devonianwalk
Everything posted by devonianwalk
  1. Sounds like your set. Please post pics of the install man!
  2. R50's have struts in the front. We are wanna' be trucks, hence "caR50". Great advice on going with the rear suspension lift. It may look a little goofy but, it has to be way safer than the molested rear suspension that is on the rig right now.
  3. About as much as an early '90's model Chevrolet Astro van ... "all wheel drive" of course.
  4. Yeah, someone posted some pics of a very nice looking lifted Black R51 about a year ago. What ever happened to him/her?
  5. You know, the timing belt will whine win it is new. I hate to have experience with this subject.
  6. Interesting. Owning a 1999.5 model I always tell parts stores that I need "x" part for a '00 Pathfinder. I have yet to find one that didn't fit to my old '99 (including the radiator I just installed last weekend).
  7. Deff only the rears. Disk breaks don't need adjusting like drum brakes.
  8. They look like they are high quality. I can't tell from the photo if the bolts are grade 8 but, probably what you would want to use. Curious, why would you need to change the engine mounts on such a new vehicle?
  9. I don't know man. The whole reason I lifted my ride was due to a worn out suspension ("saggy ass" if you will?)
  10. Xplor is right. It almost looks like those springs were intentionally heated to make them fit her Pathy. I'll venture to bet that the ride is some what "springy" in the rear? I've seen similar results when kids heat the springs on Hondas to lower the ride height. Not very safe!
  11. Something is deffinatly not right. Both sides look like that?
  12. I can't seem to find the air relief plug on mine? Here, maybe a close-up will help!
  13. Too funny! I wouldn't think that it would present a problem if you put the screen on the air box. I would be more concerned about which type of screen to use to insure that the little suckers don't chew through it.
  14. Yes, it is a weak little spring wire clamp that you can remove by pinching it with your fingers. Burgandy has an excellent idea!
  15. This seems odd to me. I have had my radiator off at least three time this year and not once did I have any air bubbles in my cooling system. It is possible that you may have a clog somewhere in your radiator or heater core. This would explain why you can hear the "whooshing" sound under your dash.
  16. Odd? A broken/cracked windshield is replaced for free in South Carolina by the owners insurance company. I think that it is some sort of state law? I've had three replaced on prior vehicles and I don't have a clue on how long it took them as they came to my residence once, and my work place the other two times.
  17. First issue) +1 with not using the belt dressing. I used a cheap bar of soap that worked pretty well but, eventually changed all my drive belts. Second issue) It is more than likely your exhaust heat sheilds. That sounds like the usual symptoms any way. The next thing you will notice will be hearing a rattle while sitting in a drive-thru or at a red light. It is safe to pull them off (at least I haven't gone up in flames yet!)
  18. You may want to post this in the 86.5-89 WD21 section. This is the R50 thread.
