3rd Member 1997 Pathfinder
Good evening everyone,
I’m in need of a 3rd member for my Pathfinder. Mine is an open diff and has a significant humming noise on the highway that goes away once you let off the throttle. In addition to that, the entire floorboard of the vehicle vibrates between 70-80mph. It’s not the tires or balancing, definitely driveline related. Rear differential has excess lash and definitely worn out over the 250k miles. Vehicle has a brand new driveshaft installed as well, still no luck.
I’m located in NYC and there are no salvage yards around the area that has a differential for this vehicle. So I’m reaching out to the community in hopes of anyone being able to locate one for me. I’ll pay all costs.
Thank you!
Check out Car-part.com
This will search all the yards around you Via distance. also if memory serves, look for an xterra rear differential. they are 33spline as well like the R50s
New driveshaft might not imply anything.  How's the pinion angle?  It should be nearly parallel with the output from the transfer case.  How are your rear springs?
I'm honestly not too sure how to assess that accurately aside from eyeballing it. I am fairly certain about the humming and clunking coming from the rear diff. I changed the rear springs, shocks, poly upper and lower links within the last 5 years.
Now I replaced the u-joint on the original Nissan driveshaft last Thursday after starting this thread, and returned the new one. Did a 500 mile roadtrip up to Canada this past weekend and did not experience any vibrations in the vehicle. However, humming noise is still there between 40-60mph and some clunking if I press and release the throttle.
23 hours ago, Strato_54 said:
how are the bearings?
Rear wheel bearings have never been changed. Front ones I changed a few years ago.
I was planning on changing the rear wheel bearings soon. I know it's a different setup than the front. Easy to tackle in the driveway?
Not easy.  Requires special tools to pull things apart and a press to put things back together.
Can second that, its easier to get a whole JY axle shaft with the bearings on than to change your self. i'm running all wheel disc thanks to Hawairish and his posts but it is possible yours are going out. took me a solid few days of work and almost lost a finger..... only the nail was the sacrifice... still wanted to ask how they seem. there should be 0 play in and out or basically next to 0.
