Back in another R50 after 6 years
alexg89
Scored this little 96  about 3 weeks ago. guy said it had an overheating problem with 223k on the dash.
Drove 3 hours to check it out and it looked promising so i got it.
5speed 4wd, clean interior, not alot of rust thank goodness.
But come to find out the headgasket had pushed out on cylinder 4 so tore it all apart.
Upon having it all tore down cylinder 2 and 6 had some pitting in the cylinder, so took a 3 stone hone to it and tried to clean it up the best i could.
few lifters were a little beat up but we are gonna run it as is.
Get it all back together, and it fired right up. Throttle had a bit of a hesitaton when you blipped it but ran fine when you barley got into the throttle.
Come to find out MAF was no good.
Stuck one in from my Xterra and she runs just fine.
Unfortuently the trans may be bad, gotta get it out and check the counter shaft bearing in the front, being its howling pretty bad on de-celeration. worst case i source a wd21 trans since the gearing is better.
Plans are to source a SFD and get some 33s or 34s under it.
Question, being a 96 is this thing 31 spline or 33? cause id like to get some 4.9s in this thing also
Anywho lets see how this thing goes
https://imgur.com/a/BbKLrpJ
I recognize that X from the Nissan SAS group.  Welcome back.
All R50s are 33-spline...but the problem with 4.9s is that there isn't a set that fits the front axle.  R50s have reverse cut gears up front in the R200A; W/D22 are standard cut.  You're limited to 4.6s, and hopefully that's what you already have.
I appreciate the open arms! lol
talk to me about this reverse cut stuff. ive never really understood it.
As for the differential itself, whats limiting me to sticking an xterra full front diff in place of this one?
You'll probably know it as "high pinion" (reverse cut) and "low pinion" (standard cut), much like the reference on Dana axles.  The pinion line is either above or below the centerline of the ring gear.  Rotation's all the same, but the teeth on the gears are cut in opposite directions.
R200A from an W/D21 or W/D22:
R50 R200A:
In general, high pinion is best up front, and low pinion best in the rear due to gear mesh.  But fck Nissan for making the R50 the only high-pinion R200A application.
The short answer is they can't be (easily) swapped because they are mounted to the truck in completely different ways.  The long answer:
R50 R200A:
I'll give it a read my man!
Worst case I Sas this one too hahha
:welcome:
I found a couple of similarly failed lifters in a VG33 recently. Out of curiosity, which lifters let go? Mine lost #1 and #5 exhaust. I ask because the only other thread I've found where somebody had that happen, it was the same two lifters that let go.
I ended up scrapping that engine, but held onto a few bits and pieces, including the rest of the lifters. PM me if you want a few (unknown mileage, used) lifters that don't look like they've been used as tire studs.
58 minutes ago, Slartibartfast said:
:welcome:
it was number 2 intake, 1 exhaust, and 3 intake and exhaust. and i hate to say this.......... i stuck them right back in lol.
Motor was a gamble to begin with considering milage, blow head gasket and the fact cylinder 2 and 6 had some bad pitting in the cylinders.
This motor isnt long for this world and i dont expect it to be. Just trying to keep it running long enough to actually build the truck and then im gonna be souring a lower milage one and spruce it up a little.
Ive  got an extra supercharger for my xterra ill probably end up stuffing under the hood at that point also
I was surprised how long the one in my X ran after it ingested the drivers side catalytic converter. I drove it for like 10-20k just having to add a litre of oil every fill up of the gas tank lmao.
  • 3 weeks later...
scored some 33s this weekend. think this thing should look pretty good once the SFD comes in.
ready to get it on the road.
Still gotta find a transmission or tear this one apart and replace what ever bearing is bad in it still
https://imgur.com/6MnME5J
https://imgur.com/XLSO7dk
  • 3 months later...
so little update.
Got my SFD ordered back in like november and it showed up in december BUTTTTT
the lovely people at UPS messed up the box quantity with item quantity and the tariffs/duties skyrocketed to 2400 bucks per box. which means 4800 for 2 boxes with 500bucks worth of parts in them lol
so its been re routed back to the shipper in canada and is currently "lost" per ups but they found it in montana.
It has been an absolute shyt fest and waiting.
So in the meantime i put on some 2in AC coils from 4x4parts and debating on if i want to rip the trans out of it to do the clutch now and replace the input shaft bearing since it is howling and making all kinds of racket.
Heres a pic of the truck last night after i did the coils  image.jpeg.4231a283e5406937f973ee479df20b6e.jpeg
Edited by alexg89
  • 3 weeks later...
Finally got the trasnmission switched out. couldnt find an R50 one so scored one from an xterra. Gotta switch out shifters since they have a bit of a different angle and the shift boots dont fit.
gotta get all my old sensors put on being all the plugs are different but its in and drives with no more terrible bearing noise.
may pull the old one apart and see what happen.
STILL WAITING for this Sub frame drop but ive been in contact and he will be reshipping it shortly
Just ready to get this thing on the darn road lol
