Guest ARB Posted December 5, 2003 Share Posted December 5, 2003 I'm considering in getting this kit for my path. Do you suppose it is worth the money? http://www.purenissan.com/wd21_3_kit.htm Link to comment Share on other sites More sharing options...
Simon Posted December 5, 2003 Share Posted December 5, 2003 it probably is....but you could also just buy the torsion bars, and get some Ford F-150 coils for the rear lift, or Jeep Grand Cherokee coils. They both will give you added lift in the rear, and are MUCH cheaper than new ones.....check local scrapyards. Then, with the new torsion bars, you'll be able to crack them up to level out the front. Whether you get the kit or not, you'll need an alignment afterwards, so the new A-arms may, or may not be worth it. It also depends on how good, or bad, your current shocks are... I know Jim has the Calmini torsion bars in his Pathy, and he's said he likes them. Link to comment Share on other sites More sharing options...
88pathoffroad Posted December 6, 2003 Share Posted December 6, 2003 I think a set of upper a-arms by themselves and new torsion bars along with a set of JGC springs would be the best/most economical route to lifting your Pathfinder about 3". And yes, get an alignment afterwards. Link to comment Share on other sites More sharing options...
Casey.T Posted August 31, 2005 Share Posted August 31, 2005 Guys, This is also the kit that I am looking at putting on my 92 $750+SH From what I have seen and read it does the job for a SL. I am not planning on a BL, just because I feel the SL is all that is really needed for the weekend brush beating and hunting that I do. Im still looking for the how to crank the t-bars:( Link to comment Share on other sites More sharing options...
Filthy Luker Posted August 31, 2005 Share Posted August 31, 2005 (edited) Im still looking for the how to crank the t-bars:( You gotta be kiddin' right? Google: "cranking pathfinder torsion bars" and click on the first link provided. Also Calmini is so ridiculously overpriced it's not even funny, and most people that actually try to off road with their components are cursing them out. Whatever suspension lift you get, make sure you factor in a steering system upgrade into your budget (such as L&P centerlink) or you'll be blowing the stock one or two trail runs. Edited August 31, 2005 by Filthy Luker Link to comment Share on other sites More sharing options...
Kn0xville Posted August 31, 2005 Share Posted August 31, 2005 this is cheaper, guy on AC is selling the whole AC kit. HERE Link to comment Share on other sites More sharing options...
exodus_68 Posted August 31, 2005 Share Posted August 31, 2005 I have the Calmini kit fitted and I think it is pretty damn good. Haven't had any problems with it, and I hit some pretty good trails. As has been said though, make sure you incorporate a steering upgrade into your costings. I have spent about 1000(australian) replacing stock steering components since I lifted. Evidently it is easier to get steering upgrades in the US for that in Australia. Link to comment Share on other sites More sharing options...
TrailChaser Posted September 1, 2005 Share Posted September 1, 2005 Click here for some JGC lift coils. They give a JGC with a V8 3.5in. of lift, just think how high that pathy rearend will be. These are cheaper, but you gotto put in your zip and follow a couple of links. Both are under $200 tho. Click here for coils. Link to comment Share on other sites More sharing options...
Casey.T Posted September 1, 2005 Share Posted September 1, 2005 I found some JGC springs at the local Junk Yard for $20 each, they said they had about 12 rigs out there with AWD V8's Ill be picking them up in the morning. Filthy, found Jim B's page it was the 1st on on the google, thankyou now its back under the beast. Link to comment Share on other sites More sharing options...
red-finder Posted September 1, 2005 Share Posted September 1, 2005 I installed that same kit on mine. For a complete kit with all you need included it's REAL GOOD! The stuff is heavy duty and goes together easily. I also had no problem getting it aligned the first time with new tires. The only complaint I have is the UCA bushings like to squeak, but I don't care. If you have the money for the kit buy it. If I had it to do over I wouldn't lift mine any other way!!! Link to comment Share on other sites More sharing options...
Earth1 Posted September 1, 2005 Share Posted September 1, 2005 I agree. The squeak thing is annoying. But, Calmini UCAs are very well made. Way more solid than any other ones I've seen. I can't imagine damaging mine. The guys at my alignment place said they were the best they've ever seen. If you can spare the dough, I'm sure you'll like them. Link to comment Share on other sites More sharing options...
Duffman Posted September 2, 2005 Share Posted September 2, 2005 Have it and the steering upgrade, mine dont sqeak either. Great stuff. Link to comment Share on other sites More sharing options...
SteeevO Posted September 6, 2005 Share Posted September 6, 2005 does anyone have pictures of a 3" lift completed?? if so can they post them? Link to comment Share on other sites More sharing options...
wheel366 Posted September 6, 2005 Share Posted September 6, 2005 As soon as mine is back, I will post some better shots. I have 2 pics up at cardomain, but they aren't very good shots. They are from underneath the car. http://www.cardomain.com/ride/758062/3 Link to comment Share on other sites More sharing options...
Duffman Posted September 7, 2005 Share Posted September 7, 2005 This is on un-even ground, the back sits allitle higher, Ill post another tomarow. Link to comment Share on other sites More sharing options...
SteeevO Posted September 7, 2005 Share Posted September 7, 2005 that looks realy nice.. and i don't mean to hijack theis thread but i realized u have 33's,.. I just got 30's on my pathy...u think it would look ok? Link to comment Share on other sites More sharing options...
Casey.T Posted September 7, 2005 Share Posted September 7, 2005 Duffman, Nice :bow: Your in Seattle??? short drive to meet in Elensburg from Spokane..... My Vote is in for the Calmini, I will be ordering it shortly. About how long did it take to install? Link to comment Share on other sites More sharing options...
Duffman Posted September 7, 2005 Share Posted September 7, 2005 30's on a 3" lift would look fine, but I would move to a bigger tire down the road. 33's with only the 3" lift rub the hell out of everything. Im putting the 3" body lift on later this month if time permits. Casey, just shoot me a PM. Link to comment Share on other sites More sharing options...
Airrun2002 Posted September 7, 2005 Share Posted September 7, 2005 Just look at mine got 30s on a 3" lift i think it looks great. Link to comment Share on other sites More sharing options...
Kn0xville Posted September 9, 2005 Share Posted September 9, 2005 31's dont look bad at all, it'll look funny to you at first, but you'll get use to it. And if you do any hard off roading, you might wanna only go to 32's, the 33's are a heavy tire and can kill the TRE's pretty quickly, and the steering too if yours is stock. I plan on some 33's REAL SOON, but i dont wheel to hard either, just like the mud. Link to comment Share on other sites More sharing options...
Mr. Pickles Posted September 9, 2005 Share Posted September 9, 2005 (edited) You should be fine. I think it depends on the type of tire too as to how it looks. A more agressive MT looks much more at home than a street tire. Here is mine on very worn down 31" MT's with 3" suspension + 3" body lift. Edited September 9, 2005 by Mr. Pickles Link to comment Share on other sites More sharing options...
MaritimeMan Posted September 9, 2005 Share Posted September 9, 2005 .....rubs his hands and waits for his Body Lift to arrive Link to comment Share on other sites More sharing options...
Mr. Pickles Posted September 9, 2005 Share Posted September 9, 2005 .....rubs his hands and waits for his Body Lift to arrive Are you sure that's all you're rubbing? Link to comment Share on other sites More sharing options...
Casey.T Posted September 14, 2005 Share Posted September 14, 2005 Ok, I found some 33/950R-15 Mud Terrain SXT from Les Schwabs @$150 each (PC 02113966). They will fit on the stock rims NP. Will I have the steering clearance with the stock rims or will I have to up grade the rims with the Calmini 3" SL? Link to comment Share on other sites More sharing options...
gabod7 Posted September 14, 2005 Share Posted September 14, 2005 man, i'm goin with 3" BL and 3" SL by way of JGC coils and new a-arms and torsion bars, and im gonna run 35's. that may be excessive, but hey, why not. im going to cut my fenders alot to and run a custom front bumper and exo cage. lol, sounds crazy now but it'll be cool when its done. Link to comment Share on other sites More sharing options...
