All Activity
This stream auto-updates
  1. Yesterday
  2. Plenty of info on TD27s on the Aussie facebook groups, a lot of us are TD nuts, they will be able to give you all the measurements and info you might need. There is a group 'TD27 Torque' which will have plenty of help.
  3. Superstar. Great to have the extra support. Huzzahhh!
  4. yep ! that's a good guy ! happy that the forum is back online... facebook groups are just not my thing when you search things ! way to go adam
  5. Last week
  6. That sounds more like sommething external to the motor. Do what @Slartibartfast said, if that isn't it, these trucks were kind of known for the harmonic balancer separating (it's a 2 piece press fit rubber thing IIRC). I would check that out as well. My parents 2000 R50 with the VG33E had this happen, twice. The first time, the dealer replaced a ton of parts before finding it. An easy way to check rod knock is to loosen all the plug wires at the distributor and then while the truck is running, remove one at a time and see if any make the knock go away or less pronounced. Good luck and keep us posted. For what it's worth, of all the Nissan vehicles I've had with the VG engine, I only ever had one with a rod knock and it was severely overheated several times/ran without coolant.
  7. He has been an NPORA member for nearly 20 years and a regular the whole time. Recently he worked with us in the background to get the forum back online, root out problematic DDoS sources and test for reliability. And now adamzan has agreed to join the Mod Team. Welcome adamzan!
  8. I had a weird clatter turn out to be the front bearing in the alt giving out. Remove the accessory drive belts, run it, see if the noise goes away. If you do them one at a time you'll know which one is noisy. I would also give the water pump a spin, see if there's anything obviously wrong there. Given the front-end wreck, I'd also check that the fan shroud is held on properly, and the fan isn't making contact with it. Long shot, but worth checking. If it still makes the noise with all the belts off, might be worth pulling the timing covers to check the belt tension and the condition of the idler pulley. IIRC the keyway only locates the sprocket during assembly, and it's clamped in place by the crank bolt. So unless the crank bolt is loose, it shouldn't be able to rattle.
  9. My '98 Pathfinder has recently started making an alarming sounding racket, from the lower end of the engine. As the title suggests, my thoughts go towards worst case scenario and say its a rod knock in its early stages. I've recorded a video of it, which is the worse the noise has been so far, and iirc the engine was at full operating temp. It's not quite as loud or deep as bad rod knock is, but that's why I say it could be in the early stages. It could be attributed to piston slap, but as far as I know, that sound would go away when it warms up, plus this sound has been happening for maybe 3 weeks now, as opposed to the 3 years that I've owned it. The youtube channel 'Auto can' has a series of videos diagnosing a vg33e knocking sound, and it turned out to be the keyways on the timing belt sprocket and crankshaft being very deformed, allowing the key to rattle around when running. I don't know if I'd rather have that than rod knock but it could be that as well considering how relatively quiet the noise is? One additional thought I had about this was that according to the maintenance records I have, the timing belt was done at 103k miles, and it now stands at 170k miles. Technically less than Nissan says to replace the belt, but not out of the possibility it needs replacing and could be contributing to the noise, right? I should also mention that I went on a quick drive before posting this, getting it to operating temp for around 15 minutes. Neither when it was idling cold nor after the drive did the noise come up, it sounded just as it did before the concern arose. I don't know what that means but probably good to know. This car was very nicely garage kept and maintained for most of it's life before I had it, and while sadly it did experience a decently big front end collision (that didn't immediately affect any mechanical components), I have been very on top of oil changes and other maintenance items, so it's very frustrating to see the engine potentially going to crap, especially so long before 200k miles.
  10. That same guy has the username "Nefarious" on here. He hasn't been on in a while but maybe PM him and it'll email him to remind that npora still exists lol.
  11. So i found these rims of an 03 Pathfinder SE: https://imgur.com/a/YkOPJK2 Door jam says 255/65/r16. Unfortunately, I'm getting 1 tire option when searching online. Is it safe and okay to install 255/70/r16 tires on these rims wihtout issue for my 1997 Pathfinder SE? Vehicle is on a 1 inch spacer lift. Thank you.
  12. Thank you! I'll try to find a set of those. Most places I'm calling either don't have them or don't have the full set. So essentially any of those vehicles up to 2004? Also including the supercharged Frontiers?
  13. Earlier
  14. Any first gen Pathfinder, hard body, Xterra, or frontier wheels will fit. Supercharged Xterras came with 17" wheels. Probably not hard to find a set of those. The 2nd gen Xterra/frontier like slart said have a different bolt pattern and won't fit. Many aftermarket Chevy wheels will also fit. Be careful with Toyota wheels, you'll likely need different lug nuts for those.
  15. Those look like a smaller lug pattern. Looks like the D40 Fronty went to 6 on 4.5" rather than 6 on 5.5". I would assume the D22 Fronty wheels would fit the lugs, but I don't know what they had as far as diameters and offsets and whatnot.
  16. Good evening everyone! I am looking for a set of rims for my 97 Pathfinder SE. It has the stock 15 inch rims, however, there are not too many options for tires and I'm looking for a set from either frontiers or later model Pathfinders. I know for sure that the 17 inch rims from the 2004 Pathfinders will fit, but will 16 inch Frontier rims fit without any issues? Do these rims have the same bore size as the factory 15 inch rims I have? I do have manual locking hubs on my Pathfinder. Are there any other options that will fit my vehicle? I have seen some 4Runner rims on these trucks too. Here is a link to the picture of the rims I am currently looking at. https://imgur.com/a/0rT48Tm Thank you
  17. I’ll add to that. Bee running rear disc on my 97 for almost a year and they’re absolutely amazing
  18. Finally ordered the last of the engine parts today, time flies and I miss driving this thing more than I thought I would. I went camping over the Xmas break in my D22, it felt like such a betrayal after all these years!
  19. It wouldn't be too hard to delete the sunroof, weld some sheet metal in and finish it off with short strand fiberglass/body filter, then paint. My friend did it on his R32 Golf track car.
  20. That id a good idea, I need paint as well.
  21. I've heard of the dampers causing bleeding issues. I don't think I've heard of one doing what yours is doing, but it does sound plausible. If nothing else jumps out at you, look for an M10x1 invert flare (not bubble) union. And yeah, I'd check under the dash first, if only because I hate bleeding hydraulic systems.
  22. I haven't seen him around in a while, but Ekim Naelcm on the NPORA FB page did a TD swap. He would be the guy to track down with questions, or see if Farcebook lets you dig up his old posts about the swap. The gear ratio should be marked on the tag in the engine bay. US trucks are HG43 or HG46, for 4.3 or 4.6 ratio diffs. Hopefully the Terrano is marked similarly. If the '95 is auto, it's more than likely HG46. Manual trucks usually got HG43. If you plan to run stock-size tires, and the ratios are wrong, that'll throw off your speedo. But if you plan to run larger tires, then the deeper gears would be an upgrade. I have a service manual for the TD27, but sadly not the full manual for the rest of the truck, so I don't have a schematic for the glow plug wiring. However, the '87 Pathy/Hardbody manual that I do have shows an SD25 diesel engine, which has an automatic "quick-glow" system wired from what looks like the same ignition switch as the gasser. If you want I can take a few pictures of the relevant pages in the manual. That said, I suspect you'd be better off reverse-engineering it from the donor (or just swapping over the harness and everything attached to it!) than making assumptions based on service info for an earlier engine from a different family. Good luck, and let us know how it goes!
  23. Awesome thanks for the info! I’ll see if I can find some metal around those dimensions to try and fabricate it up.
  24. You can bypass it with a union, there was a post on it on here somewhere. The dampener is to assist with smooth shifts IIRC. First I would check the return spring on the pedal itself as well as bleeding the clutch fluid. I still have mine In place and have never had an issue. Just replaced a couple bad slave cylinders. If it were me I'd check everything else before hacking into it to bypass it.
  25. Wohoo!!! The Site is back up!!!! The clutch pedal, over time, 10's of minutes, does not fully return. It's not leaking or losing fluid. I can put my foot behind the pedal and pull it back into place with no issues, but it returns back to the partially depressed position once it's depressed again. I have a new master cylinder and slave cylinder (Not yet installed). I have a suspicion that the Dampener is sticking, which I believe could cause this symptom. That part appears to be unobtanium. Can this be bypassed, if so, how does bypassing it affect operation? I've been having this issue with my clutch for some time now. If anything, it's a bit annoying, but doesn't affect drivability for short drives to work or in town. Not sure if it would be an issue for a longer drive. Don't really want to test that out and get stranded somewhere while it slowly resets... Miss you guys!! Have a great day!!!
  1. Load more activity
