alexg89 Posted 18 hours ago Share Posted 18 hours ago Scored this little 96 about 3 weeks ago. guy said it had an overheating problem with 223k on the dash. Drove 3 hours to check it out and it looked promising so i got it. 5speed 4wd, clean interior, not alot of rust thank goodness. But come to find out the headgasket had pushed out on cylinder 4 so tore it all apart. Upon having it all tore down cylinder 2 and 6 had some pitting in the cylinder, so took a 3 stone hone to it and tried to clean it up the best i could. few lifters were a little beat up but we are gonna run it as is. Get it all back together, and it fired right up. Throttle had a bit of a hesitaton when you blipped it but ran fine when you barley got into the throttle. Come to find out MAF was no good. Stuck one in from my Xterra and she runs just fine. Unfortuently the trans may be bad, gotta get it out and check the counter shaft bearing in the front, being its howling pretty bad on de-celeration. worst case i source a wd21 trans since the gearing is better. Plans are to source a SFD and get some 33s or 34s under it. Question, being a 96 is this thing 31 spline or 33? cause id like to get some 4.9s in this thing also Anywho lets see how this thing goes https://imgur.com/a/BbKLrpJ Link to comment Share on other sites More sharing options...
hawairish Posted 16 hours ago Share Posted 16 hours ago I recognize that X from the Nissan SAS group. Welcome back. All R50s are 33-spline...but the problem with 4.9s is that there isn't a set that fits the front axle. R50s have reverse cut gears up front in the R200A; W/D22 are standard cut. You're limited to 4.6s, and hopefully that's what you already have. Link to comment Share on other sites More sharing options...
alexg89 Posted 16 hours ago Author Share Posted 16 hours ago 15 minutes ago, hawairish said: R50s have reverse cut gears up front in the R200A; W/D22 are standard cut. I appreciate the open arms! lol talk to me about this reverse cut stuff. ive never really understood it. As for the differential itself, whats limiting me to sticking an xterra full front diff in place of this one? Link to comment Share on other sites More sharing options...
hawairish Posted 14 hours ago Share Posted 14 hours ago 1 hour ago, alexg89 said: I appreciate the open arms! lol talk to me about this reverse cut stuff. ive never really understood it. As for the differential itself, whats limiting me to sticking an xterra full front diff in place of this one? You'll probably know it as "high pinion" (reverse cut) and "low pinion" (standard cut), much like the reference on Dana axles. The pinion line is either above or below the centerline of the ring gear. Rotation's all the same, but the teeth on the gears are cut in opposite directions. R200A from an W/D21 or W/D22: R50 R200A: In general, high pinion is best up front, and low pinion best in the rear due to gear mesh. But fck Nissan for making the R50 the only high-pinion R200A application. The short answer is they can't be (easily) swapped because they are mounted to the truck in completely different ways. The long answer: Link to comment Share on other sites More sharing options...
alexg89 Posted 10 hours ago Author Share Posted 10 hours ago 3 hours ago, hawairish said: You'll probably know it as "high pinion" (reverse cut) and "low pinion" (standard cut), much like the reference on Dana axles. The pinion line is either above or below the centerline of the ring gear. Rotation's all the same, but the teeth on the gears are cut in opposite directions. R200A from an W/D21 or W/D22: R50 R200A: In general, high pinion is best up front, and low pinion best in the rear due to gear mesh. But fck Nissan for making the R50 the only high-pinion R200A application. The short answer is they can't be (easily) swapped because they are mounted to the truck in completely different ways. The long answer: I'll give it a read my man! Worst case I Sas this one too hahha Link to comment Share on other sites More sharing options...
Slartibartfast Posted 1 hour ago Share Posted 1 hour ago I found a couple of similarly failed lifters in a VG33 recently. Out of curiosity, which lifters let go? Mine lost #1 and #5 exhaust. I ask because the only other thread I've found where somebody had that happen, it was the same two lifters that let go. I ended up scrapping that engine, but held onto a few bits and pieces, including the rest of the lifters. PM me if you want a few (unknown mileage, used) lifters that don't look like they've been used as tire studs. Link to comment Share on other sites More sharing options...
alexg89 Posted 43 minutes ago Author Share Posted 43 minutes ago 58 minutes ago, Slartibartfast said: I found a couple of similarly failed lifters in a VG33 recently. Out of curiosity, which lifters let go? Mine lost #1 and #5 exhaust. I ask because the only other thread I've found where somebody had that happen, it was the same two lifters that let go. I ended up scrapping that engine, but held onto a few bits and pieces, including the rest of the lifters. PM me if you want a few (unknown mileage, used) lifters that don't look like they've been used as tire studs. it was number 2 intake, 1 exhaust, and 3 intake and exhaust. and i hate to say this.......... i stuck them right back in lol. Motor was a gamble to begin with considering milage, blow head gasket and the fact cylinder 2 and 6 had some bad pitting in the cylinders. This motor isnt long for this world and i dont expect it to be. Just trying to keep it running long enough to actually build the truck and then im gonna be souring a lower milage one and spruce it up a little. Ive got an extra supercharger for my xterra ill probably end up stuffing under the hood at that point also Link to comment Share on other sites More sharing options...
