Cell phone car mount
mickmutante
This might be a silly question, but is there an off road cell phone car mount?
I have never used one, so I have been looking a lot of those and I really do not know what to buy...
Wich car mount do you use? Pros? Cons?
Thanks.
Tons of options. I prefer any clamp style window mount. Just google search it and find something you like. The only advice I can give in terms of stuff to stay away from is vent clip mounts, those don't hold up off-road. And don't cheap out either because a good window suction mount needs to be solid, like a GoPro suction mount. I've had cheap ones and they just stopped working after a while. You could also consider cigarette lighter mounts, holds your phone and charges it.
Something like this:
http://www.amazon.com/UNPAINTED-MOUNT-WITH-SUCTION-GRIP/dp/B006QRHZJK/ref=zg_bs_2407778011_33
or this:
http://www.amazon.com/VicTsing-Charger-iPhone-Samsung-Smartphones/dp/B0177T3DO6/ref=sr_1_1?s=car&ie=UTF8&qid=1452735108&sr=1-1&keywords=cigarette+lighter+phone+mount
I use a specific bracket for a JK and a case+holster for my phone of choice.
http://www.quadratec.com/products/17017_005.htm
http://www.amazon.com/Platinum-Seidio-Kickstand-Holster-Samsung/dp/B00PF9KIAS
The bracket fits with a trivial amount of bending, mounts using a radio bracket bolt. I drill out the rivet on the holster and bolt it to the mount (I also retain the mechanism that allows it to rotate) using a small socket flathead bolt and nylock.
Since the phone clips into the holster, it's not going anywhere.
I know some of the pictures are gone, but these threads should help with idea's too
Cell phone holder install
MOD: Cellphone mount
interior modifications
Note, the mount that I referenced is still in my truck with the only changes being the actual holster portion changed to match phone models used over time.
One word: slick...
Thanks!
There are also a few mounts meant for bikes/motorcycles that use ram/ball mounts. The bracket I used allows for simple bolt on of those mounts, but I found those parts to be a little expensive and bulky. And if not cranked down, the phone will move when off-roading.
