Timmons
Everything posted by Timmons
Guys, looking for new rear shocks. For you SFD guys, what are your thoughts on these specs. Ford F-250 / 2000 Rancho RS9000XL Adjustable RS999254 Compressed Length 18.52" Extended Length 30:51" Travel 11.99" Finally rolling with 285's and ready for a shock upgrade. The 285's were much more gas friendly then the 315's ouch.
Here is what my lift looked like after installing Krypton Fabrications SFD Lift. With the new springs, I now have a 6 1/2 inch lift. Totally worth it and makes the Pathy look tough.
Possible? Alternative parts Aiding in our Lifts?
Timmons replied to borninabarn's topic in 96-2004 R50 Pathfinders
You guys will want to check out this website for a 4" lift. If you include the AC 2" springs in the struts and longer springs in the rear, you can get a 6.5" lift from the kit. http://www.krfabs.com/product_detail.php?productID=2 -
Had the same problem before, it was the entire distributor. You could see a small black area on to where it was arching to the body. Another thing i had to replace was the positive connector to the battery. Removed those crappy terminals, cleaned up the wires and installed nice connector J-Block that had two openings that I could install the two smaller gauge wires. Worked like a charm. Good Luck on the distributor. Hopefully that has resolved the issue.
Wow! Those look great. What rear shocks did you finally go with? I want to change out my 32's now.
The CV's are easy to change and will cost you about $70-$90 new, buy Warn hubs and you will not get the wear on the CV boots. Everything else you listed, I have changed myself and you can to with a little work and buying parts online. 150k miles on a 97 is low mileage for a VG33. I have almost 200K on my 98 and it still runs great. That engine and trans is very robust. Just keep up on the maintenance like oil changes etc.
Official Staangs fab install R50 SAS
Timmons replied to PaMountianbiker's topic in 96-2004 R50 Pathfinders
Wow! That is amazing looking!! -
Wow PAMountainbiker, 37's!! I guess no guts no glory. Good luck on that SAS. I have another ride with the Jeep club out here in New Mexico tomorrow, going to climb some large hills. What are you guys using now for your rear shocks on the 6.5" SFD? I need to replace mine again. LOL.
What are you guys using on the 6.5" SFD lift for rear shocks now?
Welcome to the forum.
Did you ever install the WARN HUB lockers? That will really help.
Dududckling, can you show me a picture of your Pathy with the rim & tire setup? Still looking at the Pro Comp Rock Crawlers 16x8 but with the 285/75/16 BFG AT KO.
So since were on this subject now. LOL. What is the preload torque? Then how much do you back it off guys? I did mine to a few weeks ago and didn't do it correctly.
You won't have to worry about any torsion bars in an R50. If this is going to be your DD and your not worried about a rougher ride, go with the AC 2" lift from WWW.4x4PARTS.COM. Go with the KYB-GR2 for struts in the front and Bilstens for rear shocks. https://www.4x4parts.com/nissan/pathfinder-suspension-package-p-1959.html
I started with the AC 2" lift and quickly got bored. Check out this website for a sub frame drop. http://www.krfabs.com/product_detail.php?productID=2
Then I should be ok running 285/75/16 on a 16x8 rim with 3.75 BS and will clear the strut without having to add adapters. Any idea if you can get those rock crawlers hub centric instead of lug centric?
Rick, did you have to add and spacers or was the back space enough on those rims? maybe a 16x10 would be better 3.75 BS??
Who's running these Pro Comp Extreme Rock Crawlers? Checking on a new set of rims and tires after the SFD. Is this a good combination, no rub, no rub on the struts and no spacers or adapters. 16x8 w 3.75 BS (Pro Comp Extreme Rock Crawlers. BF Goodrich A/T KO 285/75/16 Tires (32.8") SFD 6.5" lift
I installed the link two years ago, works great. Noticeable difference on corners and off-road.
Silvapathy, what rear shocks are you running? Compressed, extended? I need to buy new ones LOL.
Man, that's a relief. NICE!! Good Find.
It's the ECU
