Hmmm, Never been here before. This is new!
Kyle94
Does it happen when using cruise control?
I would also try the following:
  • Adjust accelerator and cruise throttle wires' slack (see FE-3 and EL-161 respectively, for instructions)
  • Ensure throttle body return spring and the spring on the accelerator pedal are not binding and are properly secured
  • Clean throttle body and MAF sensor (use throttle body cleaner and MAF cleaner only)
  • Check intake tubing for damage / leaks
  • Change fuel filter
EDIT: Wow, this forum software is idiotic. It can't even handle my list.
Edited by Towncivilian
But the plate is steadily open when on the throttle? The pulsating/fluctuations I get are when I'm on the throttle.
Did you mean to say the pulsation/fluctuations you get are when your not on the throttle?
If so there probably is build up on the edges of the TB buttefly, the butterfly is designed to let some air through when it is closed so the engine can idle, if the edges of the butterfly are dirty the small gap where air can get through would be restricted and air may not be able to get through causing the bad idle.
Kind of sounds like a distributor or spark plug wires issue. Whatever it is, it is happeneing when the engine is under load.
Check the FSM for the diagnositic proceedure for 'engine surging' and do the sub proceedure for 'under load'
Edited by Alkorahil
That's what I'm thinking...
I heard the bearing in someone's dizzy went out and caused problems. But I HEAR something inside the dizzy spinning around. Can't tell if it's the rotor hitting the points or not.
Have you looked at the points on the rotor and the rotor head yet? If they are worn to nothing it could be that simple.
  • 3 weeks later...
HECK YA MAN, GRATS ON YOUR R50, I have loved mine since i bought it 5 or 6 years ago. REALLY REALLY reliable. only thing i have done to it so far is throw a batter at it and valve cover gaskets, "well aside for the rear diff gear oil, and normal upkeep stuff" getting ready to do the front diff and manual trans fluid soonish, probably the next week or 2. "fluid transfer pump 18 bux is all i have to say about the diff oil" it will make you not want to cry in the fetal position....."just trust me on that" haha
Well, so far its gotten a total audio system rebuild. New "used" vg33er distributor cap and rotor. But still haven't figured out the pulsation/fluctuation.
And i took it on a little adventure.
My hitch acted as an anchor at one point and i almost got stranded. lol. I dug some earth out as i bashed around. damn low ground clearance!
  • 4 weeks later...
Added some new to me wheels! :) Much better stance and look over all... But then i played around on shale, and lost a tire. :( So it's running the silly stock spare until i get a new one.
Decided to play around with some editing features i found on photobucket :)
thanks!
I dunno why. But I've always liked these wheels. Plus they give it a wider stance that I like. But not to much, they still tuck.
Yeah. I love the woods in our area. :)
Cabin? There's PLENTY! lol.
It's 1984 Audi 4000s quattro that is sadly going to the scrap heap this weekend. Sold a whole bunch of parts off it for 700$+. and im making money on scrapping it, it is what it is...
Yeah he's a fan. And that's a sad loss of 80s design, though I'd never drive it, my dad bought an audi 5000 brand new and the glovebox door handle came off in a month. It was steeply down hill from there.
