Everything posted by William
B. Why do you need a TAP for? Are you re-threading?
I'll take care of it. James is right. 10 people were needed to get the headers manufactured again. I reckon we will need less to close a GB deal with JWT. I'll check and let you all know.
Great the Group Buy list is growing: 1. BikerJared 2. William 3. RustFlames William
+1 to that
Let me know when you decide to place your order. I'll probably join you as well and maybe BEN could give us both a better discount PM when ready in the future. William
Hi Precise1, Heard over at infamousnissan.com that you received your custom 3-gauge Pod. How did hang? How does it look. I am also interested but would like to see a picture of it hanging first. I also heard that it is not a "clip-on" but rather a "screw-on" type. Did you manage to close the gap somehow? William
Hi BikerJared, I am in for the Group Buy. Anytime I'd leave the ECU upgrade until after I swap my VG30E for the VG33E to avoid having to re-map the ECU again (do it once only) I am also interested in the CAMs. However, I am more inclined into the S1 CAMs. I heard they provide a better smoother idle. Whereas, The S2 CAMs are a bot rough at idle and give a bit of "Lope". Also, the S1 uses the factory springs and saves you $129 William
Hi B, Any luck with the used Hose measurement? I'm kinda waiting on your feedback before placing my order for the Water Temperature Adapter William
Well my next steps are CAMS as well from JWT How about we try to organize a GROUP BUY on NPORA. I reckon many are interested in more power. I know the salesman at JWT and can give him a call and organize this GROUP BUY. We could be talking discounts between 10-20% depending on the number of participants. What do you all think?
But B ... You stated above that the OD of your Radiator output is 1.375" (34.93mm) shouldn't this match up with the ID of the Radiator Hose reported on rockauto.com being 1.25" (31.75) Does that make sense to you? William
B. like ahardb0dy said, RockAuto.com lists all the upper hose models (different manufacturers) as 1 1/4" ID. Example: GATES Part # 25251 Flexible Coolant Hose (Standard) Upper; 1 1/4" x 13" What do you think? William
While on the same subject. I came across this T-PIECE OIL PRESSURE AND TEMPERATURE SENDER ADAPTOR on eBay: http://www.ebay.com/...=item3f1c9898c3 It has 1 input and 3 Output ports (each is 1/8 NPT thread). It mounts right on the engine block in place of stock sensor position and allows to mount the stock sensor + my two aftermarket Pressure and Temperature sensors. All in one unit. What do you think? William
B, You mentioned having an old WD21 radiator with hoses in your backyard. Can you kindly check the ID/OD or the Upper Hose. It seems everyone is convinced that tapping the upper radiator hose with the temperature sensor should give the most accurate reading. According to ahardb0dy, www.rockauto.com lists the upper hose for the WD21 as a 1.25" or 31.75 mm diameter hose. It will be good to verify that information prior buying the temperature adapter. Thanks in advance William
I did suffer from a bit of "rough idling and dying" myself after I removed my stock Air Filter and replaced it with a "Pop Charger Air Filter" by Weapon-R. After a while, I guess the ECU adjusted itself and now the car drives well with no issues. Is getting a CEL error normal after a DT Header Install?
Thank you for the Hint and the Link Do you know which one these WATER TEMPERATURE ADAPTERS fit our Pathfinders? NS-2050R NISsport Water Temperature Adapter for SE-R/NX/Sentra B13-15 NS-2050Q NISsport Water Temperature Adapter for B15 SE-R, Spec V, Altima NS-2050S NISsport Water Temperature Adapter for 240SX NS-2050X NISsport Water Temperature Adapter for 300ZX, Maxima NS-2050Z NISsport Water Temperature Adapter for 280Z, 280ZX NS-2050G NISsport Water Temperature Adapter (1 3/8) NS-2050S NISsport Water Temperature Adapter for Mitsubishi NS-2050U NISsport Water Temperature Adapter (1 3/8) William
Hi Rob. Do you still have one of these in stock? William
Thx again I am not sure. Where do you think it fits best? Safest? Upper-side or Lower-side of the Radiator! I will need to route the cable through the Firewall inside the cabin into the gauge mounted on the driver-side A-Pillar or central dash (haven't decided yet as I will have 6 of these digital gauges to distribute inside the cabin). William
Thx B, Do you know by any chance the ID of the OEM Radiator Water hose that I can tap into? William
Hi Guys, I recently purchased 3 Digital Gauges from Innovative Motorsports: 1. Oil Pressure/Temperature (Engine Oil) 2. Oil Pressure/Temperature (Transmission Oil) 3. Water Temperature/Battery (Coolant / Radiator) I looked up on eBay and found these Aluminum Temperature Sensor Gauge Adapters: However, these adapters come in few diameter sizes: 28mm, 32mm, 34mm, 36mm, 38mm, and 40mm Unfortunately, I don't have my car with me at the moment and was wondering what is the correct diameter size for these adapters to use for each of the Innovative Motorsports gauges above (Water Temp, Engine Oil Temp, Transmission Oil Temp)? William
Can you post some pictures please showing what you did? I am quite interested in this small project. William
My New Doug Thorley Headers (Clamp Size)
William replied to William's topic in 90-95 WD21 Pathfinders
Does anyone know what is it for? William -
Dennis, I am confused. If I swap my engine to a VG33E which uses 10mm studs and use these DT headers. Why do I even need the old VG30E Exhaust Manifolds? William -
Thanks B. Does that mean that if I swap my engine for a VG33E, I won't need to "widen" the header stud holes from 8mm to 10mm anymore since they are already 10mm? William -
Last question about those headers I am aware that the DT THY-464-2-C headers for the VG30E need the standard 8mm Studs. (which I already got from Alkorahil as follows: Part # Description Qty 14065-V5004 STUD-MANIFOLD 12 14037-V5005 WASHER-LOCK 12 14039-W1500 NUT 12 However, upon measuring the diameter of the holes on my new headers, they came to be 10mm (which I believe is the size recommended for the VG33E and not the VG30E). Does that make sense to you or am I wrong somehow? William -
Another question about the same headers. Should I just slide the 2 pipes that connect the EXTENSION PIPE with the Y COLLECTOR, Weld them or put a CLAMP around them to make sure they do not separate? I am slightly inclined towards the CLAMP. Do you happen to know the diameter of these 2 pipes? William
