02 Nissan Pathfinder what would cause my brakes to grind
Petercan1020
Every once in a while I can feel mine dragging, I'm ordering a brake rebuild kit soon and will put it on whenever the snow clears. On my caliper there is a bolt with a rubber boot on it that should be able to be compressed but on mine it is seized. I'd check if yours is the same.
here's a link to the kit I'm ordering:
http://www.partsmonkey.com/carlson-quality-brake-parts-disc-brake-hardware-kit-13328q
I think some aftermarket pads are just made of a compound that under the right amount of braking force will make a grinding sound.
I noticed that 3-4 times over the last 6 months even though my brakes are in fine order.
they where very tight putting them in.
Where were they tight? Did you push the pistons back into the calipers before installing the new pads?
Did you put the metal clips in that the pads slid on and lube the bolt that the caliper slids on?
A dab of brake lube on the retaining clips is also good. The caliper assembly should be able to move freely on the pins, which is best tested with the pads removed?
