DJ Dank Posted January 28, 2006 Share Posted January 28, 2006 Dang yer quick...I typed it all out and then accidentally clicked Add Reply before attaching the pic. Then I went to edit it and it took me a while to find it! :o Link to comment Share on other sites More sharing options...
Trainman Posted January 28, 2006 Share Posted January 28, 2006 Hey Trainman.. What are you using for a mount? I'm looking to install my Yaesu FT-90 or Kenwood TM-D700A APRS rig. Guinness Its a clamshell type, I will get you a picture on Monday (wife has the camera). Works well, can be set to any angle form 0 to 180 degrees. Link to comment Share on other sites More sharing options...
XPLORx4 Posted January 28, 2006 Share Posted January 28, 2006 What antenna are you using? I'm using a Firestik 4' antenna, but it's mounted to my bull bar. Any CB antenna that's properly mounted and tuned will work fine with the 75WXST. The type of antenna you use depends on how and where you want to mount it. Link to comment Share on other sites More sharing options...
t0ast Posted January 29, 2006 Share Posted January 29, 2006 Dang yer quick...I typed it all out and then accidentally clicked Add Reply before attaching the pic. Then I went to edit it and it took me a while to find it! :o How's the clearance on the mount with the hood closed? I didn't think I'd be able to fit anything through the crack without drilling a hole. Link to comment Share on other sites More sharing options...
DJ Dank Posted January 29, 2006 Share Posted January 29, 2006 (edited) How's the clearance on the mount with the hood closed? I didn't think I'd be able to fit anything through the crack without drilling a hole. The clearance is fine. Those mounts are called "Hood Channel" mounts and they are thin enough to fit just fine. Its the Firestik MK174 mount. Edited January 29, 2006 by DJ Dank Link to comment Share on other sites More sharing options...
Trainman Posted January 31, 2006 Share Posted January 31, 2006 Hey Trainman.. What are you using for a mount? I'm looking to install my Yaesu FT-90 or Kenwood TM-D700A APRS rig. Guinness As promised, here are some pictures, hope they help. Link to comment Share on other sites More sharing options...
Guest Guinness Posted January 31, 2006 Share Posted January 31, 2006 (edited) As promised, here are some pictures, hope they help. Thanks for the pics.. Unfortunately I don't think I'm going to be able to put a rig there as my Pathy is 5-speed. There won't be any room to manage the stick there. Guinness Edited February 1, 2006 by Guinness Link to comment Share on other sites More sharing options...
Trainman Posted February 1, 2006 Share Posted February 1, 2006 Thanks for the pics.. Unfortunately I don't tink I'm going to be able to put a rig there as my Pathy is 5-speed. There won't be any room to manage the stick there. Guinness Yep, that would be a bit of a problem! No magic can fix that :Magic: Hope it works out. Link to comment Share on other sites More sharing options...
nissandoms47 Posted February 1, 2006 Share Posted February 1, 2006 what about if i get a 102 inch whip antenna. radioshack sells them for 20 bucks. mount it to the rear bumper and tie it down to the roof? Link to comment Share on other sites More sharing options...
herm Posted February 2, 2006 Share Posted February 2, 2006 Apologies for simultaneously cross posting and post-jacking: but..... Looking at new CB set up for the pathy. Some of these shops offer a service to "tune" the radio, to improve reception... is this crap? Such as: <<To drastically simplify it, the true tune is a realignment of the transmitter section of the radio. The mega tune involves completely aligning all sections of the radio.>> I prefer a portable system to swap between vehicles, or on occasion to use on foot for short distances. This is what I'm thinking of - Midland 75-822 Handheld CB Radio FS-4, Four Foot Firestik Antenna Tri-Magnetic Mount Pad Just wondering if this 'extra tuning' work really does anything on such a relatively simple radio? Link to comment Share on other sites More sharing options...
mws Posted February 2, 2006 Share Posted February 2, 2006 No, it is not crap. There is an incredibly slim chance everything is perfectly matched right out of the box, but most users will see at a least a doubling in range with tuning - and some MUCH more than that. Put your stuff in and see what kind of range you have. If it is inadequate for you, get it tuned. And with the firestick, I think you can fine tune the length yourself. It's more time consuming without the VSWR meters like the shop has, but it can be done. Tuning just the antenna won't get you quite as much as tuning the entire system, but it is far better than nothing. Find a big open area. Have a buddy park and continuously talk to you. Drive away until signal fades away. Stop, and adjust antenna length until it signal gets stronger. Drive further on until the same happens. Eventually, tweaking the length even a tiny bit in either direction causes significant loss. You're there. Link to comment Share on other sites More sharing options...
tiagoqx4 Posted February 2, 2006 Share Posted February 2, 2006 The type of antenna you use depends on how and where you want to mount it. @ xplr where is the best location to mount the antenna? If in case that I dont have a bull bar on my Q? And why would it depend on the location? -study- still figuring out where to put it (radio and antenna). :type: Link to comment Share on other sites More sharing options...
Trialsin26 Posted February 2, 2006 Share Posted February 2, 2006 tiagoqx4 - I am going to mount my antenna to my Thule roof rack. I figure the higher the better, and when it's not in use I was going to get this attachment that lets me fold it down. At least that's the plan. Link to comment Share on other sites More sharing options...
Pezzy Posted February 2, 2006 Share Posted February 2, 2006 @ xplr where is the best location to mount the antenna? If in case that I dont have a bull bar on my Q? And why would it depend on the location? -study- I have heard the higher up you put it the better... also in the case of mine, its a magnamount - so its in the center of my roof, high as it's gonna get, and also it 'supposably' will use the surface of my roof to reflect radio waves & help w/ reception.. Although that might be a complete line of crap. Link to comment Share on other sites More sharing options...
Trainman Posted February 2, 2006 Share Posted February 2, 2006 I have heard the higher up you put it the better... also in the case of mine, its a magnamount - so its in the center of my roof, high as it's gonna get, and also it 'supposably' will use the surface of my roof to reflect radio waves & help w/ reception.. Although that might be a complete line of crap. No, not crap. It is something we deal with in forestry so the best place to mount an antenna is dead center of the roof. BUT who wants a hole there? And it would interfere with putting stuff on the roof. On my employer supplied trucks I always got the antenna on the roof. It added about 10 km to the range when talking truck-to-truck, and a good 50 km to the repeater (sort or irrelevant to a cb or ham install but just shows what the difference is). Good call Pezzy. Link to comment Share on other sites More sharing options...
DJ Dank Posted February 2, 2006 Share Posted February 2, 2006 Yes the top of the roof is the best place to put it. You want something thats central so as to act as the ground plane for the antenna. But for my purpose, I can't have something that high up sticking up from my roof. My 3 foot Firestik barely hits certain parts of the roof of my parking garage at work. Link to comment Share on other sites More sharing options...
Pezzy Posted February 2, 2006 Share Posted February 2, 2006 ...so the best place to mount an antenna is dead center of the roof. BUT who wants a hole there? And it would interfere with putting stuff on the roof. Well I ran the wire to mine from the back hatch... it sits under my basket in the summer, so yeah - I do have to pack around it when I use the rack for camping gear, but it's never really been an issue. Link to comment Share on other sites More sharing options...
Trainman Posted February 2, 2006 Share Posted February 2, 2006 Well I ran the wire to mine from the back hatch... it sits under my basket in the summer, so yeah - I do have to pack around it when I use the rack for camping gear, but it's never really been an issue. You have a mag mount, so they work well. My company trucks had them bolted in, hence the hole. Link to comment Share on other sites More sharing options...
