SC88Pathy Posted March 21, 2005 Share Posted March 21, 2005 OK got a problem here, my hood won't pop when I pull the pop hood switch. This is anoying because someone has to pull on the switch while someone else pulls up on the hood. I can do it alone but it often requires many trips back and forth pulling on switch then pulling on hood. Anyone know what's causing this, and more importantly how to fix it? Link to comment Share on other sites More sharing options...
vengeful Posted March 21, 2005 Share Posted March 21, 2005 Your hood latch and release mechanism has gotten FUBARed. After a while, corrosion builds up and the spring stops working effectively. I had the same problem, replaced the hood latch, and it works fine now. Link to comment Share on other sites More sharing options...
BigMike Posted March 21, 2005 Share Posted March 21, 2005 you try pulling it and smakin the hood? mine sticks sometime but thats cause its still f*cked up since i had my front accident. you tried spraying some lube on the assembly? Link to comment Share on other sites More sharing options...
blackpath94 Posted March 21, 2005 Share Posted March 21, 2005 i sprayed lubeish stuff on mine and it pops right up now. Link to comment Share on other sites More sharing options...
hardwaretoad Posted March 21, 2005 Share Posted March 21, 2005 Try adjusting the tension on your release cable ~ it's wire that stretches over time. Also, you might make sure that your little rubber bumpers for your hood on either side of the radiator support haven't screwed themselves down too far. Take a Phillip's head and back them out a bit, that'll create some tension against the latch so it goes back to "popping" open again. The lube's a good idea, too. I'd try those before running out & springing for a new latch... GL Link to comment Share on other sites More sharing options...
thndrwhls Posted March 21, 2005 Share Posted March 21, 2005 Ahh, this one I know, its pretty simple too... Ya know those rubber bumpers on either side of your radiator that are there to support the hood, well they actually have treads so that they can be adjusted like a screw and if you back them out a little bit they will put enough pressure on your hood to help it pop up when you pull the release. I know this because I had the same problem and my cousin who is a mechanic adjusted them for me and it works great now. Hope it helps... Link to comment Share on other sites More sharing options...
94extreme Posted March 21, 2005 Share Posted March 21, 2005 as to one man operations.. try using a string or a bungee cord from your steering wheel or head rest to the hood popping mech in the cab... Link to comment Share on other sites More sharing options...
hardwaretoad Posted March 22, 2005 Share Posted March 22, 2005 as to one man operations.. try using a string or a bungee cord from your steering wheel or head rest to the hood popping mech in the cab... Good idea, mzxtreme! Kind of like the game "Mousetrap", right? I love Rube Goldberg-type fixes, truly man's greatest triumph is the satisfaction of jury-rigging some contraption that actually does what you intended it to do. Maybe not the right way, but it's my way, dammit! Now, where'd that cat go? Link to comment Share on other sites More sharing options...
94extreme Posted March 22, 2005 Share Posted March 22, 2005 lol, thanks... man, i almost always work on my vehicles all by myself... necessity is the mother of invention after all... Link to comment Share on other sites More sharing options...
hardwaretoad Posted March 23, 2005 Share Posted March 23, 2005 (edited) Rube Goldberg walks in his sleep, strolls through a cactus field in his bare feet, and screams out an idea for self-operating napkin: As you raise spoon of soup (A) to your mouth it pulls string (B.), thereby jerking ladle © which throws cracker (D) past parrot (E). Parrot jumps after cracker and perch (F) tilts, upsetting seeds (G) into pail (H). Extra weight in pail pulls cord (I), which opens and lights automatic cigar lighter (J), setting off sky-rocket (K) which causes sickle (L) to cut string (M) and allow pendulum with attached napkin to swing back and forth thereby wiping off your chin. After the meal, substitute a harmonica for the napkin and you'll be able to entertain the guests with a little music. Edited March 23, 2005 by hardwaretoad Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 23, 2005 Share Posted March 23, 2005 Basically, these guys have covered the bases. It needs to be properly lubed and adjusted before it'll start working right again. Link to comment Share on other sites More sharing options...
SC88Pathy Posted March 25, 2005 Author Share Posted March 25, 2005 Adjusted rubber bumpers and ta da! hood now pops open! Thanks for the help everyone. :bow: Link to comment Share on other sites More sharing options...
Arthur92XE Posted March 28, 2005 Share Posted March 28, 2005 Had that problem last year. I got a hood latch from a junkyard. Before I replaced it I cleaned it up real well, added grease and now it works just fine. Link to comment Share on other sites More sharing options...
