Everything posted by William
Hi. Well .... my Doug Thorley headers recently arrived (Thanks to Steevo). Everything looks Ok and ready for the install. However, I was puzzled by a small "round cylinder-shape" part that came in the same bag along with the Bolts and Nuts. Does anyone know what is it for? William
What is that Website's URL link please?
How did you come up with 5.21 please? William
I agree. However, I used the following site for the calculation. It is not a commercially available wheel size but probably the exact metric size ..... "mathematically" speaking: http://www.extremeterrain.com/wrangler-jeep-metric-tire-conversion-calculator.html
Yes. Will stick with the 33" as this is also my DD and I don't want to go higher than 33". William
Oops. You are right. Sorry.I used the sample given below the formula on the URL and left the wheel diameter at 17 . Thx
Hummm ... I am currently running 33x12.5r15 (which means in METRIC: 318x72R15) So according to the formula below that calculates my overall tire diameter, I have a 35"? (CROSS SECTION WIDTH x 0.ASPECT RATIO x 2 ÷ 25.4) + WHEEL DIAMETER = OVERALL TIRE DIAMETER (318 x 0.72 x 2 / 25.4) + 17 = 35" Does that mean I need 4.56 Gears to return to NORMAL OEM? William
Well actually mine came with 215x75R15 (not even 235's )!! The driver door TAG is below. Does that mean I need I need something higher than 5.13?? William
Hi Guys. I am currently running 33x12.5R15" BFG tires on a 15x10 MT with the correct backspacing. My truck is a V6 A/T with 3" BL + 3" SL from AC (4x4Parts.com) I will be SASing the front of my truck in the near future. Still researching the best AXLE to use considering that Dana44 from old Wagoneers are not common in my area. My current differential Gears are still factory (HG43) which I believe stand for 4.365 Rear (H233B) and Front (R200A). Not sure about the Front and Rear Spline count but can safely assume they are 31 Rear and 29 Front. Q: Which Ring and Pinion should I shoot for? 5.13? Q: What is the difference and how can calculate the one needed to return to factory settings considering that I running 33" tires now. William
wd21 sas, what axle options ?
William replied to Stinka's topic in Solid Axle Swaps, Hardcore Custom Fab
Hi Pete, What about the LENGTH of the Patrol Y60 axles (Front and Rear) that you used for this conversion? Are they the same as the ones on the Pathfinder WD21 or will I need to shorten them? I believe the H233B length on the pathfinder is about 59" in length. William -
Hi Guys. went through that post today and I had a question please since I am endeavoring the following 3 projects: 1. SASing the front of my '92 WD21 (HG43) 2. Upgrading my rear H233B axle Drum Brakes to Disk Brakes 3. Installing new NISMO 5.13 Ring and Pinion in the front and rear. I am currently running 33x12.5R15" BFG tires on a 15x10 MT with the correct backspacing. My truck is an V6 A/T with 3" BL + 3" SL from AC (4x4Parts.com) It is quite difficult for me to source D44 axles off a Jeep Wagoneer as none exist in the JY around my area. I figured I keep all Nissan and go for the following Axles from a Nissan Patrol Y60 (GQ/GR) instead for the above 3 upgrade projects: Front: H233B, 32 (1.26”), 31 Spline Rear : H233B with rear disc brakes, 33.3 (1.31”), 33 Spline What do you think? Will that work? William -
Hi guys, Recently took off my manual mirror and put on the nice-looking Power Mirrors instead. I also acquired the in-cabin joystick/remote control for these Power Mirrors. The problem is that my Pathy did not come pre-wired for this kind of setup and I am not sure how to connect the mirrors harness (on each side) to the joystick/remote control? I tried looking for these harness/cables in the local junkyard or online with no luck Pictures: Joystick/Remote Control Harness Mirror Cable: Any help is appreciated William
Hi Guys, Just came across this on the WHITELINE website. It is for the rear end of a NISSAN PATROL. Noticed the sentence above: "Front & Center Bushes available in both Standard & Offset for Caster Adjustment. A Must for raised suspension" Does this apply to WD21? William
Where did you order it from? William
Silverton, Can I add you to the list? Which kit do you need: NP12452 or NP12451? Are you interested in NP12633 as well? William
If any of you is worried about spare parts for this kit: 1. The custom idler Arm Bushings are available from www.bandit4x4.com. No need to worry about those. 2. The custom Calmini TREs and Adjusters are available on www.calmini.com as follows: NPES409R $24.95 NPES4044L $29.95 NP12460 $64.95 William
Fair enough Silverton. #2 or #20 are the same. If we do not fill the whole list, the opportunity is gone. I'll go ahead and add you. Which kit you need: NP12452 or NP12451? Are you interested in NP12633 as well? William
Pulleys for VG30E accessories on a VG33E engine
William replied to Dizer92Pathfinder's topic in 90-95 WD21 Pathfinders
Mr.510, Do you have a picture of this adapter Hub? and how it fits on the Crank Pulley? William -
This is the Calmini HD Steering system upgrade!! Aren't you guys interested? William
If interested, place you name in the list below and indicate which version you are interested in (NP12451 or NP12452) and whether you are also interested in the Rear Track Bracket as well or not (NP12633). Note: NP12451 is for the pre 1991 WD21 steering boxes with the Small Tapper/Nut size < 41mm (I believe 30mm!). NP12452 is for the 1991+ WD21 steering boxes with the Large Tapper/Nut size = 41mm #1 William (NP12452 + NP12633) #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15 #16 #17 #18 #19 #20
Dear All, After several rounds of discussions with CALMINI (USA), I managed to cook the following GROUP BUY deal: 15% OFF the following parts for 20 (or more) confirmed orders of each: NP12451/NP12452 CALMINI HEAVY DUTY REPLACEMENT STEERING SYSTEM $629.95 (reduced down to $535) or NP12633 REAR TRACK BRACKET $75.95 (reduced down to $64.5) (This bracket is only suitable for WD21 equipped with a 3" Body Lift) Note: The brass Idler Arm bushings can be replaced in the future if need be and are available at www.4x4bandit.com To make use of this once in a lifetime Calmini GROUP BUY, simply fill your name in the list below and indicate which part you are interested in. We will need 20 confirmed orders of each to get the 15% discount on both (i.e, 20 confirmed orders of NP12451 will get us the 15% off on the NP12451 only not the NP12633 which needs its own 20 list of 20 confirmed orders). Once the list is complete, each buyer will need to get in touch with David Kampa at CALMNINI USA and provide him with his/her credit card and shipping details. David will only "Authorize" your cards for the discounted price and wait until all 20 confirmed buyers have done the same before fully charging your cards, sending you the invoices along with the shipment tracking details: David Kampa CALMINI Products Mfg. Inc. Sales Department P: 800.345.3305 T: 661.398.9500 F: 661.398.9555 www.calmini.com As I said, this is a once in-a-lifetime kind-of-a-deal. This steering kit doesn't get discounted at all and the best time to get them would be now! If you are in doubt, please read the following Project Pathfinder (Part 12) article that explains the advantages of this Kit as opposed to other after-market steering enhancements: http://www.motoiq.co...cleid/1299.aspx Good Luck to us all William
Any feedback please?
The Pitman Arm is the one in Green in the attached picture. Is the 41mm Nut the one highlighted in RED at the bottom of the Steering Gear? William
I'll get in touch with them and offer them this GROUP BUY and hopefully they agree. Will keep you all posted. I don't need a new PITMAN ARM, I need to upgrade my weak Steering system and the 2 ways to do that are either: - Calmini HD Steering Package (which includes a Pitman Arm) - Hoohaa's Center Link I personally don't believe in Hoohaa's CL upgrade and prefer the Calmini HD SP. William
No need to approach CALMINI directly for the Idler Arm Bushing. Go to the following link: Bandit4x4 and order part# BDT-0003 (which is made exclusively for the Calmini Heavy Duty Steering System) for $55 and your buddy will be a happy wheeler again William
