adamzan
Moderator
Everything posted by adamzan
  1. Bad/defective part? What brand did you use? I just replaced mine after an ntk sensor lasted only 4 months. Bought it well over a year ago so no warranty. I replaced it with a bosch like factory.
  2. I have never seen any pathy with anything but a 21 gallon tank. I easily fit 75+ liters in mine after riding on empty dorfor days.
  3. It should read anywhere from 13-14+ volts depending on what you have on. Nothing higher than 15 though. Mine currently dips down below 12 at idle with the rear defrost on. I'm going to swap it with the one from my parts truck so I can warranty replace this one. (again...)
  4. Best bet is find a good used cluster. You can swap the individual gauges to keep your mileage.
  5. You must have a rust hole in the quarter panel. That's what happened to mine on my old 95. Luckily my 94 has no rust holes at all so its nice and dry inside.
  6. May want to look into the coolant temperature sensor as well if the o2 doesn't help. They're not too expensive either.
  7. Right now I am lucky to get 400km out of 70 something litres... Also the one in mine was an ntk. That i put in in the fall. I am going to get a bosch one this time. That's what was oem.
  8. The o2 will definitely cause @!*% mileage though. Mine is brutal right now.
  9. checked the codes. in the old pathys you don't need a scanner.
  10. Driving home tonight I got a CEL. Checked it in the tims parking lot and found my o2 is dead...Yay no wonder I've been getting 350k to a tank.
  11. Sadly I see the tanker trucks crossing from here to fill stations in ny. So I buy our gas cheaper over there lol.
  12. http://www.nissanpathfinders.net/forum/topic/4945-headlights-performing-poorly/ http://www.danielsternlighting.com/tech/relays/relays.html fskc HID lights. They all look blue, and blind everyone. Every oncoming car that clearly has them I just leave my brights on. I have the relay mod done and I have a good set of halogen bulbs. I can see perfectly.
  13. I don't see why you couldn't. People swap in the vg33 into the wd21 all the time. I probably wouldn't want to though. Less power.
  14. I have one of those solar panels that you get at most camping and car stores. It keeps my battery topped up when i use my electric cooler. Seems to work well
  15. Who cares if the the axle housing rusts. The important spots are the strut tower area and the a pillar. Did you never think to have it oil sprayed this entire time? I see 15 year old pathys that still look new because they were rust proofed.
  16. You need to find someone who can scan abs codes. the dealer can do this.
  17. Find someone with a good scanner, they can read the codes. My parents maxima had the same issue and it was an abs wheel sensor.
