Tungsten
Everything posted by Tungsten
  1. Do you know what it is called? My Home(less) Depot doesn't have ANYTHING. If I know what the name of the product is at least I can do a search.
  2. Well I really don't know much about the manual but if I remember correctly, they did have some problems with gear whine and all that. The automatic one however will probably take up to 210 hp tops, and thats the medium duty RE4R01A. I don't think the 3.5L has the same transmission, the redline of that engine is 6500 rpm. Here is a good link: http://en.wikipedia.org/wiki/Jatco_4R01_transmission
  3. Even better! Keeps those pesky guests from ruining the floor.
  4. Unless you want to have some fun on a closed circuit...
  5. I'm probably going to get beaten with a stick for this but here it goes... Rip the entire carpet out and Line-X it! Then just add some rubber mats on the top for looks.
  6. BTW I don't know if this has been said before but... You guys do know if you do anything to change the power output of your engine, the AUTO transmission WILL SLIP and the manual may blow up sooner.
  7. Just got it today, I think its going to exit more to the back instead of to the side, I am planning to cut that last whole bend off.
  8. http://www.nissanpathfinders.net/forum/index.php?showtopic=21 ECM = Engine Control Module Looks like your ECU is toast... At least its an easy fix.
  9. I have a custom exhaust and a stock tailpipe from NAPA and thats how it came out. This is the tip I got: http://www.amazon.com/Superior-28-6202-Stainless-Steel-Exhaust/dp/B000CPAW2O/ref=sr_1_4?ie=UTF8&s=automotive&qid=1266096034&sr=1-4
  10. i decided to go for clampy partly because its easier to clean it
  11. Yeah I hate how it exits to the side... If I was to get a tip should I get a clamping one or a weld-on?
  12. maybe cutting it off before the first wrinkle and adding something like this http://www.summitracing.com/parts/FLO-15360/ or this http://www.summitracing.com/parts/JEX-JAC200/ welding and tips may not go together well so i could get a clamping one http://www.summitracing.com/parts/PLT-PM582/?rtype=10
  13. This is how my new tailpipe looks: Its a 2 inch pipe and it doesn't look very nice does it? I was thinking of either angle cutting it or just cutting it and putting a nice tip on it. I don't want to go to Autozone or Advance Auto Parts for one because chances are the chrome on them will be gone in a few weeks. Can anyone recommend something nice?
  14. actually that gray color looks like crap anyone got any good ideas for other materials? i was thinking redoing them in black leather but idk
  15. I think it does have to do with the fuel pump building up pressure. I know my fuel sender gasket has a slight leak in it so the truck stumbles on cold starts. I bought a new gasket from the dealer but its going to have to get warmer out first before I replace it.
  16. http://www.nissanforums.com/truck-suv/46725-v8-swap-88-nissan-pickup-2.html nuff said.
  17. yea bleed it and make sure you have some pad left over otherwise you are looking at new rotors or possibly even new calipers
  18. you can start with a cat-back exhaust don't do any chip mods
  19. Yeah it stumbles and fumbles and then its good.
  20. if you have an aftermarket master brake cylinder theres your problem make sure you got a real Nissan one
