AlabamaDan Posted October 1, 2018 Author Share Posted October 1, 2018 Thanks Astrorami Link to comment Share on other sites More sharing options...
AlabamaDan Posted October 22, 2018 Author Share Posted October 22, 2018 I finally had some time to spend installing my lightbar today. It’s not wired up but it is mounted. Wondering around the hardware store today I came across some hinges for a door in the house and thought I might could re-purposed that. Using a saw Zaw I cut off the loops ground off the rough edges and painted it. I think it looks pretty good.Hey trip to Ace Hardware and I was able to spend a few bucks and find some nuts and bolts that worked and here we are.Now I just need to learn to solder so I can wire up the harness.Sent from my iPhone using Tapatalk 3 Link to comment Share on other sites More sharing options...
AlabamaDan Posted October 26, 2018 Author Share Posted October 26, 2018 Since installation Monday, I've been driving the last few days and through the sunroof I can see it vibrating from the wind resistance, but no noise. 2 Link to comment Share on other sites More sharing options...
01Pathmaker Posted November 2, 2018 Share Posted November 2, 2018 On 10/25/2018 at 8:43 PM, AlabamaDan said: Since installation Monday, I've been driving the last few days and through the sunroof I can see it vibrating from the wind resistance, but no noise. Have you thought about doubling up the adapter plates (hinges)? That would make them more rigid and possibly reduce or eliminate the vibration. 1 Link to comment Share on other sites More sharing options...
AlabamaDan Posted November 2, 2018 Author Share Posted November 2, 2018 I'm not too worried about the vibration at this point, but that's a good idea. Link to comment Share on other sites More sharing options...
AlabamaDan Posted November 28, 2018 Author Share Posted November 28, 2018 Worked on extending the wiring a little tonight. I'll finish the install this week and post up more pics and how to. 1 Link to comment Share on other sites More sharing options...
AlabamaDan Posted November 30, 2018 Author Share Posted November 30, 2018 As I mentioned earlier in the thread, the light bar came with a wire from the bar that was too short. I couldn't find a 3-wire covered wire, but I did find a 4-wire with matching wires and one extra green wire. I ran it down the weather stripping along the windshield. I could use a little advice getting it seated back in tight. The wire came out right in the engine compartment. I just cut the green wire off and didn't use it. Cost for the wire was about $4. I had to buy some male spade connectors to connect it, another few bucks there. I soldered the new wires to the harness, added some electrical tape and a heat shrink. Plugged right in. Then I ran picked back up on the controller harness that came with the light bar. I ran it along the firewall using the brake lines (I think that's what they are) to the other side of the engine bay. I couldn't really find a place to mount it on the firewall. There were a few threaded holes on the firewall, but a screw that fit them wouldn't go through the holes in the controller. So, what's a good ol' boy from the south to do? I zip tied it to something! It's really attached well and if I need to get to whatever that is underneath it, I'll just cut the zip ties. I now realize I need a power distribution block, but in the meantime I went ahead straight to the battery. I added an extra nut rather than compromise the stability of the connection to the battery. Works well. For the hot wire, I've been going to this fuse box behind the battery. This is a fused wire. Link to comment Share on other sites More sharing options...
AlabamaDan Posted November 30, 2018 Author Share Posted November 30, 2018 It was nice to finally have it hooked up. White light: Amber light (that will match the lower fogs Back view The switch is a wireless fob. I used one of the black twisty ties and mounted it to the visor. I originally had it on the passenger visor, but moved it to the drivers visor. Link to comment Share on other sites More sharing options...
AlabamaDan Posted November 30, 2018 Author Share Posted November 30, 2018 (edited) Note that the screws that came with the light bar for the mounting are an allen head with a little peg in the middle. So, I saved the special wrench, along with the other two that came with it, in a small zip lock with the instructions. I'll keep this in the glove box. Edited November 30, 2018 by AlabamaDan add photo Link to comment Share on other sites More sharing options...
AlabamaDan Posted November 30, 2018 Author Share Posted November 30, 2018 (edited) Test drive. OE headlights Just the amber lights, headlights off Just the white light, headlights off Whitelights and headlights I had the lights adjusted much higher earlier and it worked well for the white lights. They can really throw the light further down the street/trail. But if I wanted to use the amber lights I needed to aim it lower. Edited November 30, 2018 by AlabamaDan finish last sentence 1 Link to comment Share on other sites More sharing options...
AlabamaDan Posted November 30, 2018 Author Share Posted November 30, 2018 The light bar also has a series of flashing lights which this short video shows me cycling through. Link to comment Share on other sites More sharing options...
RainGoat Posted November 30, 2018 Share Posted November 30, 2018 Wow, that’s alot of functions. I like that it can go all amber or all white. The wireless controller is a handy way of skipping the wiring through the firewall. The amber would be nice for pulling into occupied camping areas without disturbing everybody. It also has very little hood glare from the looks of it. Can you link it again? Link to comment Share on other sites More sharing options...
AlabamaDan Posted November 30, 2018 Author Share Posted November 30, 2018 (edited) I don't have any hood glare at all. I thought about the amber for campgrounds as well so as not to blind people as much. I also thought it would match the OE fogs. Not sure what you mean by linking again? Edited November 30, 2018 by AlabamaDan Link to comment Share on other sites More sharing options...
RainGoat Posted November 30, 2018 Share Posted November 30, 2018 Do you have a specific product name or Amazon link for it? Link to comment Share on other sites More sharing options...
AlabamaDan Posted November 30, 2018 Author Share Posted November 30, 2018 Do you have a specific product name or Amazon link for it?I found it on eBay. My research brought me to the conclusion that a lot of the same ones for the $50-$100 range are all Autofeel. Lots of different sellers and ads, but that same manufacturer. Sent from my iPhone using Tapatalk 1 Link to comment Share on other sites More sharing options...
AlabamaDan Posted November 30, 2018 Author Share Posted November 30, 2018 Do you have a specific product name or Amazon link for it?https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F273408571391Sent from my iPhone using Tapatalk 1 Link to comment Share on other sites More sharing options...
Jax99 Posted November 30, 2018 Share Posted November 30, 2018 Your fitment looks good. Ima gonna hook up a 50 inch bar soon, figure a 40ish woulda been better but I got toooooo good of a deal to pass it up. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
AlabamaDan Posted November 30, 2018 Author Share Posted November 30, 2018 Your fitment looks good. Ima gonna hook up a 50 inch bar soon, figure a 40ish woulda been better but I got toooooo good of a deal to pass it up. Sent from my iPhone using Tapatalk A 50 may be wider than the truck. Mine is a 42”. It’s about 39” from center to center in the OE rails. Sent from my iPhone using Tapatalk 1 Link to comment Share on other sites More sharing options...
Jax99 Posted November 30, 2018 Share Posted November 30, 2018 A 50 may be wider than the truck. Mine is a 42”. It’s about 39” from center to center in the OE rails. Sent from my iPhone using TapatalkRough estimate..... got the bar too cheap to pass up soo I’ll run with itSent from my iPhone using Tapatalk 1 Link to comment Share on other sites More sharing options...
RainGoat Posted December 1, 2018 Share Posted December 1, 2018 You could turn it into a side camping floodlight 1 Link to comment Share on other sites More sharing options...
AlabamaDan Posted December 2, 2018 Author Share Posted December 2, 2018 9 hours ago, RainGoat said: You could turn it into a side camping floodlight I was thinking the same thing. 2 Link to comment Share on other sites More sharing options...
AlabamaDan Posted January 13, 2019 Author Share Posted January 13, 2019 I got to do a little riding on back roads tonight. The light bar is pretty awesome. I do think I need to modify my mounting brackets because there is a lot of vibration. I'll address that later. In the meantime an update on the performance. Here is a shot of the OEM low beams: This is the OEM high beams: This is the high OEM beams and the yellow lights from the LED bar: This is the OEM High beams and the white lights from the OEM bar: This is OME high lights, the yellow and white lights from the LED bar: 4 Link to comment Share on other sites More sharing options...
RainGoat Posted January 13, 2019 Share Posted January 13, 2019 Wow, that’s a lot of light. You’ve done a good job with aiming & the bars output angles look tight enough that I only really see hood reflection in that last picture. 1 Link to comment Share on other sites More sharing options...
AlabamaDan Posted January 13, 2019 Author Share Posted January 13, 2019 Thanks RainGoat. I'm pleased with it and for $50 you can't beat the improvement. My OEM lights are so bad I drove right by a state trooper on bright and they didn't do anything. 1 Link to comment Share on other sites More sharing options...
PathyDude17 Posted January 13, 2019 Share Posted January 13, 2019 Ya, it definitely looks like it shoots further and wider. Good deal Link to comment Share on other sites More sharing options...
