88pathoffroad Posted January 29, 2006 Share Posted January 29, 2006 Just so everyone knows, a generic GM/Chevy #PH3600 (WIX/NAPA #51516) oil filter fits perfectly fine on the VG30 block and is slightly larger than the stock-size filter. I'm using one on mine right now. The stock filter is about 3.5" long, the new one is 5.25" long. That's quite a substantial increase in internal filtering surface area, actually. That's some cheap, good insurance against dirty oil and a small increase in oil capacity! I put 4 quarts in when I refilled my oil and the dipstick was still showing a little high, but not enough to worry about. Link to comment Share on other sites More sharing options...
Mr. Pickles Posted January 29, 2006 Share Posted January 29, 2006 Really? No leaky-leaky? Sweet. Link to comment Share on other sites More sharing options...
RedPath88 Posted January 29, 2006 Share Posted January 29, 2006 Ahh cool, now I can increase the filtration and capacity on my Pathy like I did on my Yota Link to comment Share on other sites More sharing options...
90seven Posted January 29, 2006 Share Posted January 29, 2006 (edited) No tips for the R50-ish? bah! Anyone ever use/heard of this product? I tried it out once, should I continue to use it? I've read some good things about it, just wondering if anyone else on here has. Edited January 29, 2006 by 90seven Link to comment Share on other sites More sharing options...
02silverpathy Posted January 31, 2006 Share Posted January 31, 2006 used this like curse words on my 3.1l chevy corsica...loved it...i really don't think it sped up the age process either...my pop was a machinest for 26 years and said that it is really good for higher mileage engines....the corsica ran strong through 120K miles...bu t there were just too many leaky gaskets! it really just raises the oils ability to coat and to stay bonded...for a period of time longer that it usually would. Link to comment Share on other sites More sharing options...
revgolem Posted January 31, 2006 Share Posted January 31, 2006 I'm just kind of curious as to what the actual advantage is supposed to be?!? You are still pumping the same amount as determined by the oil pump, and i've never had a problem with the filter keeping up. More oil capacity just means, to me at least, mosre oil to put in. As long as the oil and the filter are changed regularly, I don't really see the advantage. I'm not trying to argue the point, just trying to figure out what I'm missing. Link to comment Share on other sites More sharing options...
88pathoffroad Posted January 31, 2006 Author Share Posted January 31, 2006 The more oil is in the system, the cooler it can run and better it can lubricate, especially on cold starts. Better filtration via having more filter element inside is a gimmie, it helps protect the engine. It's not about oil pressure, it's about capacity and filtration. Link to comment Share on other sites More sharing options...
Mr. Pickles Posted February 1, 2006 Share Posted February 1, 2006 And if you can squeeze an extra half quart in, that's one less half-empty oil bottle I'll have sitting forgotten on a shelf in the garage. I'm due in about 750 miles, so you know I gotta try it. Besides, maybe the Chevy filter will be cheaper than the already pretty cheap Pathy filter. Go 88! Link to comment Share on other sites More sharing options...
Slick Posted February 1, 2006 Share Posted February 1, 2006 (edited) No tips for the R50-ish? bah! Anyone ever use/heard of this product? I tried it out once, should I continue to use it? I've read some good things about it, just wondering if anyone else on here has. :bow: i swear by the stuff.. been usin it for years in my chevy (210,000 perfect miles) and pathy (137,000 unmentionable miles) and the Jeep (90,000 reliable miles)... Edited February 1, 2006 by Slick Link to comment Share on other sites More sharing options...
94extreme Posted June 30, 2006 Share Posted June 30, 2006 this filter does NOT fit in my 94.. it's at least half in too long.. catches on the frame thusly doesn't want to catch the threads squarely. Link to comment Share on other sites More sharing options...
wheel366 Posted June 30, 2006 Share Posted June 30, 2006 Do you have a lift? Maybe that is the reason. Also, wouldn't the headers be an issue with fitment? Link to comment Share on other sites More sharing options...
94extreme Posted June 30, 2006 Share Posted June 30, 2006 no, i am stock but 88 has both types of lifts which may somehow make a differnece but i don't see how.. neither the engine nor the frame changed their position as related to the filter.. Link to comment Share on other sites More sharing options...
Harbinger Posted July 3, 2006 Share Posted July 3, 2006 It fit mine just fine and my pathies stock. Link to comment Share on other sites More sharing options...
89_trailboss Posted July 16, 2006 Share Posted July 16, 2006 fit fine on my 89, and our 94 and 95. my 89 has a 3" sus lift, but the lift does not have anything to do with the oil filter fitment. they DO hit the frame a first, but just give it a little bit of lovin and it will get in there just fine. Link to comment Share on other sites More sharing options...
94extreme Posted July 17, 2006 Share Posted July 17, 2006 i gave it plenty of "love" and it's too long by about the inch i mentioned.. no way no how.. too bad.. maybe something is a little different on my truck.. i dunno. Link to comment Share on other sites More sharing options...
unccpathfinder Posted July 17, 2006 Share Posted July 17, 2006 88 i dont think that'll fit on a stock 87...they ran the brake lines right down the frame rail there and i know with the reg filter on the last threads it butts flushly up against that 1...i could see it working on my 95 b/c they did a better job with opening a lil space around the filter... so once again another good reason to get a lift Link to comment Share on other sites More sharing options...
