SpecialWarr Posted April 1, 2015 Share Posted April 1, 2015 I was looking for the load-sensing brake valve under the pathfinder on the weekend and I cannot seem to locate it. Where exactly is that creature supposed to be? 1990 4x4 auto with disc brakes at all 4 wheels. It would seem to me that it would be under the truck near the rear axle but I have nothing but an exhaust, spring perches and a fuel tank. Link to comment Share on other sites More sharing options...
adamzan Posted April 2, 2015 Share Posted April 2, 2015 They don't have them. Only the hardbodies did. Link to comment Share on other sites More sharing options...
5523Pathfinder Posted April 2, 2015 Share Posted April 2, 2015 And caR50s Link to comment Share on other sites More sharing options...
SpecialWarr Posted April 2, 2015 Author Share Posted April 2, 2015 Soooo.... no ABS either... hmmmm.... that would explain the lockup of all four wheels yesterday on the highway. Oh Well, that just means less stuff to break! Thanks boys! Link to comment Share on other sites More sharing options...
Precise1 Posted April 2, 2015 Share Posted April 2, 2015 Actually, I believe you should have rear ABS (inside frame rail on the passenger side, 2/3 of the way back), but it is a fairly useless system that only might do something if you are towing a heavy load and brake hard. Soo... yeah. B Link to comment Share on other sites More sharing options...
CO_pathfinder Posted April 2, 2015 Share Posted April 2, 2015 ^ Yea, I just ripped my ABS computer out and might re-connect it when I upgrade the abs module this summer Link to comment Share on other sites More sharing options...
SpecialWarr Posted April 2, 2015 Author Share Posted April 2, 2015 I will go and take a look for that 'cause DAMN it don't work now! Link to comment Share on other sites More sharing options...
Pav Posted April 3, 2015 Share Posted April 3, 2015 I had an '88 and '90 WD21 and don't remember either having the rear ABS as part of the brakes. Link to comment Share on other sites More sharing options...
CO_pathfinder Posted April 3, 2015 Share Posted April 3, 2015 It was one of the many mix-and-match Pathfinder options Link to comment Share on other sites More sharing options...
Pav Posted April 3, 2015 Share Posted April 3, 2015 It was one of the many mix-and-match Pathfinder options ABS might have started after the '90 model...both were full loaded manual SE models...and the '90 had a Nissan tow option. I'm going to keep researching this one...I still have old dealer pamphlets I'm going to dig up to confirm what years had this option. Or Nissan guru Rob can tell us...lol. End of the day, the ABS on these trucks is useless and only in the rear so its better to just forget its even there and drive old school with threshold braking. Link to comment Share on other sites More sharing options...
SpecialWarr Posted April 3, 2015 Author Share Posted April 3, 2015 (edited) Old Skool it is then! I was just really looking for better performance from the rear brakes so maybe I'll install an adjustable brake bias valve so I can get a bit more out of the rears. I can't say I mind not having the ABS from back in the day, I recall that they were lauded as the NEXT BIG THING but really never worked as well as they were supposed to except under a fairly strict set of parameters. I guess it didn't help that common braking techniques were either threshold for car guys and pump-and-release for the other 80% of drivers. Edited April 3, 2015 by SpecialWarr Link to comment Share on other sites More sharing options...
CO_pathfinder Posted April 5, 2015 Share Posted April 5, 2015 End of the day, the ABS on these trucks is useless and only in the rear so its better to just forget its even there and drive old school with threshold braking. Yea, considering that my rear drums probably can't even lock my rear wheels up, I considered it a reasonable thing to just remove the ABS control box. Link to comment Share on other sites More sharing options...
WD21colorado Posted April 5, 2015 Share Posted April 5, 2015 my 95 has a rabs ( Rear ABS ) and as far as i can tell it kinda works but only if high wheel speed is operating and is on slick ice other than that i dont think abs is all that useful on these old vehicles since most of the braking force is up front something like 70% front and 30% rear. Link to comment Share on other sites More sharing options...
Precise1 Posted April 5, 2015 Share Posted April 5, 2015 Sorry, my bad then! I thought all 4 door WD21s at least came with the rear ABS and didn't consider it an option. Maybe it varies per country as well... Yea, considering that my rear drums probably can't even lock my rear wheels up, I considered it a reasonable thing to just remove the ABS control box. Then I'd say that your brakes aren't adjusted properly or your shoes are contaminated. I know mine are from a leaking seal... B Link to comment Share on other sites More sharing options...
Pav Posted April 7, 2015 Share Posted April 7, 2015 Final Verdict - rear ABS was added to the WD21 starting 07/90. If your vehicle was made after that date you have it. Link to comment Share on other sites More sharing options...
SpecialWarr Posted April 10, 2015 Author Share Posted April 10, 2015 Nope... 05/90 on the door jamb! But it does have 4 wheel disc brakes! Link to comment Share on other sites More sharing options...
Precise1 Posted April 10, 2015 Share Posted April 10, 2015 Final Verdict - rear ABS was added to the WD21 starting 07/90. If your vehicle was made after that date you have it. Well, I was close... Thanks for clearing that up, good info. Damn Nissan and their 1/2 year changes! B Link to comment Share on other sites More sharing options...
mechanicalbaron Posted April 11, 2015 Share Posted April 11, 2015 My 90 pathfinder has 4 wheel disk brakes, however no rear wheel ABS. But I got auto AC =) Not sure the production date in it though. Link to comment Share on other sites More sharing options...
