94 Pathy
Everything posted by 94 Pathy
  1. k. Thanks guys! Will keep ya posted.
  2. Are those relays behind the cargo panels? If so, that's gunna be a bitch! Thanks for the layout though. I guess it's time to head to the garage & see what I can find. Thanks a million!
  3. OK, I've done some searching & haven't found any helpful info. Ever since I bought the Pathy, the rear wiper hasn't worked. I'm thinking the motor is shot. I figured for a cheap fix, it it works, I bought a relay from Rock Auto for $5.00. Now, I'm trying to find where the damn relay is.....Not with the others under the hood, & not in the rear hatch behind the panel with all the mechanisms. Anyone have a clue where the rear wiper relay is located? Under the dash? Thanks for all your help. By the way, I put a new starter in my Pathy two days ago & forgot how much of a PITA it is. Starts though.
  4. AWESOME! I'm thinking about looking into them also so I can get my 1st Pathy's frame all done up. I do have to say, this newer Pathy I got is nice. Was an Arizona Pathy. SOLID FRAME & NO RUST.
  5. I really really appreciate all the info. With me not having any welding experience @ all, but wanting to learn & find it facinating. I'll keep everyone posted & show some of my work if I feel it's presentable.
  6. Thanks fellas! I figured it should work so I can drive if not tow the Pathy 2hrs. I could always have someone later touch it up & make it stronger. I think I'll be getting myself a new welder with-in the next few weeks. Figured it couldn't be a bad buy even for getting my feet wet with welding. Thanks again for your input. I do have a book on welding also. Goes over all the different kinds of welding units.
  7. Alright all you welding guru's.... I'm wanting to get into a little welding. I don't have the money to go out and buy an expensive welder that will do everything. I want to plug & play. So, with that said, I'm looking at a "Northen Tool" 125 Flux core welder for $150.00. "Harbor Freight" also has a 120 amp, 230 volt Mig & Flux welder for $130.00. I was reading the reviews & they both sound really good & performed better then what they are rated for. The Northern tool brand was a plug& weld, while the Harbor Freight you needed to get a few extras to be ready to plug & weld. So, I'm asking for the guru's help if I purchased one of these welders, would I be able to weld up plates for my rusted frame & possibly weld up some bumpers? I was told I couldn't & NO WAY could I use it if I'm wanting to do a roll-cage. Thanks for all your imput everyone!
  8. Why do you need my status
  9. WOW, Nothing like reading over your own "How to do it" posts. It's time for a knock sensor replacement on this Pathy. I cried when I went back to where my other Pathy is & it runs better then this one. Oh well, this next week I'll be doing the ol' knock sensor. See whatelse I can do. Wish I could get my BL done that week since I'm off the whole week.
  10. I should also add that these will be going on my 1st '94 Pathy. Once I get things hoping with that, I'll be dropping in the 383 Stroaker. Will take time, but that is my plans for the next few years. I want to geta start on it.
  11. Alright all! So, I'm beginning to look for components to do my SAS. I'm curious to know who all out there has done this & what you used...If I should go with a Dana 44, or a Dana 60 if I run across a cheap on? Should I look for one from a Chevy, Dodge, or Ford? If price is right & I have the extra money, do I get front & rear so they match, or just regear the Pathy rear? Thanks for all your imput & knowledge. I'm not to knowledgeable when it comes to components like these. I'll be doing some more searching, but I know I can count on the guru's from this site.
  12. Sorry, pic didn't come up. You can see it on Harbor Freights website. Lot no. 67576
  13. Has anyone used or seen this & is it worth the money? 8000 Lb. Electric Winch with Automatic Brake Email to a Friend Click on image to zoom More Views . 8000 Lb. Electric Winch with Automatic Brake Item # 67576 Manufacturer: Road Shock 4.1 Horsepower Only: $359.99 Sale: $279.99 Add Items to CartQty: Add to Cart . Add to Wishlist | Add to Compare .Shipping Economy Ground Shipping available. Availability: In stock Leaves the warehouse in 1-2 business days. Quick Overview8000 Lb. Electric Winch with Automatic Brake 5 Review(s) | Add Your Review Customer Rating:.Description ■Three-stage planetary gear system for fast line speed and sure hold ■Freespooling ■Automatic load-holding brake ■Power in/out ■Remote hand control switch with 12 ft. cord ■Fairlead: 11-3/4" L x 3-5/16" W x 1" deep ■Line speed (in feet per minute): 13 (no load), 11 (2000 lbs.), 6 (6000 lbs.), 4.5 (8000 lbs.) Some vehicles may require Universal Channel Winch Mount (sold separately). 12 volts, 4.1 HP, 7.5 amps Drum diameter: 2.5" Gear ratio: 210:1 Cable: 5/16" x 94 ft. Overall dimensions: 20-11/16" L x 6-1/8" W x 6-15/16" H Bolt pattern: 10" x 4.5" .
  14. I have a '94 with frame rust like yours. I also have some in the middle of the frame also, which I guess can be patched by some flat plates. I'd be willing to purchase some from ya. Any possible way you could get a little wider so they can be bent around & welded together from both inner & outer plates? That would solve the top & bottom of the frame. Weld the two plates together. Just a thought.
  15. I wouldn't use undercoating on the frame. The POR-15 knock-off you used is wonderful. I'm using a cheap version of it from JcWhitney. I'll try & find my can of it & let you know exactly what it is called. I used it on my running bars, hitch, & gas tank. Planning on using it on the frame. Make sure you paint it on while it is humid. Yes, HUMID. It will dry harder & protect better. Good luck!
  16. I'm I the only one confused about your post? What does undercoating have to do with greasing the hubs? If it does, I'm a complete retard & don't understand & deserve a 4x4. no offense MY1PATH, but I think you were having a
  17. OK, I've hunted & can't find anything, so here goes...... When I installed my manual hubs on the Pathy, the directions mentioned not to grease manual hubs. I was reading an article the other day while on vacation about 4X4 maintenance. If the hubs are too hot to touch & remove, that is a sign they need to be looked @ & greased. I myself, would think you'd want to keep these greased just like axles & gears.....Correct me if I'm wrong, but don't you want to keep them greased? Thanks for your help & info ladies & gentlemen.
  18. Welcome to the life of a Nissan Pathy owner. They are known for rear frame rot. My 1st '94 has it bad....Waiting to do some welding & boxing so I can do some serious things with that Pathy. I was pretty lucky on my 2nd '94. An arizonia Pathy. Rust free frame. Getting ready to do the BL & Suspension lift on that one.
  19. Well, I would say from my previous Pathy, I would sware by the Platinum 2's. Ran like a champ & better overall. Now this Pathy, they did run like crap & I'm surprised about not all like engines being able to work with them. Just got done changing them out with original style plugs & runs like new. My next goal is to get the knock sensor replaced. Hopefully with-in the next month or two, get my BL & SL on this Pathy. Thanks again for the heads up on the plugs! Time to go play in the water/mud holes
  20. Thanks for the heads up on the plug issue. I figured it shouldn't really matter. Figured my previous ran awesome with them, so lets do it with this one. I'll get some standard plugs. Thanks again!
  21. I know I put them back on the correct order cause I did one at a time. I suppose I could try new wires. I guess It wouldn't hurt. Good weekend project.
  22. Okay everyone! I should say True Gear heads.... I ran diagnostics on this Pathy. Came out with a knock sensor code. I've replaced it on my previous Pathy, but not this one yet..... My issue is: Replaced the spark plugs with Platinum 2's. Just like I did on my previous Pathy. It ran great, but not this one. Lost HP & mileage. Runs like crap also. Wires seem to be fine, changed oil, filters, & even been using a gas additive. Would the knock sensor effect this also? The reason I ask, is cause I never had this issue with my previous Pathy. Could it be MAF sensor or the O2 sensor? Kinda lost with this... Thanks in advance for all the imput!
  23. I purchased some JGC coils also. Used, but from a V8. Curious to know how much longer they are from the Pathy's original coils? How much lift do you get from the JGC coils?
  24. Sorry for the confusion. I went ahead with the ZJ coils. Just made payment & hope the ycome soon so I can get them on as soon as I get some UCA's.
  25. WOW! Didn't realize I would have to do all that. I did get the ZJ's swapped out for the XJ's. I guess I'll just save them for the future. Are you talking about upper ball joint spacers? I son't have struts. '94 Pathys have UCA's & shocks. Hey Mudd, your '99 has a complete different set up compared to the older Pathys. Thanks for the info!
