edicer2
Everything posted by edicer2
  1. my 300zx did the opposite as your car. I cleaned it and it would bearly idel at 400-600 rpm so it ended up being the idel throttle sensor or whatever. Its the sensor on your throttle body. I replaced it on my zx and it runs great now. I still have my spare off my old pathy ifu want to try that. pm me if interested.
  2. I have a MAF off my 93 if u rather buy that? PM me
  3. could it be sqeaky struts/shocks or something of that nature? also check your brakes like he said
  4. I have one of these on my truck looks realy nice! http://www.truckcustomizers.com/images/pro.../K5FLW311.2.jpg pictures of mine are here just scoll down(mines stainless steal looks shiny but in the pictures its really dirty) 2.25" to 3.5" http://www.nissanpathfinders.net/forum/index.php?showtopic=20369
  5. what do these relays look like i might have some from my old pathy yet idk if i yanked them out yet.
  6. i had 32" tires on my pathy but it rubbed a little bit when i hit bumps and when i had to flex alot or go in reverse. drivng normal it was ok. I only have a 1 inch lift though. if u had a 3 in lift you would have no problems
  7. the stock amps will help you turn it up louder but it sounds like crap its best to just go around them thats whati did. I mounted my amps behind my rear seat. same with my cap. you cant see them unless you move the sub box out of the way. IDK if i would put it in the side of the truck because that way it can overheat fi not cooled properly like stated and if you pop a fusei can be a pain to fix
  8. my thoughts exactly. It will take a little time to snake some speaker wire to the doors and rear but its worth it IMO
  9. I hate using the factory amps. I always get a over amplifiyed noise when i use them. If you have a decent deck or one made in the last like 10 years lol it will probably put out around 50 watts a speaker which is plenty. All you need to do is run your own indiviudal wires to your speakers and you will be good to go plusi think it will sounds betteR!
  10. ok sounds good its been here for 6 months so i dont see it going anywhere lol let me know Gl on the insurence
  11. ill sell you mine for my 93 se 5 speed if it will work in it for 40 bucks plus shipping
  12. I was able to just get that part off of a used cable i had i have another one if u need it MAXRX7. But yeah it was defiantly the starter. I brought it in the store and it was junk. It was only 100 bucks for a new one so it wasnt that bad.but now I am getting new tie rod ends for the front of the pathy so i can get it alinged my z needs new ball joints too
  13. my guesss is the switch is broke. its pretty easy to get out. Other with more knowlegde will chime in though. I have a switch if u want to buy one. It came off my 93 i parted out. But get a few others opinions first. Or you can clean your current switch. They tend to get build up on the contacts and it malfuctions. I know there isa how to on here somewhere.
  14. This happened to my pathy last week i had to replace the starter. What you can also check are the relays under the hood. but im pretty sure if u said the battery is fully charged and its still doing it then its the starter. try to hit it with a hammer it might help
  15. werid i was able to get mine out easy in my 93 for when i parted it out. squirt some wd40 on it or something
  16. thanks man! BTW i just got my hid kit installed in it. but yours is really new ha mine has like 160k miles on it. My goal is to get a turboed motor for it someday
  17. i can see alot farther with my white ones then i could with my stock yellow ones. Actual bright yellow bulbs are illegal where i live so its just stock bulbs or silver stars or hid kit
  18. yeah for sure it definatly looks alot better! I hated the nastey yellow the stock bulbs put out
  19. i bought some of those super bright white leds off of superbrightleds.com and they look sweet in the clear corners i bought ill get pictures. im getting a hid kit soon i think also i ordered one for the z ill see how i like it should be in tomorrow! i currently am using silver star bulbs in both cars
  20. that same @!*% happened to my 93 pathy and i ended up parting it out becasue the body was junk. it was only 200 bucks for a new motr with 120k on it but the body was so show on the frame it wasnt worth fixing other wise i would have. good luck just buy a new motor and it should be good to go it sohould cost to much to do it.
  21. maybe you have a short in your ignition or something. does it shut off whenu hit bumps?
  22. nope i have a ecu for a 93 but its for a manual
  23. hows the paint going? the rustoleum products are really good! i used that t opaint my rocker panel on my old truck on top of some bed linder and it never rusted, faded, or pealed! great stuff!
  24. pretty sure from 86-89 was 2 door and 90+ are 4 door
