AkPrecision Posted December 11, 2014 Share Posted December 11, 2014 Does anyone know someone who makes the r50 missing link? Any help is appreciated Link to comment Share on other sites More sharing options...
CNAM Posted December 11, 2014 Share Posted December 11, 2014 What exactly is this R50 missing link you speak of? 1 Link to comment Share on other sites More sharing options...
AkPrecision Posted December 11, 2014 Author Share Posted December 11, 2014 Its a crossmember that makes the pathy much more rigid. It bolts to the arms underneath. They say it also makes it handle even better than it aleady does. Hence its name the missing link 1 Link to comment Share on other sites More sharing options...
paul.thoroughgood.3 Posted December 11, 2014 Share Posted December 11, 2014 If I'm thinking of the correct part, I saw someone on here using 1.5" galv pipe and just compressed the ends and used existing LCA bolts. He did it mainly as a support for his skid plate though Link to comment Share on other sites More sharing options...
CNAM Posted December 11, 2014 Share Posted December 11, 2014 I added one I guess... When I did my skid plate too.. Steel bar stock cut and drilled. also undercoated it. 1 Link to comment Share on other sites More sharing options...
ferrariowner123 Posted December 11, 2014 Share Posted December 11, 2014 Jackson autosport I think is who made it to buy, I have one, but I'm fairly sure you can't buy them anymore. They can be made fairly easy though. -Kyle 1 Link to comment Share on other sites More sharing options...
AkPrecision Posted December 29, 2014 Author Share Posted December 29, 2014 Was looking at krypton fabs website and he makes a missing link! Link to comment Share on other sites More sharing options...
PathyDude17 Posted December 11, 2018 Share Posted December 11, 2018 Any thoughts on this approach to a missing link? If it holds up as good as anything else, I'd like to give it a shot 1 Link to comment Share on other sites More sharing options...
herotrooper Posted December 12, 2018 Share Posted December 12, 2018 I followed stiocs approach and it’s been working great for me. Noticed an improved on my drive home that evening. I didn’t have any tube lying around the shop so I went to Home Depot and got a black steel pipe with threaded ends for under $15 (CAD) cut the ends off, and squished them in the press. I went a little farther and rounded the ends and then welded them shut. Quick coat of self etch primer then some black paint and on it went. Been on my truck for about 3 weeks now and it’s not coming off. Only thing I need to do is to make sure it’s torqued to correct spec now that I have a factory service manual. If you have any questions, feel free to ask. *also on my phone at the moment so if you want pics I can put them up later* 3 Link to comment Share on other sites More sharing options...
joshrichard Posted December 12, 2018 Share Posted December 12, 2018 SFcreations.com Link to comment Share on other sites More sharing options...
PathyDude17 Posted December 12, 2018 Share Posted December 12, 2018 Thanks herotrooper! Ya I saw the one of sfcreation, but I’d like to not spend $100 2 Link to comment Share on other sites More sharing options...
PathyDude17 Posted December 12, 2018 Share Posted December 12, 2018 9 hours ago, herotrooper said: I followed stiocs approach and it’s been working great for me. Noticed an improved on my drive home that evening. I didn’t have any tube lying around the shop so I went to Home Depot and got a black steel pipe with threaded ends for under $15 (CAD) cut the ends off, and squished them in the press. I went a little farther and rounded the ends and then welded them shut. Quick coat of self etch primer then some black paint and on it went. Been on my truck for about 3 weeks now and it’s not coming off. Only thing I need to do is to make sure it’s torqued to correct spec now that I have a factory service manual. If you have any questions, feel free to ask. *also on my phone at the moment so if you want pics I can put them up later* I don't have access to a shop press, would a bench vise be sufficient? What's the best workaround for that? Link to comment Share on other sites More sharing options...
herotrooper Posted December 12, 2018 Share Posted December 12, 2018 (edited) Could work. If you are using a vice I’d probably heat up the metal if you can or slide a longer bar over the vice handle so you can get some leverage, or both. Lol. Make sure you measure a few times so when the link is attached, the round part will clear the lower control arm and the flattened piece will actually lay flat where it bolts up. Edited December 12, 2018 by herotrooper Grammar Link to comment Share on other sites More sharing options...
PathyDude17 Posted December 12, 2018 Share Posted December 12, 2018 Ok, thanks. Might just have to buy the pipe and give it a shot! Link to comment Share on other sites More sharing options...
PathyDude17 Posted December 21, 2018 Share Posted December 21, 2018 As a follow up, I went through on this approach to the missing link. Definitely added some sturdiness to my ride, and I’m very pleased with it for what it cost 5 Link to comment Share on other sites More sharing options...
zakzackzachary Posted December 21, 2018 Share Posted December 21, 2018 You ended up buying pipe and flattening it yourself? Link to comment Share on other sites More sharing options...
PathyDude17 Posted December 21, 2018 Share Posted December 21, 2018 1 hour ago, zakzackzachary said: You ended up buying pipe and flattening it yourself? Yep! 3/4” EMT. I used a vice one time on each end to flatten out about 3” per side. I also painted it, but couldn’t get a picture of it into my post 1 Link to comment Share on other sites More sharing options...
Jax99 Posted December 21, 2018 Share Posted December 21, 2018 Awesome! In the end it’s good you have that. I’m still confused why my bro had an arb bumper before a missing link Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
PathyDude17 Posted December 21, 2018 Share Posted December 21, 2018 When all it takes is $4 and few hours of work, I can’t see a reason not to do it. 1 Link to comment Share on other sites More sharing options...
RainGoat Posted December 22, 2018 Share Posted December 22, 2018 As a follow up, I went through on this approach to the missing link. Definitely added some sturdiness to my ride, and I’m very pleased with it for what it costNice job. Looks great! 1 Link to comment Share on other sites More sharing options...
herotrooper Posted December 28, 2018 Share Posted December 28, 2018 Glad you got this done! Looks good. 1 Link to comment Share on other sites More sharing options...
MTGunner Posted January 1, 2019 Share Posted January 1, 2019 OK, following this thread and can someone clarify the advantage in this modification. Has been said that it improves handling and makes suspension stiffer. This would be a easily fabricated link if the advantages are truly significant. Please elaborate more. Thanks. MTG Link to comment Share on other sites More sharing options...
PathyDude17 Posted January 1, 2019 Share Posted January 1, 2019 So it does improve handling and stiffen up your ride. It also makes your ride stronger, and protects the front suspension from undue stress by linking those lower arms together. I legitimately noticed less body roll in cornering, and I guess its harder to prove that it strengthens the structure of your ride, but that's generally what crossbars do..... Also if you make the crossbar a certain way, it serves as a great mounting point for some skid plates 1 Link to comment Share on other sites More sharing options...
RainGoat Posted January 15, 2019 Share Posted January 15, 2019 It’s worth noting that it may compromise safety in a front impact as it likely inhibits ejecting the drivetrain components down & away from the passenger compartment. I’m not saying you shouldn’t do it, just pointing out pros & cons. 2 Link to comment Share on other sites More sharing options...
Sjackson2 Posted February 6, 2019 Share Posted February 6, 2019 On 12/20/2018 at 10:19 PM, PathyDude17 said: As a follow up, I went through on this approach to the missing link. Definitely added some sturdiness to my ride, and I’m very pleased with it for what it cost Just a heads up....they guy that owns jackson motor sports has stated that that was their original prototype and it works pretty much as well as the one they were selling. I made one last week from 6 dollars worth of 1 1/4 angled steel. It’s working great and is one of the better mods I’ve done to my pathy 1 Link to comment Share on other sites More sharing options...
