45
ahardb0dy last won the day on October 10 2025
ahardb0dy had the most liked content!
About ahardb0dy
- Birthday 11/24/1965
sold
46+
Do Not Go Off-Road
1994
Gender
Sorrento, Florida
Country
Interests
Nissan's, boomboxes Aiwa especially, CB & ham radio, collect knives
23,998 profile views
ahardb0dy's Achievements
NPORA Old-Timer (5/5)
393
What ever engine has the clear tubing
I would suggest getting rid of that clear tubing, possibly the vacuum is sucking it closed, you need to be using vacuum lines.
Found out last night, that the photo hosting site I use, Tinypic is shutting down, so I'm sure any and all pics I have posted will be disappearing. I'm going to save all the pics before it shuts down, I should have most if not all of them but want to save them just in case I don't.
- 1 reply
- 2
Just a heads up, I just bought a used column cover from a member on another forum and went to install it and came across a problem, not his fault, I never even knew there was a difference in the top covers, this probably wouldn't be an issue on the Pathfinder a most probably came with tilt steering, just wanted to share what I found. pic below is the stock cover from my 93, non tilt that I modified to fit the tilt column, you can see the opening for the ignition cylinder is towards the rear. New/used tilt column cover from a 90 Pathfinder, you can see the opening for the ignition cylinder is towards the front: I also noticed the bottom cover from the 90 Pathfinder is not as deep as the one from my 93, but the bottom cover would have worked, I just had to move all the wires to the right side
My former 87 Hardbody never passed emission tests on it's own, with full emissions, cat and everything. I heard way back, not sure if it was true that Nissan rushed the VG30i into production and is why they had emission problems ??
Where to purchase torsion bars and strut rods?
ahardb0dy replied to Bdoe's topic in 90-95 WD21 Pathfinders
Compression/strut rods are dealer or junkyard only, Torsion bars I would recommend Sway A Way -
I worked in a 4x4 shop back in the best times for the Nissan trucks, 87 -90 ish, We installed many visors and all were made by Lund. Not saying there wasn't another company out there but I do not recall one off hand. There was a company that made them out of metal that were shaped differently than the Lund visor. I have a very old Jobber price book from one of the warehouse's who we got our parts from, I'll look through it and see if I can find another company.
Does the AC clutch engage when you turn the AC on? May just be low on freon.
VG30 to VG33 SWAP, Step by Step Starting Today 8/26/17
ahardb0dy replied to OH6PILOT's topic in 90-95 WD21 Pathfinders
Very nice step by step with the pictures ! I guess you have a body lift as the upper radiator brackets are upside down, did the same on my former 87 Hardbody with the body lift. A member on Infamous forum is swapping a VG33 into his Hardbody and discovered most of the JDM VG33's that are for sale have the alternator on the pass. side, he wanted to keep his on the drivers side, where it is on the VG30, but he found the oil filter bracket was too thick and it would not allow the alternator to clear , so he replaced the oil filter mount with one from a frontier, it is thinner and allows the alternator to bolt up and clear. A tip when removing the hood and getting it to re align is to drill a hole through the mount into the hood on each mount, than when reinstalling use a drill bit to line up the hole in the mount into the hole in the hood, once the drill bit is through both holes you know it is in the same location it was before being removed. -
He said he figured it out and it no longer has a misfire. He said he pulled the TB and the gasket was all tore up
he said he doesn't remember what the old plug looked like. He also posted a video of doing the compression test on #5 cylinder. I told him to get a new gauge because there is no way the reading he is getting is correct, he is showing 210 PSI, The service manual shows a new engine should be at 173 PSI.
he said he pulled the valve cover today and everything is moving the way it should.
Weird that the plug has spark when pulled and held next to the engine but doesn't effect the idle when the plug wire is removed from the plug while running
No
