Everything posted by exit34rocker1017
Went wheeling again today.... PICS/VIDEOS
exit34rocker1017 replied to muddfildvaynes's topic in 96-2004 R50 Pathfinders
thank god for swampers -
Best place online to get factory Nissan parts?
exit34rocker1017 replied to snow4me's topic in 96-2004 R50 Pathfinders
http://www.nissanpathfinders.net/forum/index.php?showtopic=18653 -
What about rear drum brakes? Anyone know if there are any upgrades from OEM? Or if we should stick with OEM for rear brakes.
What have people done with fender flares///
Pacer Flares -
Stock fog lights for sale
If you don't sell, maybe you should consider dropping the price. I got two craigslist fog lights for $40 -
I dont think 3.75 will rub the strut. Tyler and new4x4r both said they ran 3.75 backspacing and they had 12.5 wide tires.
When I was going to do a SFD, I was going to get these shocks. They were the same kind I have on my truck now, just with more travel.
I like you. Keep us updated.
I did not take pictures of the process. What is it exactly that you want pictures of?
I thought there was a way of doing this without enlarging the holes?
Does your R50 have a 5 speed
exit34rocker1017 replied to SilverPath's topic in 96-2004 R50 Pathfinders
I thought you couldn't regear with our trucks cause no one makes front matching gears? -
Advanced search "Rear Bumper" and check the show titles only box and also filter the results to 96-2004 R50 Pathfinders. That is what I did when I was searching for ideas and tons of them came up
Bumper finally finished
Put it on -
If it's just a resonator whats the point of keeping them on? If you're going through the trouble to re-weld them why not just take them off?
Suspension upgrade
exit34rocker1017 replied to Methfinder's topic in Solid Axle Swaps, Hardcore Custom Fab
That is sick, I'm wondering how the rest works out for you. Keep us updated! -
Suspension for Daily driver
exit34rocker1017 replied to freyspath's topic in 96-2004 R50 Pathfinders
Get KYB GR-2 brand struts. They are great struts and mostly everyone has them here. There is never a bad thing said about them. They are direct bolt on fit. They last long and are reasonably priced! Keep in mind if you get new struts, you'll want to get new strut bearing and strut upper mounts while the strut is out. Make sure you get OEM Nissan strut bearings and mounts because the aftermarket brands only last 12-15,000 miles. Just looked up your part numbers, and they are 335033 for the left and 335032 for the right. -
It might have not been hard but the whole point of designing this was because a spacer welded to a steering linkage to extend it is just not a good idea in any way. This new linkage is not only safe and strong to use, but it is completely new and bolts on. If I had a SFD and didn't have this new linkage, I would order it right away.
While we're on the topic of skids, for those of us making our own middle skid, are there any dimensions out there? What are good spots to bolt it up? What to cover/what not to cover?
Don't really know what you're asking, but a 265/75R16 is a 32x11.5 tire. From what I looked up online, a 265/75R15 is a 31x10.5
They are talking about paragon. And yes, it is closed unfortunately. However in PA is Rausch Creek Offroad Park, I don't know how far you (Pamountainbiker) are from that, but from what I've heard it is a great park. I have yet to make it there. Max got rid of the R50 a little after that and drives a F350(?) with 37's stock.
It might look better blackened out, but the original truck was two-tone with the gray tone on the bottom so blackening it out would defeat the purpose of buying a two-tone truck. It looks better than the original, and looks clean. Good job!
I'd go with the 16's. And thumbs up to the Mickey Thompson MTZ's. I have the ATZ's and I love them.
Let's see some pics!
I went for a while without changing one, but they can affect your MPG. It's very simple to change. One end is a plug that plugs in to the left of the engine (I think). The other end is the sensor that simply gets screwed into the cat. I believe it is either a 21mm or 22mm wrench you need to screw it in. Here are a few tips: 1) Soak the sensor end on the CAT the night before with PB blaster of some sort. It makes it A LOT easier 2) Tape the plug end of the new O2 sensor to the sensor end of the old O2 sensor. This way you can pull the old one out from the engine bay, and the new one will follow the exact path of the old one and you can just plug it in
