LD50
Everything posted by LD50
  1. Consider yourself lucky... they charged me $197 to ship to Alberta
  2. Wheels with 4" of backspacing are probably the best choice as far as fit. They will also reduce the wear and tear on your steering components. You can get Cragar Soft 8's from summit for $36 each and free shipping in the USA. Thats where I got mine, and I like them! edit -- looks like the price went up $2 http://store.summitracing.com/partdetail.a...15&autoview=sku
  3. I have yet to decide where the other one will go... might be cool above my glove box. Here's where i put one
  4. I got mine before synic disappeared. I would probably buy another (ESPECIALLY from a fellow Canadian)
  5. Mine jumps all over an eventually stays at 9000rpm after i drive for a while. i have an after market tach I'm going to install shortly to remedy the situation
  6. LD50
    Parts
    What sort of materials? billet shift knobs are cool (not the ricer variety though)
  7. I hate searching for those elusive bolts Good thing it's warm out, I may just head to the J/Y on Saturday! Thanks for the specs
  8. For the life of me, I can not find the correct bolts to get a tow hook bolted to the frame on the drivers side. Anyone have the specs??
  9. you dont need anything specific, pick a muffler, pipe size and cat of your choice and tell them to install it!
  10. I like mine 2.25" pipe, Flowmaster 40, no cat I also have a cone intake so it makes it sound cool too.. Listen here: Exhast clip
  11. Hi-jack time :furious: Anyone know off hand how many turns of the T-bar adjuster will lift my front 1" or so? (I want to level it out before i get my tires installed.) /end hijack
  12. I don't have much experience with working on vehicles. Ive taken my quad apart and put it back together a few times, I guess that helps somewhat. The body lift is the most extensive mod or project I've done to the pathfinder and it went quite well. As long as you follow directions, do some research and take your time you can install your own BL.
  13. heres mine before/after with 29's before after
  14. I'm pretty sure the only thing AC does is add the correct bolts, the kits are otherwise the same between the 2 pathfinder kits
  15. It should work just fine then
  16. You'll spend $20 on the bolts anyways, if you can even find the right ones.
  17. I got my BL from AC ( 4x4parts.com) they add the correct bolts, since performance accessories does not make a kit with the correct rear body bolts for the newer (90-95?) pathy's. It's a good, complete kit.
  18. I also need to add more lights. Instead of the roof, I'm going to put them next to the wipers - mounted on the panel between the windshield and hood. Another idea to think about.
  19. Does this diagram make sense for what needs to be done with our pathfinders?
  20. Yeah, I didn't realize the cap pooped up like that, a few minutes in the cold and I figured it out pretty quick.
  21. So does the rivet need to be drilled out of the cover as well? Or perhaps I am misunderstanding Edit-- Went and checked it out, I get it now. Thanks guys
  22. Flowmaster Super40 No cat, 2.25" pipe.
  23. I want to access the panel between the windshield and hood, but can't figure out how to get the wipers off... is the spring holding them on or is there something else to remove?
  24. LD50
    Bumper bolts
    few inches lower and back. should be just after where the panel with the elongated hole ends.... if that made sense.
