it back in. It beats buying a new air filter twice or three times a year and they flow a lot better. After you clean it out you can almost see through it. I always like to put it up to the sunlight and look through it to find anything I might have missed.
Yeah even though it's my argument I tend to agree with you considering the relative youth of his engine at only 156,000 miles old. It's gotta be something though...there is SOMETHING amiss, something tangible. Well, now it looks like we're down to: General drive train issues / Sensor issues or Exhaust. Oh! I just remembered something! Our trucks rear drive shaft ride on a bearing that sits right behind the transfer case, if that bearing is bad / worn, that would put extreme drag on the power transfer to the rear diff, forcing the engine to have to make more power than it normally would, hence gulping the fuel down. What about your fuel filter under the hood? That's an inexpense replacement item that never hurts to look into and pretty easy to do. If your gas is dirty that's no good.
well that helps a lot to narrow it down at least. Change your pcv valve and get a fuel system service done, spray some cleaner in the MAF, put a bottle of Gunk or something similar and run through the system, and lastly you need that compression check, or ask the tech that did your front end work if they happened to perform one when they were replacing your front seal. Beyond those things it's going to be something periferral, i.e. exhaust, trans / diff fluid / Did someone already say replace your O2 sensor? I need to do that too...what kind of oil are you using? I like Castrol Syntec and Mobile 1 10 w 30, and whatever best quality oil filter Wix or Fram extra tough guard, what ever filters to the highest efficiency percentage and micron. What about your air filter? Get a K&N drop in atleast if you're still using a paper filter, first thing I did when I got my truck.
Sorry, just saw this. What was your mileage prior to having the work done?
Enkryptd what kind of driving do you do, mixed city / hwy? 180 - 190 In my estimation would be all city driving stop and go traffic. Something is definetly wrong there. Manual or auto? Clean MAF? Over drive turned off? Check your brake pads and calipers to make sure the calipers aren't siezed up and dragging. Check ignition timing and head / cylinder compression. If you have low compression the engine is only getting a small percentage of benefit from combustion, which would waste a lot of fuel, which would probably also mean you either had antifreeze in your oil because of a head that is loosing it's seat against the block, or your engine would be using / burning oil because of bad rings and blow-by. Low compression can also result from dirty valves that don't seat properly because of carbon deposits, which amounts to the combustion chamber allowing fuel / air mixture to escape when being compressed in preparation for the power stroke when the spark plug ignites. As for your header installation, it's not mandatory that you change out everything else. The collector just has to be able to bolt up, it doesn't matter what comes after / behind the collector. The exhaust piping could remain totally stock allowing you to replace pieces of your exhaust one at a time, you don't have to do it all at once. You could have a 2 1/4" exhaust collector bolted on to a flange with a reducer on the other side to go back down to stock, and then at some point go in with a 2 1/4" pipeing and high flow cat that again reduces back down to stock on the other side and so on until finally it's 2 1/4" all the way out the back.
Wow, it's really quiet around here lately. I thought I'd share an idea I've just started kicking around a little bit. I'm on a really tight budget right now, as always but I'd like to get a little exhaust work done on my ride. Now, ideally ofcourse I'd love to have newly mandrell bent 2" pipe from a high flow cat all they out the back with a mild sound, high flow muffler. At this time however, I cannot spend the roughly $200 or so that it would cost for that, so I'm thinking of just staying in the current stock pipe diameter and cutting and splicing some new pipe in, cut out whatever that secondary exhaust chamber is (resonator?) between the cat and muffler, and throw in a cheap new muffler, maybe a Thrush turbo muffler or something. Does anyone have any experience pulling off some super cheap cut and splice with U-bolt jobs on their exhaust? Any ideas?
Need help replacing the Vehicle Speed Sensor (VSS)
gv280z replied to shadowork's topic in 90-95 WD21 Pathfinders
Thanks this helps me as well, I've crawled under there like 3 times now looking in the back of the auto trans trying to find the vss, no wonder I couldn't find it! Too bad the OEM costs like $180 for the 31" tires version. -
Need new tires 31x10.50x15 recommendations
gv280z replied to Stifun's topic in 90-95 WD21 Pathfinders
Yes, it will fit, talk to Txpath4x4, he also has an XE that I know he just installed 31s on. He might be able to give you some information. -
I like the look of that Nissan man, I think that thing would be a riot. tough truck http://www.off-road.com/trucks-4x4/tech/project912.html
Yea man, who gives a crap if you've got a Pathy or not, I don't, you're waay beyond that at this point. You know it's not like your going to come wondering in here running game and talking trash like some noob who doesn't even drive yet! Hehe, jeez man. Just because you don't have your Path anymore doesn't mean you just forgot everything you learned while you had it. And besides I bet maybe a year or so from now you're gonna be hard pressed to pass up a good deal you happen to run across on some sweet little virgin 95 WD21 that some old lady is selling. You'll be back. How long do you think you can go before you start eyeing some new trail you've never seen before..hmm? Uh huh..
He wants to do like 11 sec 1/4 mile times it sounds like, I don't really know how far / short / quick the 1/8 mile strip is so for 7 - 8 secs I guess it would be about 2/3rds the distance of 1/4 mile. I'm guessing roughly 0 - 60 in about 5 or 6 seconds. 3 - 5K to spend for that could go any number of a 1000 different ways.
No offense but I don't think you're going to get there using a v6 mustang. You'd have to end up swapping out the motor and basically rebuild the whole car. I would graciously accept that car from your Granddad, clean it up, throw a tune up on it and make it as respectable a commuter as possible and then sell it. From there, it's about what do you like? Are you about classic muscle cars from the 70s, or more modern sports cars. Fuel injection or carburetion, foreign or domestic? I LOVE 70s and 80s Japanese sports cars, they've always held a special place in my heart. The 5MGE inline 6 from Toyota is a radical beast n/a or forced, I love the look of a mark IV supra with the fender flares and mags and fat tires and when you sit inside one of those it's like being in a cockpit of a spaceship or something. Or you've got the shrunken down miniature muscle look of a 75 Toyota Celica GT (I had a 77 ST coupe) fast back with the window louvres and quad headlights and bullet proof 20 / 22 R engines that you can turbo the ever loving crap out of, easily put 10, 12 psi through one of those. And then of course from my own name sake the Datsun 280Z (or controversially ZX which is what I had, loved it) another great inline 6 that made loads of torque and huge fun to drive. Whatever you do, just remember to have fun with it. Good luck!
Oh please God don't let my madness infect you too! Don't listen to me just for my sake, I'm the guy that steers everyone away from extreme modifications. I don't want the entire board jumping down my throat! 30" tires are small and don't look as cool as bigger tires, and if you lift it it's just going to look silly. -
http://www.crawlpedia.com/tire_size_converter.htm check out this website, it does the calculations for you. If your truck came stock with 31" tires then the 265/75/16s should be a close fit that just barely has enough clearance. According to the conversion site, it's 32" x 10.4. I'm currently running 31 / 10.50s and 32" is as much as I would increase for several reasons: Clearance without a lift (I think) tire weight and overall gearing. The larger the tire, the lower your torque because your overall gear ratio is increased so that puts a damper on acceleration and power overall. I know this may sound a bit funny but now that I finally have my 31s (up from 235/75/15s) I'm starting to think I should have just gone to 30" x 9.5 on a good set of M/Ts combined with a simple 2" lift (i know, it's goofy as hell) that truck would be one hell of a functional vehicle. Traction, clearance, lighter weight tire, slightly more torque than average. Come on, who's with me?!? (crickets...)...hello..??? -
Good Lord, I had no idea how lucky I was. Mine works and I ownly play with (use) it occasionally..all this time I guess I kinda took my little popper for granted...
oopss, my mistake..duh. Thanks for the correction guys.
Just bought a 94, have small issues and need help
gv280z replied to Mustangfreak's topic in 90-95 WD21 Pathfinders
I don't understand, the water pump is part of the timing belt KIT! Why would he not have replaced the water pump? Or, atleast I think some of those kits come with the pump..come to think of it, I guess I did have to buy mine separately. I say cut your losses, and take your new engine / timing belt and find a new mechanic! -
Here is a link to a long term road test from car and driver for the dodge dart: http://www.caranddriver.com/reviews/2013-dodge-dart-rallye-14t-manual-long-term-test-review
Well, in regards to the first one I had my response all queued up as to how that french guy climbing the 1700 meter aeriel tower was WAY worse...ahem, until I got to the end of this one and the guy drops down and dangles and then lets go...are you kidding me? WTH????
That little black box is not the data recorder from when you crash...it is however your ECU and is supposed to be under one of the seats. In my 94 it's under the driver, I don't know about the 91. I guess the position doesn't really matter, It could be in your glove box or the center console or screwed to the ceiling. At least that way you'd have to flood the entire vehicle to damage it! The previous owner must have had a really bad ongoing problem, so he relocated it to where he could observe the error code light in real time as he was experiencing whatever was plagueging the truck, and then he'd had quick access to reset it.
Okay, since I posted on this topic, I have atleast now become aware of the MazdaSpeed 3 5 door and 4 door sedan, and I have to say both are GREAT looking cars. I'd be pretty excited at the thought of looking into either one to own. The 5 door is extremely aggressive looking. The 4 door is pretty sharp too but just a bit on the softer side. I still don't know anything about the engines and whatever the hell Sky Active tech is. I am wondering if they're using the same engine in the MazdaSpeed cars as is in the Focus. The only thing that scares me a little about the 5 door is for an adult, anyone over say...28 - 30 years old I think should get the 4 door because I don't think anyone would take you seriously if you pull up driving the 5 door cuz it kinda looks like a tricked out race car that some young 16 - 20 something would drive. Another car I saw the other day that really surprised me, I did a double take actually, was I guess the current gen 5 door Subaru WRX..holy cow that thing looks hot. I think the age demographic problem would still exist to a degree with this one but it's obviously a more expensive car and looks a little more mature.
Do you have the title? Is the guy going to send it to you? If you do have the title, and he signed it over to you then you could let one of those car buyers (IQ Auto buyers in TX) come and give you cash for it, which I'm sure would be near market value. One problem though, you're going to have to pay the registration fee according to the blue book value of the truck. Atleast that's the way it is in TX, too many people were scamming on the whole "Uh, I paid 200 bucks for the car!" bit which ofcourse lowered the registration fee. I know the ones here will buy it even if it's wrecked or broken down, but you gotta have the title.
I just need a schematic to show how the factory foglights are supposed to be wired. I don't know how it happened but mine got all screwed up, where as they used to work. I could turn them off and on with the toggle switch but only when the headlights were turned on. Then I guess when I had my front seal and timing belt replaced the guys had to remove the bumper because and disconnect everything because now the right foglight stays on (if I put the fuse in the link) but goes off when I turn the headlights on, and then the left one comes on! I can't get them both on at the same time and I cannot turn off the right one unless I remove the fuse. Sorry for the thread hijack.
Hey Bluewulf man what about the Legacy? Those are gorgeous..I'd be very happy to own one, it's a mid size and have 4 doors, awd, I'm sure they make a wagon version too. Boxer engine, even if it's not the turbo it's still a monster 2.5 liter boxer with equal torque to hp, that thing would stomp a mudhole in it's rivals.
