47
Everything posted by XPLORx4
What size tires do you have now? Divide your new tire diameter by the old tire diameter to calculate the percent change: new tire diameter / old tire diameter = % error of speedometer. So if your truck has 31" tires now and you install 32" tires, that's 32/31 or a 3.2% error. At 75 mph (speedo reading) you would actually be traveling at 75 x 1.032 = 77.4mph. At 35 you'd be traveling at 36.12mph This approach is rather simplistic, since actual tire diameters vary by make, model, and even tire pressure, but it's close enough. As for fuel economy differences, again that depends on the tire itself. Going from a 31" mud tire to a 32" highway-biased tire will yield entirely different numbers than a 31" highway tire to a 32" mud tire.
Questions about adding an upgraded bumper
XPLORx4 replied to tmorgan4's topic in 96-2004 R50 Pathfinders
The irony of TJM's decision to discontinue production was because they released and marketed the product before there was demand for the bumpers. Now that the off-road R50 market has matured, and there's increased demand, it's too late. Kind short-sighted if you ask me. -
They said it couldn't be done... TJM Bumper
XPLORx4 replied to Pezzy's topic in 96-2004 R50 Pathfinders
Awesome Pezzy! Way to "pioneer" and push the envelope. It looks like your grille blocks access to the hole where the winch lever sticks out. Can you take a picture of the top of the bumper where your grille protrudes? -
That's an educated statement. An engine with more horsepower isn't under more stress than an engine with less horsepower. If anything, the opposite would be true- the smaller weaker engine would have been stressed more since it has to pull the same weight as the more powerful engine. Anyway, the 3.5L does prefer premium fuel but the engine will run on 87 octane.
I've not heard of any R50 owners swapping drive flanges to auto hubs, but it can be done. The easiest (but maybe not the cheapest) way is to go to your local Nissan dealer and buy a pair of auto hubs for the Xterra (which also happen to fit the Pathy). Or you could visit the Xterra message boards and see if anyone there who has swapped to manuals is willing to sell their stock auto hubs.
The things we do, the money we spend... all for the love of our dogs...
Yes, you can use synthetic ATF in the t-case, which has both a drain and fill plug. I put Mobil1 ATF in my t-case. When replacing drivetrain fluids, ALWAYS loosen/remove the fill plug before the drain plug. You don't want to drain the fluid only to find out you can't remove the fill plug!
With a 2-3" lift, the CV's are at a slightly higher angle, but this does not exceed the operational limits of the CV. With the factory hubs, the front CVs and diff always rotate when the truck is moving, so the CV boots may wear out more quickly. You may also feel slight vibration at highway speeds because of the increased CV angles. Manual hubs (or even Nissan automatic hubs) will solve these issues, but if your truck has the "all-mode" AWD transfer case (not the lever-operated case) then you must be certain to lock the hubs prior to using "all-mode". I don't think the ball joints will wear "prematurely." My truck has over 130000 miles (208000 km) on it (over 160000 km with the lift), and I have had to replace both ball joints only once- the rubber boots had cracked and were leaking grease. With a 2-3" lift, you can fit 265/75R16 or 32x11.50R15 tires, but you might have to use different wheels with less backspacing, so that the tire clears the spring pan on the strut. Trimming the mudflaps and plastic fender liners may also be needed to reduce/prevent rubbing problems. 31x10.50R15 tires will fit on the factory wheels with no lift.
I don't mean to pooh-pooh your preference to get a Pathfinder, but have you considered a Subaru Outback or Forester? Compared to the Passat, you will be disappointed with the fuel economy of any Pathfinder. The other mini-utes (CRV, RAV4, etc.) may also fit your needs.
A suspension lift increases the distance between the axles/tires and the chassis by altering suspension components, such as a springs, torsion bars, A-arms, etc. A body lift increases the distance between a vehicle's frame and its body. This only applies to vehicles with body-on-frame construction. The 96-04 Pathfinder does not have a separate body on frame. It uses a "monoframe" chassis, in which the "frame" and "body" are fused into one unit, or "unibody." Therefore, you cannot get a body lift for it. The available lifts for the Pathfinder provide clearance for larger tires and better off-road capability, as well as providing enhanced "truck-like" looks. All of the known recommended lifts replace the coil springs on all 4 corners. The stiffness of the springs determines how high the truck sits (1" to 3"). With regard to the tires you specified, do you have a particular brand in mind? Search tirerack.com for that tire size to see what's available.
On the 2001, you're not paying just for the engine, you're paying for a 2-year younger vehicle with 14,000 fewer miles on it. Since it's an LE you're also getting dial-selectable all-mode 4WD system, which can be easier for a novice to operate than the transfer case lever. And finally, you're getting the newer cosmetic enhancements that were introduced in the 99.5 model. On the other hand, there were a few minor issues introduced on the 01's, namely the 6-disc in-dash CD changer, which has had problems ejecting CD's (player reports "ERR2"). What does your wife drive now, and why does she want a Pathfinder?
It's hard to recommend a tire when you don't give any indication of what your criteria are. Longevity (treadwear rating)? Noise? Highway handling? Wet performance? Price? Tire size? Where will you be using them, what will you be using them for and how often? That being said, I chose to put 32x11.50R15 Goodyear Wrangler MTR on my truck. These replaced 32x11.50R15 BFG AT-ko. My truck is not a daily driver, so I'm not too concerned with treadwear. Since my truck has become more of a purpose-built adventure wagon, I also wanted a tire with an impeccable reputation for rock-crawling performance and a durable sidewall. (A rock slashed a sidewall on my BFG AT, which prompted me to get the MTRs.) I don't drive through mud very often. In fact I try to avoid it! The GY MTR is relatively quiet on the highway (compared to other MT tires), too, so getting to and from the trailhead won't be unbearable. If I had continued to use my truck as a daily driver, I would have stuck with the BFG ATs.
What about a cargo net like this?
Sliders and NEW Bumper of to the powder coaters
XPLORx4 replied to snosnk's topic in 96-2004 R50 Pathfinders
Those look great, man! What are the 2 larger pieces behind your sliders? Not for your truck, are they? -
I think he means that the antiswaybar links are prone to wearing out sooner than other suspension parts, and replacing them with new OEM ones improves the ride. There's nothing inherently "wrong" with the original links, and there aren't any aftermarket replacements.
I recently replaced a front hub on my truck. Naturally, repacking the front bearings involves much of the same labor. Photos are at this link if you're interested in finding out what's involved. Note: not all of the steps (such as removing the rotor bolts) are required to repack the bearings.
I pulled the diagrams from aaanissanparts.com. I've ordered OEM parts from them before.
power steering problems 2 questions!!!
XPLORx4 replied to 98Chilkoot's topic in 96-2004 R50 Pathfinders
When you turn the wheel all the way left or right and hit the stops, it puts additional strain on the power steering pump. If the power steering pump belt is loose, it will squeal. Turning the wheel while the vehicle is stationary scuffs the tires. Irregularities in the road surface and tire tread can combine together to make steering seem rough. Additionally when the power steering fluid is colder it may not flow as well. Have you checked the fluid level and condition recently? Otherwise, what you've described doesn't seem that out of the ordinary. -
Any suspension component that moves and is attached in any way to a non-movable part (such as the frame) is usally attached with some kind of rubber bushing or other material that is prone to wear. Clunking in the suspension could be caused by any number of things. However, the easiest to check are the following: Figure 1- Suspension Components: Figure 2- Steering Components: - Antiswaybar endlinks (Fig1 #15). These are the short vertical rods that attach the swaybar to the strut. They can either be loose in their mounts or the sockets on either end of the link may be worn. Shaking them by hand or cycling the suspension up/down reveals their condition. Also check for torn or cracked rubber boots on the endlinks. (Photo here.) -Ball joints (Fig1 #5). With the front wheels raised off the ground, shake the bottom of the tire toward and away from the truck. Rattling or any kind of movement at the ball joint indicates it is worn out. (Also check for torn rubber boots.) -Antiswaybar bushings (Fig1 #17). These rubber parts isolate the metal swaybar from the frame. Over time the bushings can harden or change shape, allowing the swaybar to move freely up and down during suspension cycling. The bushings are located on either side of the frame, just inboard of where the swaybar bends. Shake the swaybar up/down and check for movement. -Inner tie rod ends (Fig2 #3). With the front wheels raised off the ground and the steering wheel locked, shake the tire in such a way as to attempt to turn it left/right. Excessive play or rattling while doing so reveals that the inner tie rod socket is worn and should be replaced. -A-arm bushings. They are located at the front and rear of the lower A-arm (Fig1 #6). It's more unlikely that the A-arm bushings cause rattling/clunking sounds than any of the other components mentioned above. However, they should be checked as well. -Strut components. Worn parts in the strut are hardest to diagnose because they cannot be easily seen. If all of the other suspension parts check out OK, first pull the rubber cap off the top of the strut and check that the nut holding the strut shaft is tight. If so, likely causes for clunking are: worn strut mount (Fig1 #13); worn strut bearing (Fig1 #11); hardened/worn rubber boot (Fig1 #10).
They look like a poor-man's solution to a real lift, and (IMO) a sort-of "billyjoebob redneck" method. I would be wary of spring stability if placed outside of the coil (ie. on top or on bottom) since the spring could pop out of its mount. Also, they look like they wouldn't work well on the front springs, since by installing them you will lose significant uptravel (spring can't compress as much). Plus, they're so thick I don't know how you'd fit them between the spring coils, then get the coils in the truck anyway.
$400 for a wheel bearing repack!!!??? OMG, what a ripoff! For starters, you can drive a lot longer than 30K before you have to repack the bearings. I don't necessarily recommend that you do this, but I drove ~60K miles before repacking the bearings. It shouldn't take a qualified mechanic more than an hour per side to repack the bearings. If you have the wherewithall to do it yourself, it's not really that hard. It's just kinda messy.
If none of those parts are the cause, check your inner tie rod ends, the ball joints, or the rubber bushings that hold the swaybar to the frame. At some point or another all of these parts needed replacing on my truck, and all of them caused a slight clunking sound before replacement.
pathmaker- I 'wheel in the Sierras mostly when there isn't snow, since I live in San Jose. However, I grew up in Valencia and the mountains around SCV used to be my stomping grounds when I was in high school. I once took my parents' 2wd Ford van out in the boonies near Sand Canyon and got it stuck so bad on a 4WD jeep trail that it took 3 weeks to find a 4WD towing company to go get it! Do you live in SCV or just go there to 'wheel? Oh yeah, one last question for ya- have you noticed a big drop in acceleration with those tires?
If you want to buy a set of good sliders (without having someone custom-fab a set just for you) you can try 4crawler. Shipping could be pricey for you if you're far from California, but otherwise they're well-made and relatively affordable. I have a pair on my truck. Pics here
Neither, I'm guessing. They're probably 285/70R17, since BFG doesn't make flotation sizes for 17" wheels.
